Adrian's 2nd Build - Giant AC Full Suspension
Re: Adrian's 2nd Build - Giant AC Full Suspension
Postby adrian_sm » Sat May 01, 2010 3:13 am
Yeah. My Avanti stem is longer, about 100mm, but it is for a different diameter handlebar in the centre portion. So I will have to switch the stem + handlebars. On the plus side it will let me use my new DIY CA mounting bracket. Got sick of the original one which was so flimsy. Felt like it was going to break everytime I pushed a button.
So here it is. Adjusted the seat while I was at it.
Now I have the CA,DC->DC, and lights all hooked up to.
- Adrian
Longer stem
Longer stem and set forward.
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby adrian_sm » Sun May 02, 2010 10:27 pm
Well made it to work without any failures. Glad I had it running, as I don't have a car at the moment, and am still getting over this flu.
Felt good. Definitely feels safer than the old bike. I used to get this "Oh shit, why would anyone go faster than this on a e-bike" feeling on the hardtail when you hit dodgy bits of tarmac. Now it feels in control.
Stuck to the roads so haven't tried it on bumpy stuff yet. Might take a detour on the way home.
Still a few things to do to finish it off:
1) Torque arms
- current set-up is too dodgy.
2) Rear brake
- I failed last time I tried to put a disc on my rear 408
- lets see if I can do better, or just buy a different motor. Hmmm.
3) battery enclosure
- thinking vac formed
4) Swap pedals
- need to put my SPD clipless peddles on.
5) New seat post
- have a 30.6 on a 30.9 frame, mounted beyond it's minimum insertion point.
6) Mudguard clean up
- probably just a better mounting bracket for the rear
- cable ties, and hot glue was Mark_A_W's recommendation for the front
All pretty minor stuff, so am pretty happy with how it all came together.
Now to spend the 80% effort, on the final 20%.
adrian_sm
Postby adrian_sm » Tue May 04, 2010 9:16 am
Only minor updates:
1) Mudguards:
Well it was a wet ride home, and it highlighted how dodgy my first attempt at mudguard attachment was.
Nothing a bit of hot melt glue, a pair of scissors, and a small metal bracket wont fix.
2) Pedals
Got my SPD pedals on and am much happier. No longer have to worry about feet position on the pedals, and feet slipping off.
3) Battery Cover
Survived the wet trip home without getting electrocuted, or things stopping, but need a more permenent solution.
I couldn't work out a neat way to retain the batteries, protect from bumps, and weather proof using the vac formed plastic covers.
Also worried it might end up looking like a petrol tank as Mark_A_W puts it.
So current theory, is to keep the duct tape retention, as it seems to be holding things nice and firm, but add some bash plates to side and rear of battery. Then create a fabric weather cover (cut down to a snug frame hugging fit) from this....
http://www.torpedo7.com.au/products/R7JKVN8SS/title/route-7-softshell-vest
It will cover all the duct tape, and wrap around the front of the frame, back of the battery, but probably leave the controller exposed to keep the shape and size in check. If I get it snug enough it should improve the looks a bit, and keep the rain out. For $30 I thought it was worth a try.
- Adrian
adrian_sm
Postby adrian_sm » Wed May 05, 2010 7:08 am
Rear Disc Brakes & rear 408's part 2
On my last build I bought a disc brake mount side cover for my rear 408, but things didn't go according to plan.
Essentially it spaced the disc so far over it clashed with the frame. Eventually I sold it off to another forum member who assured my he could get around the issue.
This left me with rim brakes on the back, disc on the all important front and I was happy enough.
Now this frame doesn't have rear rim brake mounts. So I have to find another solution.
The options I have found are:
1) Custom ~225m rotor
- this will allow me to place the disc caliper such that it clears the outer diameter of the motor
- the disc could be bolted directly on the existing side cover.
2) Standard 203mm rotor
- this brings the caliper inside the outer diameter of the motor
- even if I go to low profile button head screws for the side cover, the position of the caliper would put the disc to wide and it would hit the frame...
- don't really want to try and modify the frame to create clearance.
3) Try different brake calipers
- might find something that has less bulk between the rotor and the motor, as this is causing the main clearence issues
4) No rear brake.
- not ideal
.............. OR ...............
5) Go to a different motor
- sensored Bafang BPM, with a fast wind sounds like a good option
- it can fit a disc
- will be faster, with out requiring me to upgrade my batteries
- higher torque, so quicker up the hills
- will free wheel
- it would be lighter
I feel some upgradeitus coming on....
adrian_sm
Postby adrian_sm » Tue May 18, 2010 8:22 pm
Couple of minor updates.
I have order some 8" discs for front and back, along with adapters.
And had an idea in my head when looking a LiPo pack I got for an RC plane, that I just had to try ....
Not the right size, but had to try it anyway.
adrian_sm
Postby adrian_sm » Thu May 20, 2010 7:51 am
It is amazing how much difference a few volts make. That tiny little LiPo pack really helped my understand what extra volts would mean for my bike.
The main thing I noticed is the available power. Not too surprising really, since I usually cruise at 40kph using WOT as my "cruise control".
With the extra volts, at 40 kph I now have about 300w reserve power. So rather than slowly settling towards 40kph, I race towards it.
It really changes the whole feeling of the bike, especially with the new DH frame. It felt less like a push bike, and more like a motor bike.
To me this is about the tipping point for what is a "pedal assist bike", and what is a "why pedal type bike".
This graph probably highlights the change in performance the best. It shows the output power for the motor at various voltages 48, 60 & 72 (solid lines), as well as the power required to go up various grades of hill. 1%, 5%, 10% & 15% (dotted lines)
x408 - Power Comparison.PNG (33.71 KiB) Viewed 3541 times
For example if you look at where the 1% curve intersects all the power curves, this tells you the typical WOT cruise speed on the flat.
48V = ~40kph
60V = ~48kph
72V = ~56kph
If you do the same for a 10% curve, it tells you how fast you can climb a decent hill.
48V = 22kph
60V = 32kph
72V = 36kph
Or look at a particular speed, 40kph, and see what sort of grade you can maintain 40kph.
48V = 1% grade
60V = 5%
72V = 8%
So at 60V and a bit of peddling I could basically maintain 40kph for my whole commute. Rather than drop down to 30kph on the hills like I currently do.
Sooooooo. The question is: What will it take?
Let's see. Based on http://www.bmsbattery.com prices.
US$66 - 4 more headway cells
US$36 - 20cell, 40amp BMS
US$35 - 240W charger (times two)
Total $172 + shipping
But hell if I am doing that, I might as well go for 72V. :twisted: $5 extra for the BMS, $66 for batteries.
So $242 + shipping.
Just need to repackage things a bit on the bike to fit it all. :?
adrian_sm
Postby Mark_A_W » Thu May 20, 2010 8:08 am
You could just do what I did, and add booster cells, with or without a BMS.
And add a second charger.
Might save some money, and save rewiring your pack for a new BMS.
But it is more hassle.
Umm....where would you put four or EIGHT extra cells? Along the downtube end to end?
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Mark_A_W
Postby adrian_sm » Thu May 20, 2010 8:20 am
Mark_A_W wrote:You could just do what I did, and add booster cells, with or without a BMS. And add a second charger.
Might save some money, and save rewiring your pack for a new BMS. But it is more hassle.
I love the simplicity of single plug, and walk away charging too much. Don't have to think/worry about it at all.
Mark_A_W wrote:Umm....where would you put four or EIGHT extra cells? Along the downtube end to end?
If you ignore the fact that I have the CA shunt and DC-DC converter in front of the pack (not shown in picture), there is a little bit of room..... maybe.... for 4 cells....
Would have to be more creative for 8 cells. :roll:
adrian_sm
Postby adrian_sm » Thu May 20, 2010 8:27 am
Actually, It might just be cheaper and easier to change motors.
