Sturmey Archer X-FD Brake Drum
Postby MrBoots » Mon Nov 29, 2010 11:06 pm
Because of the impending snow, I swapped out my Avid SD7 front V-brake (w Koolstop thinline pads) in favor of a Sturmey Archer drum brake hub. I originally wanted to run an Avid BB7 front disc brake, but there were too many parts and $ involved in a disc conversion. So far, I've been using the brake drum for two weeks. Stopping power is great, on par with my V-brakes on their best day in the dry and as good as the old Tektro disc brakes on my MTB in the wet. Additionally, the internals are completely sealed from the elements so I'd highly recommend this for all-weather commuter bikes.
Diamondback Insight 1 converted to single-speed Cyclocross
Turnigy 63-74 200Kv outrunner
EVLogix RC Throttelizer
Turnigy Sentilon HV ESC and Wattmeter
7S/16ah LiPo battery pack
11t/110t single-reduction
MrBoots
Re: Sturmey Archer X-FD Brake Drum
Postby MrBoots » Mon Nov 29, 2010 11:14 pm
Oops, I meant to post this in the Testing and Reviews section. If a mod sees this post, can they please move it to the correct section? Thanks!
MrBoots
Postby NeezyDeezy » Wed Dec 29, 2010 8:36 pm
I thought drum brakes didn't provide very good stopping power.
NeezyDeezy
Postby MrBoots » Wed Dec 29, 2010 10:49 pm
A few people told me that too but I don't buy it. Perhaps older drum brakes in the past weren't very good but this Sturmey Archer brake stops as well my old Avid V-brakes did in the dry. In wet and snowy conditions, the V-brakes don't hold a candle to the drum. It did take about a week for the drum brake to "break-in" though. Wet-braking, the drums been very comparable to discs. On top of all that, drum brakes are supposed to be maintenance free because they're sealed - no need to clean dirt and grime like with discs.
MrBoots
Postby blueb0ttle2 » Thu Dec 30, 2010 8:02 pm
How fast are you running? Also, are you using the 70mm or the 90mm (More power) model?
I recently converted to Sturmey Archer 70mm Drum Brakes and am satisfied with their performance. I cruise at 15 MPH (20km), although I am contemplating running at 25 instead :twisted:
"I'm not the smartest fellow in the world, but I can sure pick smart colleagues."
-Franklin D. Roosevelt
blueb0ttle2
Postby MrBoots » Thu Dec 30, 2010 8:49 pm
I'm using just the 70mm model. I normally cruise at around 25-28 mph and even at these speeds, the drum brake feels more than sufficient. I've heard that some folks have issues with fading brakes. This seems to happen during long decents where they brakes are used for extended periods of time or very frequently. I haven't encountered this myself even after vigorous rides with constant stop and go. Drum brakes seem to be pretty popular on pedicabs for their stopping power and all-weather reliability. If it works for a heavy cargo bike, it should work fine for my bike.
MrBoots
Postby docnjoj » Fri Jan 07, 2011 5:50 pm
Greenspeed still uses drums on the fronts of their trikes. I have ridden one and they really stop as good or better than my BB7 discs.
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby MrBoots » Sun Jan 09, 2011 8:41 am
On the few cargo bikes and pedicabs I've seen firsthand, the majority were equipped with drum brakes. I've ridden a 90mm SA drum-brake equipped hybrid and stopping power on that was on part with the best disc brake bikes I've ridden. The only problem for me, was the larger diameter of the drum was problematic when trying to source spokes. So far the biggest pluses are not having to constantly adjust and clean the brakes like I have to with V or disc brakes and no awful screeching noises like my old V-brakes did.
MrBoots
Postby blueb0ttle2 » Mon Jan 10, 2011 11:27 am
It took me a while to get the cable tension on my drum brakes just right. They had the habit of popping out at first. The trick is to make the cable tight. Really tight. It will feel "harder" to pull than a V-brake does, but it will be reliable.
blueb0ttle2
Postby MrBoots » Tue Jan 11, 2011 6:41 pm
So for shits and giggles at work today, I wanted to see how my bike would fare in a head-to-head braking comparison with a fully disc-equipped bike. So my bike commuting buddy at work who owns a Trek Mendota city bike with Avid BB5's agreed to do a roll-then-stop test. We pedaled side by side to about 12mph and then slammed our brakes to see which bike would have the shortest braking distance. Surprisingly, after 4 tries, the braking was just about dead even each time. Mind you, I probably weigh about 20 pounds more than he does and my ebike probably has a good 15 pounds on his with my ebike gear. On top of that, I've only got a V-brake in the back.
MrBoots
Users browsing this forum: Alastor, ronnbot, Sean9002, The fingers and 5 guests
