SlowCo
Re: Your Creation's Before & After Pics
Post by SlowCo » Feb 02, 2017 11:20 am
Beautiful transformation!
Looks much better now. I'll check out your build thread later.
Green Werks
Post by Green Werks » Mar 12, 2017 7:16 am
A gary Fisher with a edge1500w and a programmable sine wave controller 50 amp and a CA
powered by a 52v 24ah 50a continuous and 70 amp burst battery pack
gf edge
es gf.jpg (227.85 KiB) Viewed 3169 times
gf edge
es gf2.jpg (175.02 KiB) Viewed 3169 times
Wolfeman
Post by Wolfeman » Mar 12, 2017 9:27 pm
Green Werks wrote:A gary Fisher with a edge1500w and a programmable sine wave controller 50 amp and a CA
Great looking bike Green Werks. I like your choice of components, simple but with a good amount of power. A Suntour NCX suspension seat post would be about the only thing I'd add. $89 on eBay.
Trek 4300 w/ H3580 Crystalyte at 2300W
https://endless-sphere.com/forums/viewt ... =3&t=82738
Green Werks
Post by Green Werks » Mar 13, 2017 4:33 am
Thank You that bike is a lot of fun
I def would like to get one of those seat post
and the only other up grade that I am going to do is a set of hydraulic disc brakes
Cheers
RollinB
100 µW
100 µW
48v 15Ah
Post by RollinB » Mar 19, 2017 12:53 pm
moderator edit to add: this frame is a "Norco Nation Chopper"
After
After
torker
Post by torker » Mar 19, 2017 4:55 pm
Welcome rollinb Cool bike- looks like the business with a dig directdrive and plenty room for a big batt What specs is it?
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
http://s18.photobucket.com/user/rolinfu ... t=3&page=1
RollinB
100 µW
100 µW
Post by RollinB » Mar 20, 2017 4:22 pm
Thanks torker.
Crystalite hub (35** or 53**,I frgt), infineon 40 amp controller, 12s3p lipo.
40 amp bms. Top speed 60km/h. range 28km-42k, usually the lower-i dont peddle
Built back in 2012. Currently replacing battery with the tesla 18650 cells.
Will be 8p12s.
Is a blast to ride.
torker
Post by torker » Mar 21, 2017 9:08 am
Closest thing I had to that was a tour easy clone I built and powered it with a front hub. I built the bike in my avatar a few yrs ago. It is finally going to get some pedals :) and a bottle battery with bms. I ran it on lipos but my son and his buddies puffed a couple those on one ride. So I am turning the amps down (putting the shunt back to stock) and setting it up so my wife can ride it without killing herself...
RollinB
100 µW
100 µW
Post by RollinB » Mar 22, 2017 7:51 pm
The Code hydraulic rear disc brake was a needed upgrade. Have the regen button beside thumb throttle.
I also have the bb7 on the front, with the regen button integrated in mechanical lever.
audioecology
Post by audioecology » Apr 01, 2017 9:32 am
Claud Butler Majecstic (apparently) I picked up off ebay because it had the wide tyres on a retro frame. Fast forward and the bike has carbon MTB forks with 180mm disc brake and a Bafang BBS02 750W built into a cafe racer. 52V 8Ah battery in the satchel. What do you think?
Before
After
After
Janis
10 µW
10 µW
Post by Janis » Apr 04, 2017 1:19 pm
Cyclone 3000w, 18s6p r25 batteries, 60a bluethooth controller.
Battery case is made out of 10 mm aluminium, but side covers are plywood with vinyl sticker.
Rovii
Post by Rovii » Apr 05, 2017 12:32 am
Only a compromise solution
Standard GSXR 1000 with defect gearbox (standing more than one and a half year in the corner)
Only a compromise solution cause I am waiting on bicycle frame now since 14 month
- Fastest speed record 200,49 kph on flat after 740m (175V, 400A)
- Fastest 1/4 mile @ 157,12 kph on flat and 14.468 sec (146V, 600A)
14/34kW QS-Motor 273 80H 7T winding (560A and 1740 turns @ 144V) @ 169kg GSXR 1000 K2
boytitan
Post by boytitan » Apr 05, 2017 9:06 am
smeagol222 wrote:https://endless-sphere.com/forums/viewt ... 12&t=86228
Before you start yelling this is in the wrong place- this one in e-moto/scooter has 1 post. Perhaps this thread should be all EV before & after not just e-bicycles?