For example if I dropped your motor, in my bike at 48V, the specs look very similar to a 408 @ 60V.
x408 vs MAC.PNG (40.69 KiB) Viewed 3538 times
I am pretty keen to see how the faster wind BPM that full_throttle is getting performs. As I prefer the construction of the internals over the dramas you have had.
adrian_sm
Postby adrian_sm » Thu May 27, 2010 8:17 am
Made a soft enclosure for the batteries. Mainly to keep the water out, and make it look a bit better.
I'll add some bash plates underneath in case I drop the bike.
Anyway here is how it turned out.
adrian_sm
Postby torker » Thu May 27, 2010 9:43 am
I like the simple cover. How did you close it up? Velcro?
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
torker
Postby grindz145 » Thu May 27, 2010 11:39 am
Very well done, nice and clean.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby adrian_sm » Thu May 27, 2010 12:55 pm
torker wrote:I like the simple cover. How did you close it up? Velcro?
Thanks. Yep velcro. Allows me to stretch and adjust the fabric for a nice snug fit.
The cover drapes over the top tube, then has the velcro under the down tube, infront of, above and below the controller. And finally behind the battery in font of the shock.
I also left the fabric longer at the front so it can wrap around the steering tube, and velcro close right at the front if needed. This will have less of a gap to let water in, but is a bit more of an issue for all the control cables to enter. This has just been left undone, folded back on itself and tucked in so you can't see it in the photo. Might just leave it like this if it proves water proof enough. Will have to wait and see.
grindz145 wrote:Very well done, nice and clean.
Thanks for the kind words. I just had look through your build log and I like the way you mounted your bb7s. I might just have to steal that idea and see if it helps me squeeze my 203 disc onto my rear hub. Cheers.
grindz145 wrote:Image
adrian_sm
Postby adrian_sm » Wed Jul 07, 2010 10:36 pm
Time for an update.
I didn't maange to fit a disc brake on the rear end, due to a few clearence issues.
So I decided to try out regen braking, to see if that would help. I also wanted to neaten up the bike a bit so I decided to hook myself up with a 6x4110 Lyen special Mini Monster After a lot of reterminating cables, and repackaging things on the bike here is how it turned out.
Found the controller yet?
How about this angle?
The controller is actually narrower than my battery pack, so I now have the batteries sitting on top of the controller.
Worked out pretty well I think.
So I no longer have a huge 12x4310 Crystalyte controller hanging off the down tube. Makes for a much cleaner look IMHO.
Regen braking appears to be working pretty well. Easy to use to slow down for lights etc. But it is a on/off affair. So definitely not a substitue for real brakes. But my 203mm Avid BB7's upfront can take care of the rest. All in all pretty happy.
- Adrian
adrian_sm
Postby adrian_sm » Wed Jul 07, 2010 10:39 pm
For those interested in the battery cover here are a few more pics. I need to adjust it a bit now that it isn't hiding a bundle of cables down near the bottom bracket.
- Adrian
adrian_sm
Postby adrian_sm » Wed Jul 07, 2010 10:50 pm
Finally thought I would show what is happening up on the handle bars.
Notice the left brake lever has no cable, as I don't have rear brakes. Just regen.
I made a custom mount for the CA, as I was sick of the wobbly original mount. Especially since I put a switch on the front to turn my lights on and off (including the CA backlight). The mounts are from some DealExtreme gun sight mounts, that just happened to be the right internal diameter for my handle bar near the stem.
Finally, I now have the 3 speed switch, so I can put it in go slow mode for when my wife gets on the bike, or I am dragging the kiddy trailer around.
(122.67 KiB) Downloaded 268 times
- Adrian
adrian_sm
Postby adrian_sm » Mon Jul 12, 2010 12:32 am
Maybe it's just because I have never been able to do this before, but I find it pretty cool to be able to hook a laptop up to the bike, and reprogamme it.
I am sure the novelty and usefullness will quickly fade.
- Adrian
adrian_sm
Postby grindz145 » Thu Jul 22, 2010 2:57 pm
adrian_sm wrote:Maybe it's just because I have never been able to do this before, but I find it pretty cool to be able to hook a laptop up to the bike, and reprogamme it.
