El Steak Super-Commuter
Postby El_Steak » Wed Mar 24, 2010 8:53 pm
Here's my finished winter project.
My goal was to have something comfortable, clean, elegant and FAST. Stealthy would have been nice, but unfortunately the 9c is not very quiet.
My Methods controller is software-limited at 100 Amps and I can run the motor in either 18s3p mode (75V max) or 24s2p (100V max). Because of my large wheel size (26") and too fast motor (10x6), I generally leave it in 18s3p config. With 75V I can reach 70km/h (43mph). With 100V I reach over 80kph (50mph). It pop wheelies with both voltages and climbs any hill I could find while accelerating ;)
I spent a lot of time on the brakes. They are pretty much your only safety feature on a bike so you don't want to skip on them. This bike brakes really hard, no comparison with V brakes.
The decisions I made when building this bike were heavily based on information gathered from this site.
Here's the list of threads related to features on this bike:
Buying the TidalForce Frame: http://www.endless-sphere.com/forums/vi ... 31&t=10748
Installing a rear disk brake on the S-750 (my thread): viewtopic.php?f=2&t=13722
Air cooling your hub: http://www.endless-sphere.com/forums/vi ... f=2&t=9791
Upgrading your phase wires: viewtopic.php?f=2&t=14580
Lipo battery basics: viewtopic.php?f=14&t=9170
More essential Lipo Info: viewtopic.php?f=14&t=10817
Method's 100V 100A controller: viewtopic.php?f=2&t=13638
Fuses for the battery: viewtopic.php?f=2&t=15225
Motor selection for high voltage (my setup is not optimal - yet): viewtopic.php?f=3&t=14711
All the specs and details are in the pictures.
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: viewtopic.php?f=6&t=17166
El_Steak
Re: El Steak Super-Commuter
Postby slayer » Wed Mar 24, 2010 10:30 pm
I think you forgot to put the pictures.
slayer
Postby voicecoils » Thu Mar 25, 2010 3:50 am
That's a super clean build!
'Methods' controller, vented hubmotor, fat phase wires, lipo, hookworms, temp monitoring, beefy torque arms...you've brought together alot of great parts and recommendations from the forum and packaged it all very nicely. :)
Videos coming? :D
voicecoils
Postby dogman » Thu Mar 25, 2010 6:16 am
Holy Ribeyes Batman!
That is one of the cleanest builds I ever saw! I really like what you did with the wires, and the shrink wrapped connectors. You realize that if you bought all that from a vendor of pre built bikes the retail would be at least $2500? I bet you have a lot less than that in it.
I really like the bbq thermometer. How much do those run? Sensor actually in the motor? Guess it really hauls ass if you still need the thermometer with the hub ventilated! Bet they'd ticket the crap outa ya in Phoenix AZ! Or Florida.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby El_Steak » Thu Mar 25, 2010 9:07 am
Thanks guys.
dogman wrote:You realize that if you bought all that from a vendor of pre built bikes the retail would be at least $2500? I bet you have a lot less than that in it.
Less, but not that much unfortunately. The controller alone is 400$ and if you add in the 9 Lipo packs, charger and power supply, you're already over half that amount and you don't yet have a bike or motor... ;)
dogman wrote:I really like the bbq thermometer. How much do those run? Sensor actually in the motor?
That thermometer is readily available on ebay from several vendor. You can get it shipped to your door for under 10$. I carefully cut the "probe" to get the thermistor out and then added teflon extension wires all the way to the inside of the motor. The sensor is installed very close to the winding inside the hub. There's a problem with that thermometer which I only discovered after it was all installed: it's got an annoying auto-shutoff feature after 10 minutes. Its not that big an issue for me because I know when I'm at risk of overheating the motor (long climbs, repeated hard acceleration). On fast WOT rides, the motor doesn't get too hot.
voicecoils wrote:'Methods' controller, vented hubmotor, fat phase wires, lipo, hookworms, temp monitoring, beefy torque arms...you've brought together alot of great parts and recommendations from the forum and packaged it all very nicely.