https://endless-sphere.com/forums/viewt ... 12&t=83714
The end product is so nice I almost want a scooter lol.
izeman
Post by izeman » Apr 06, 2017 12:18 pm
boytitan wrote:The end product is so nice I almost want a scooter lol.
could you guys please refrain from
a) quoting whole posts
b) commenting in this thread at all, use PM for that
torker
Post by torker » Apr 07, 2017 10:12 am
b) commenting in this thread at all, use PM for that.... Seriously??
ePassionHomebrew
10 µW
10 µW
Post by ePassionHomebrew » Apr 13, 2017 10:44 am
Before, Cannondale Badboy 6 brand new June 2014..
After, ePassion 1000w rear hub motor & Hailong 48v 11.6ah Battery, April 2017..
(239.5 KiB) Downloaded 16 times
ePassionHomebrew
10 µW
10 µW
Post by ePassionHomebrew » Apr 13, 2017 10:50 am
ePassionHomebrew wrote:Before, Cannondale Badboy 6 brand new June 2014..
Can't get my second 'after' pic to show Incline, anybody know why??
spinningmagnets
Post by spinningmagnets » Apr 13, 2017 2:36 pm
The pic might have been slightly too large, and the sites software automatically converts it to a link. I usually resize to approximately 600 X 400 before posting. If that isn't the reason, I don't know why...
smeagol222
Post by smeagol222 » Apr 13, 2017 3:22 pm
I found a really easy way is to use imgur, sharing options have an easy phpBB link with easy thumnail size option to click (it adds before the '.jpg' has a little 'm' for medium, 'l' for large etc).
eg.
Code: Select all
[img]http://i.imgur.com/JyRFJTdm.jpg[/img]
Also if you have a bunch of images (bulk upload to imgur) then you can click the pencil on one image, select them all then select the 'view image info' dropdown-->generate image links. Then select the phpBB option.
First project small E-scooter upgrade 1.5kw/3kw 48v 45a https://endless-sphere.com/forums/viewt ... 12&t=86228
Current project medium E-scooter upgrade 4kw/7kw 72v 90a https://endless-sphere.com/forums/viewt ... 10&t=85164
Eskimo
Post by Eskimo » Apr 16, 2017 1:30 am
New paint&smaller rear wheel.
Kevät 2017 004.jpg (122.25 KiB) Viewed 2320 times
Kevät 2017 008.jpg (101.06 KiB) Viewed 2320 times
Member of a 10 000 mile club
http://helsinkiheroes.com/
lio
Post by lio » May 06, 2017 1:25 am
Before:
Home made aluminium frame (15 years ago :shock: )
After:
Motor: car alternator 120A
Controller: 48V 1500W
Batt: Lipo 4x4S 16Ah (68V)
Speed : 70Km/h (44mph)
Power max: 3200 W
9 speeds
Gear reduction: 5.6
Weight: 23 Kg
Video on the road https://www.youtube.com/watch?v=pJXladJ ... e=youtu.be
lester12483
Post by lester12483 » May 14, 2017 9:31 pm
Careful not to get zapped with all those lose wires.
MT6 Hybrid- Electric Bicycle 48V
48V 13AH AllCell Lithium Manganese Battery Pack
http://www.chicagoelectricbicycles.com
negativepitch
Post by negativepitch » May 15, 2017 1:12 am
Before:
Specialzed Rockhopper Comp
After:
Swapped out offroad tires for Maxxis Hookworm 29" street tires
Swapped out the original hard saddel for the more comfortable Planet Bike Men's A.R.S.
Added a Topeak MTX to carry my work clothes and laptop
Added BBSHD with 20ah battery from lunacycle.com
This is my first ebike build and despite it being quite a bit more challenging than I'd anticipated, the long nights were absolutely worth it because this thing is a blast. I plan to use it for daily commuting 40 miles round-trip to work with some pretty steep hills.
Wolfeman
Post by Wolfeman » May 15, 2017 8:48 am
Great looking bike negative pitch. Looks clean, fast and very fun.
zerodebikes
Zerode Tangent
Post by zerodebikes » May 17, 2017 4:15 am
Tangent ascent inboard where the gearbox usually goes.. super fun!