- Adrian
Once you get everything set up properly It will fade, but it is nice to have to begin with!
grindz145
Postby adrian_sm » Fri Aug 06, 2010 7:06 am
Okay. Got bored browsed the hobbycity site, and ended up buying a couple of these Turnigy 5000mAh 6S 20C Lipo Pack:
Plan is to use these as a 6s 10Ah LiPo booster pack with my current 16s 10Ah LiFePo4 pack.
While I wait for them to arrive, I amused myself with a quick play with Justin's simulator. Amazing what a little extra voltage will do for the bike.
This graph shows the power of the old set-up, versus the new, still @ 30Amp limit on the controller.
The curves going up from the bottom left are the power required to go various speeds on the flat, and up various grades of hill.
So I currently cruise on the flat at 40kph, and go up most hills on my route @ 30kph.
Now I should be able to cruise @ 55-60kph, and go up the hills @ 40-45kph. 8)
408 - 16s Lifepo4 + 6s LiPo.jpg (64.55 KiB) Viewed 1251 times
adrian_sm
Postby bandaro » Mon Aug 16, 2010 9:15 am
so hows the extra booster cells going? running it at the higher voltage yet, and is it much faster?
i like how the shirt turned out, seems a nice neat breathable way to conceal everything. how wide is the battery pack now? do you ever hit them while pedaling? im wondering how wide my build can go....
bandaro
Postby AussieJester » Mon Aug 16, 2010 9:22 am
Hasn't for me i always download the data logging from my Castel Creations hv160 since i got the cable, like to see how everything is working, i think we may get more data than you guys get from the Infineons though? ...e.g-->
(104.1 KiB) Downloaded 3 times
KiM
AussieJester
Postby adrian_sm » Mon Aug 16, 2010 11:00 am
bandaro wrote:so hows the extra booster cells going? running it at the higher voltage yet, and is it much faster?
Just got the package on Friday, only jut been able to play with it in the last few hours.
So far I have modded the controller R1 resistor, so I don't blow the LM317 with the higher volts.
(Not sure if I need to mod R12 aswell, Lyen assures me it is fine, but an EE mate thinks I might be sending a few too many volts to the uController)
Reterminated my new batteries with andersons.
Made up all the wiring harnesses I need. (Parallel adapter, series adapter)
Just charging up the batteries now.
With any luck I'll having it ready for the ride to work tomorrow. It will be a tape the batteries on to the frame set-up for this test run, as I won't ahve time to do it properly.
Fingers crossed.
As for the battery with, I never hit them pedalling. My last build had the batteries in the same place, but with a bulkier cover and I would occasionally brush my calf muscles on them. But this one is fine.
They are the tab welded headways, so the cells are around 120mm long, add another 10mm or so for fabric, and a bit of protective plastic. So ~130mm.
- Adrian
adrian_sm
Postby adrian_sm » Mon Aug 16, 2010 11:02 am
KiM
:D I have had one off those celllog8 things sitting on a shelf. I got it to monitor my cell voltages while I ride, but I have never got around to putting on the balance taps on the headway pack so i can hook it up. Now I ahave the LiPo boosters, I will be able to give it a thrash on that. Should be interesting to see what is happening under load.
No where near the amount of data you are grabbing though.
- Adrian
adrian_sm
Postby Mark_A_W » Mon Aug 16, 2010 5:26 pm
Hey Adrian, what will your total voltage be?
The DC-DC converter is only rated to 72v. Mine works fine at 74 volts, but if you are over 80v.....
Mark_A_W
Postby adrian_sm » Mon Aug 16, 2010 8:15 pm
Mark_A_W wrote:Hey Adrian, what will your total voltage be?
Good call. I realised this last night at about 1 am when I finally got around to looking at the wiring and how I would mount things up.
Final volts are 83.6V hot off the chargers, but settles to ~78V once the surface charge is gone from the LiFePo4's.
I might just give it a run and see what happens. I have a spare DC-DC. :D
- Adrian
adrian_sm
PreviousNext
Who is online
Users browsing this forum: dan974 and 9 guests