Videos coming?
Yes, its designed-by-ES in many ways. I added links at the top of all the threads I used for this build.
I don't think I'll make any video of me riding the bike. I watched a few clips of GTinDC riding in Washington and there's no way I can come up with something even remotely close to that :shock:
El_Steak
Postby ambroseliao » Thu Mar 25, 2010 10:01 am
Congrats El_Steak,
Beautiful build. I'm envious. My build of the S-750 works well, but isn't nearly as beautiful as your amazing kit!
Ambrose
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby StudEbiker » Thu Mar 25, 2010 11:07 am
Wow, El_Steak that thing needs flames because that is one HOT ROD TidalForce!! 8) Also, can you tell me where you sourced that kickstand. I have noticed this bike is a bit tippy with the single and I think that is a logical upgrade to the bike.
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby El_Steak » Thu Mar 25, 2010 11:40 am
I got the double stand directly from OatNet (viewtopic.php?f=31&t=10748#p164988)
He was selling it 35$ with the frames. Check with him, he might have some left.
I had to add a 1/4" shim between the mounting bracket and frame because the Hookworm tires are too big and the stand would not reach the ground.
El_Steak
Postby maydaverave » Thu Mar 25, 2010 9:59 pm
One very well realized e-bike. Best in show 8)
e-bikekit 50v 9.2ah cellman pack
maydaverave
Postby slayer » Fri Mar 26, 2010 4:32 am
Funny when i'm at work i can't see the pictures, but at home i can see them.
Anyway very nice bike, very stealth too, it must be a rush to ride.
slayer
Postby Mark_A_W » Fri Mar 26, 2010 4:37 am
Yes, very nice build.
Although...the first time you get a flat rear tyre that nice heatshrinking on the connections will get cut to bits. A lizardskin works well in this application.
How did you get the disc on the 9C? I thought a disc wouldn't fit..
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Mark_A_W
Postby StudEbiker » Fri Mar 26, 2010 6:51 am
Disc brake install thread here:
StudEbiker
Postby El_Steak » Fri Mar 26, 2010 7:00 am
Mark_A_W wrote:the first time you get a flat rear tyre that nice heatshrinking on the connections will get cut to bits.
The nice thing with the shrink wrap is that on top of the cosmetic and water proof benefits, it provides a pretty strong mechanical pressure on the connectors. Most of the problems I've had with my ebikes in the past where related to some sort of poor connection. Especially with those damn hall wires. I bought a whole batch of shrink tubing of all sizes on ebay, so removing the shrink wrap is not a bigger concern for me than cutting tie wraps.
With the rear rack, torque plates, disk brake and all, changing a flat on the rear wheel would be a biatch, so I invested a bit in preventive measures and bought some heavy-duty Down Hill tubes (thick stuff) and a Panaracer kevlar liner.
Mark_A_W wrote:How did you get the disc on the 9C? I thought a disc wouldn't fit..
The 9c is threaded on the left side so you can use "screw on" chinese disks (available from ebikes.ca and ebikekits) or you can buy this adapterand use any disk.
Fitting the 9c with disk brake on the tidal force frame was another story thought.
El_Steak
Postby Ypedal » Fri Mar 26, 2010 6:32 pm
Nice work !!.. Where did you find the hookworm tires ?
The TF frames are awsome, i have 5 more in storage waiting for parts !
You should fire up the video cam ! :D
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby El_Steak » Sun Mar 28, 2010 9:48 am
I got lucky for the Hookworms. I found them on the 12th page of google results from a small trial bike web site.
The guy had only 2 and said he was stuck with them. He sold them 20$ cdn each. :D
He still lists them on his web page at the same price.
Here's the link: http://www.thetrialsinshop.com/wheels.html
El_Steak
Postby Hyena » Sun Mar 28, 2010 6:26 pm
Very tidy el steak.
Those tidal force frame are very nice, I'd be snapping up a few if I was in the US.
As voicecoils said you've taken all the best suggestions from the forum and incorporated them into one neat package.
