grindz145
The motivation: to make a hipster-esque bike capable of 40+mph with pedalling.
It's also somewhat of a budget build with $300 being the goal.
I got my friend really hooked on the idea since I'm pimping Ebikes so much, he decided to take the plunge. He wanted what is essentially the anti-hipster, a dark hipster prime if you will, which has come as a singularity to conquer mindless hipsterness abroad :lol:
Components:
9C rear hub 6X10 on a 700c (28"?) wheel- plan to mod Delta-Wye convert -$100 blowout special
Lyen 12 FET infineon -$130 and well worth it
6X 7Ah gruber power lead acid - will run all in series - 72V nominal (this is where the budget really hurts)
$80 plus $40 in shipping.
Total Spent so far: ~$380 - So the budget hasn't worked out so well... performance and affordability are mutually exclusive.
The initial ask is to build for power and top speed only and range is not a concern. I am considering a delta-wye manual transmission (with relays) but we will try a hard-wired Delta-Wye first. It is undoubtedly going too be a ton of strain on the lead, but it saves us a tremendous amount of cash.
Components:
