Re: Your Creation's Before & After Pics
Postby kmxtornado » Sun Nov 20, 2011 9:15 pm
Looking forward to it. That's a helluva rear wheel you got there.
- My very first e-bike conversion ever: http://endless-sphere.com/forums/viewtopic.php?f=3&t=32668&p=474570#p474570
- Build Blog (more detailed than the above thread): http://e-bikeconversion.blogspot.com/ (20mph)
- Ultra mini folding bike upgrade (in-progress): http://endless-sphere.com/forums/viewtopic.php?f=3&t=33471 (12mph > 18mph)
- Recumbent Tadpole Trike completed Aids Life Cycle ride from SF to LA: http://kmxtornado.blogspot.com (27mph flats)
- Catrike Speed (in process)
kmxtornado
Postby sangesf » Sun Nov 20, 2011 9:44 pm
kmxtornado wrote:Looking forward to it. That's a helluva rear wheel you got there.
Here's a better pic of it...
And if you think the rear wheel is something, you should see the (old) front "cockpit"...
sangesf
Postby gtadmin » Thu Nov 24, 2011 9:04 pm
GT's Curious Custom
Edit: No before shots because there was no "before" bike!
gtadmin
Postby AussieJester » Thu Nov 24, 2011 9:07 pm
Turned out very nice there GT... been hooning around on it yet? Shall have to check your
worklog thread for more pics!
As usual, the pic of the bike on its own makes it look HUGE, when in reality with you sitting on it it's really
quite small...
^^ Pic from GTAdMiNS worklog For those that haven't seen it i suggest you chek it out, good read of a well documented build!
ToP JoB mate!
KiM
AussieJester
Postby gtadmin » Fri Nov 25, 2011 3:54 am
Thanks for the wrap AJ 8) Have had a few laps around the block to test the settings etc, but no full ride yet. I'll update the work log rather than cluttering this thread :wink:
gtadmin
Postby ohzee » Sat Nov 26, 2011 11:29 am
I don't have any before pics , but here is my bike in it's current form with the newly acquired HT3525 18s4p
currently no mods looking for a temp probe now. Lyen modified 12Fet controller, Doc torq plates - high power
motorcycle led lights each running off it's own wall wart 12v 3amp and 16v 3 amp - one magicshine for right
in front of the tire.
I am very happy with the bike and even at 30mph she seems pretty stable.
ohzee
Postby sangesf » Sat Nov 26, 2011 4:35 pm
Here is a quick vid of the basic workings of my bike...
Any questions, just ask...
P.S. The audio is low because my iPhone sucks.. LOL
sangesf
Postby hillzofvalp » Sat Nov 26, 2011 4:39 pm
Just wonderful. Did you use a couple blinker plugs from the auto parts store?
hillzofvalp
Postby sangesf » Sat Nov 26, 2011 6:34 pm
hillzofvalp wrote:Just wonderful. Did you use a couple blinker plugs from the auto parts store?
I used a blinker relay (electro-mechanical) from an auto parts store.
with that specific type, you NEED at least one non-led type bulb (re: Incandescent-halogen, xenon, etc) for the blinking function to work.. (if you only hook up LEDs, it doesn't have enough power to blink).
I haven't tried a pure electronic blinker relay type as I've always used one form or another of incandescent bulb for my front headlight and blinkers. (LEDs just don't seem bright enough for me.. Or at least not as bright as a 100w Halogen or Xenon.). I'm guessing that the electronic relays will work with either incandescent or LED, but I'm not sure.
sangesf
Postby hillzofvalp » Sat Nov 26, 2011 8:31 pm
the one you have should work with leds.. just need a resistor
hillzofvalp
Postby sangesf » Sat Nov 26, 2011 10:17 pm
hillzofvalp wrote:the one you have should work with leds.. just need a resistor
Don't need one anyways.. I don't really like LEDs for front lights, like I said. ;)
sangesf
Postby amberwolf » Thu Dec 01, 2011 12:59 am
The lighting discussion that branched off from the above has been moved to it's own thread here:
viewtopic.php?f=3&t=34278
at the request of multiple members.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby docnjoj » Thu Dec 01, 2011 4:32 pm
Hey GTadmin!
That is one classy piece fo work! Really quite professional. I wish I could still ride 2 wheels!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby gtadmin » Sun Dec 04, 2011 6:18 am
docnjoj wrote:Hey GTadmin!
otherDoc
Hey doc, thanks mate. 3 wheels are better than 4 though :D
GT
gtadmin
Postby moviles2 » Sun Dec 04, 2011 7:15 pm
9c at 27 amp with 48v 10ah lifepo4
moviles2
100 µW
100 µW
Postby Dreddydave » Sat Dec 10, 2011 2:37 am
Sorry, no before pic but the build thread is here: viewtopic.php?f=6&t=34039
Dreddydave
Postby AussieJester » Sat Dec 10, 2011 2:51 am
Dreddydave wrote:Sorry, no before pic but the build thread is here: viewtopic.php?f=6&t=34039
Slick work there Dave? is it? Recently knew Aussie has joined the ranks WooTz
well done anywayz matey... Only thing i might suggest? is flipping the controller
to the top of the battery box, still down low near the BB just on top not underneath
i would be a little concerned about debri/water flicking off the tires and onto the controller...
KiM
AussieJester
Postby Dreddydave » Mon Dec 19, 2011 5:53 am
Thanks Kim; sorry for the late reply! I'll see how it goes down there, I like having the controller partially hidden behind the crank. Also, it's only a road bike for those sunny weather days so should stay relatively dry & clean. Worst case scenario, a new $30 controller and lesson learnt!
Dreddydave
Postby iperov » Sun Jan 01, 2012 5:35 am
winter christmass moding...
Sorry, bad english!
iperov
Postby amberwolf » Sun Jan 01, 2012 1:36 pm
I love EL wire. :) Just don't leave it in the sun; it'll change output color and fade. :(
amberwolf
Postby StudEbiker » Mon Jan 09, 2012 6:55 pm
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby iperov » Sun Jan 15, 2012 7:53 am
Sorry, bad english!
iperov
Postby t44florida » Tue Jan 17, 2012 5:35 pm
deleted
t44florida
Postby SamTexas » Tue Jan 17, 2012 5:40 pm
t44florida wrote:
Second picture: Is your rear rack designed to move with the rear suspension?
SamTexas
Postby wineboyrider » Tue Jan 17, 2012 5:47 pm
My only concern t4florida is the controller will get too hot eventually???? It needs to breathe. 8) 8)
wineboyrider
PreviousNext
Who is online
Users browsing this forum: Majestic-12 [Bot], sal_park, Samd and 20 guests