My bike has very similar components and mods but the down side is I look like a suicide bomber riding it :lol:
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby Doctorbass » Sun Mar 28, 2010 8:31 pm
El_Steak wrote:Thanks guys.
Videos coming?
I think i already saw BBQ thermometer in hub motor somewere else setup? :P
.. Nice build!.. clean, full upgrade, all components maximized!
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Salix » Sun Mar 28, 2010 9:08 pm
A very neat and tidy bike. Well Done. Hate to sound very dull but what rear cassette are you running as getting 11 tooth cassette am finding to be difficult and as you rightly said you need a very small rear gear on a powerful e-bike due to speeds you travel at but still want to do some pedaling without super fast cadence.
Thanks and again, nice job
Salix
Postby El_Steak » Mon Mar 29, 2010 7:01 am
Salix wrote:what rear cassette are you running as getting 11 tooth cassette am finding to be difficult and as you rightly said you need a very small rear gear on a powerful e-bike due to speeds
Its a cheap chinese freewheel that I got from ebikes.ca. I don't see it listed on their web site anymore though. Methods has one listed for sale for 25$ on his page: http://www.deviantmethods.com/MethodsSa ... _Sale.html
Some people complained about the noise it makes, but you can fix that by oiling it properly. More info here: http://www.endless-sphere.com/forums/vi ... =3&t=14696 and here viewtopic.php?f=2&t=1468.
El_Steak
Postby nicobie » Mon Mar 29, 2010 2:41 pm
Nice Bike!
You really paid attention to the best ideas that ES has to offer. I honestly can't think of anything else that would make a ebike nicer (except maybe doing the CA amp limiting mod that you probably don't need anyway as you have the 3 speed throttle :mrgreen: ).
I don't think you could find anything comparable on the market with 74V/15Ah and all the same features for less than $5k USD.
Good job. Thanks for sharing.
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby El_Steak » Mon Mar 29, 2010 6:57 pm
Thanks.
I'm happy with the bike so far, but I'm already thinking of many possible upgrades/mods. It's an expensive hobby :mrgreen:
El_Steak
Postby StudEbiker » Mon Mar 29, 2010 8:26 pm
El_Steak wrote: It's an expensive hobby :mrgreen:
You should try Studebakers some time!
StudEbiker
Postby mikeross » Fri Apr 09, 2010 11:37 am
El-steak, a first rate build! You have paid a lot of attention to the details throughout. I especially like the disk brakes front and rear. As fast as this bike will go, you better be able to stop it quick :shock: These Tidal Force frames really do make for some super nice ebikes! 74V - how do you keep it on the ground??
Can I ask you a question - how on earth did you mount your CA to the handlebars? I butchered a Kryptonite lock holder to *sort of* mount mine - could not find any useful info on that one.
Excellent build!
Mike
Current bike: Tidal Force, 9C Rear Hub, EVC 36v 10a Battery and Rack
Next project - upgrade my Giant LaFree 24v SLA to lithium
mikeross
1 W
1 W
Postby grindz145 » Fri Apr 09, 2010 11:47 am
maxxis has to be making out like bandits on the ebike community:D I love them for urban assault too. I really like the sheathing on the wires. I'm really looking to make my build as clean as possible and I bet this is even cleaner than heatshrink for a large amount of wire.
P.S. I might have to follow suit and use a BBQ thermometer myself. Hope you don't mind... :mrgreen:
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby El_Steak » Fri Apr 09, 2010 12:07 pm
I myself stole the BBQ thermometer idea from other members...
You might want to buy one without an auto-shutoff feature. Its annoying.
I searched a bit on the forum and tracked down the one that Doc uses. From what I can see, it has no auto shutoff feature and it has a programmable alarm that will ring whenever you exceed a certain temp. I might swap mine for that one.
Here it is:
http://www.canadiantire.ca/AST/browse/2 ... ?locale=en
El_Steak
Next
Who is online
Users browsing this forum: 2fast2green and 8 guests
