as for me I have quite a few
as for now this is where we are.........waiting for motor and battery
Ian
Spacey wrote:Great bike dude
I bought the 900W Cyclone kit and am running it at 36v on a 15ah Ping battery. Top speed without pedaling on the flat 36mph....which is fast enough.
I have the same problem as you though, to get the gearing on the back cogs right so that the engine is not pulling too many amps (35amp controller, don't think the battery can put out that many amps for very long due to the cut outs I've had when I first road it in 8th gear everywhere)....I have to have it in 5th gear, this gives me around 24mph on average with full throttle no pedalling. It will keep this up for 12 miles without it ever hitting yellow on the battery gauge.
Pedalling though is impossible at this ratio, if I put it in 8th gear on the back cog it's pretty good, I can put in some effort but the motor is labouring somewhat and cuts the BMS.
I was thinking of running two chains from the front drive cogs, but that's not going to work. Do they do a smaller drive cog on the Cyclone, think I'm on 14t but could do with a 10t to 11t to get the ratios better.
Have done over 100 miles so far and is only 6 mins slower than the car on a 12 mile run to work.
Dingo2024 wrote: a few pics from today
deVries wrote:Dingo2024 wrote: a few pics from today
Can you post these as JPGs? Most won't have rar installed to decompress.![]()
Thanks!
cell_man wrote:Hi Ian,
can you please ensure you use a pre charge resistor when powering up the controller. The current inrush might cause a problem with the BMS over time. Low IR cells like these cause a really nasty current spike. Your connectors will appreciate it too.
Dingo2024 wrote:cell_man wrote:Hi Ian,
Hi Paul,
thanks for the headsup; I have gotten into the habit of using the precharge resistor you supplied. There has been no spark on connection of the pack to date so appears to be working as should
Ian
blkbikes wrote:nice bike. Always good to see a fello brit ecommuter.
Time to stealth her up a bit otherwise the big P is going to be asking questions; if they can catch you lol
How much does it weigh?
mhz128 wrote:Dingo,
Nice bike! What's your top speed and mileage?
How is your battery holding up?
ciao!
Users browsing this forum: Cowardlyduck, JamesDub, pendragon8000, Sean9002 and 10 guests
