Re: Your Creation's Before & After Pics
Postby Dreddydave » Sat Dec 10, 2011 2:37 am
Sorry, no before pic but the build thread is here: viewtopic.php?f=6&t=34039
Dreddydave
Postby AussieJester » Sat Dec 10, 2011 2:51 am
Dreddydave wrote:Sorry, no before pic but the build thread is here: viewtopic.php?f=6&t=34039
Slick work there Dave? is it? Recently knew Aussie has joined the ranks WooTz
well done anywayz matey... Only thing i might suggest? is flipping the controller
to the top of the battery box, still down low near the BB just on top not underneath
i would be a little concerned about debri/water flicking off the tires and onto the controller...
KiM
AussieJester
Postby Dreddydave » Mon Dec 19, 2011 5:53 am
Thanks Kim; sorry for the late reply! I'll see how it goes down there, I like having the controller partially hidden behind the crank. Also, it's only a road bike for those sunny weather days so should stay relatively dry & clean. Worst case scenario, a new $30 controller and lesson learnt!
Dreddydave
Postby iperov » Sun Jan 01, 2012 5:35 am
winter christmass moding...
Sorry, bad english!
iperov
Postby amberwolf » Sun Jan 01, 2012 1:36 pm
I love EL wire. :) Just don't leave it in the sun; it'll change output color and fade. :(
amberwolf
Postby StudEbiker » Mon Jan 09, 2012 6:55 pm
StudEbiker
Postby iperov » Sun Jan 15, 2012 7:53 am
Sorry, bad english!
iperov
Postby t44florida » Tue Jan 17, 2012 5:35 pm
deleted
t44florida
Postby SamTexas » Tue Jan 17, 2012 5:40 pm
t44florida wrote:
Second picture: Is your rear rack designed to move with the rear suspension?
SamTexas
1 GW
1 GW
Postby wineboyrider » Tue Jan 17, 2012 5:47 pm
My only concern t4florida is the controller will get too hot eventually???? It needs to breathe. 8) 8)
wineboyrider
Postby t44florida » Tue Jan 17, 2012 9:06 pm
deleted
t44florida
Postby sangesf » Tue Jan 17, 2012 9:24 pm
Especially in the summer heat, that controller is gonna melt thr ping pack in that black plastic case
Is that for you or your son?
How fast does she get up to? Controller info?
sangesf
Postby t44florida » Tue Jan 17, 2012 10:25 pm
deleted
t44florida
Postby t44florida » Tue Jan 17, 2012 10:28 pm
deleted
t44florida
Postby wineboyrider » Tue Jan 17, 2012 10:32 pm
t44florida wrote:
wineboyrider wrote:My only concern t4florida is the controller will get too hot eventually???? It needs to breathe. 8) 8)
Am thinking on that... just trying to geter done for time being. Aluminum heat sink plate beneath? PC fan in box cool it enough? Perhaps vent in box with PC fan?
Evoforce had one of his flaps open where he stored his controller at the Death Race? Holes would suffice and perhaps white color?
:D
wineboyrider
Postby t44florida » Tue Jan 17, 2012 10:51 pm
deleted
t44florida
Postby SamTexas » Tue Jan 17, 2012 11:14 pm
t44florida wrote:Yes sam... it floats up and down at the seat arms.
Great. Do you have a picture of the rack's pivot point?
SamTexas
1 GW
1 GW
Postby boppinbob » Wed Jan 18, 2012 5:35 am
before
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Postby Golden Motor Canada » Wed Jan 18, 2012 10:12 am
Before
Townie 8 Speed with internal cabling. The cables run inside the frame for part of thier run.
After Conversion.
Added two Internal Magic Pie 3 Motors, a rack with three batteries, lights and a Cycle Analyst. I Built this bike once with my first two pre-release MP3 Motors. It was a quick build with little effort to keep the "clean look".
Then I completly stripped it when I received my second set of MP3 pre-release motors. Since the wiring harness has changed nothing is compatible with the frist two motors so everything had to be replaced, motors, levers, buttons, trottle, etc.
This time I took alot of care to give it as clean of a look as possible. I routed all the wires through the frame along side or the original cableling.
I think it turned out pretty good and I absolutly love it!
After looking at that last picture of my bike I can see I should level the battery rack as it was before. I think it looks better that way.
Gary
Have you seen the new Magic Pie 5!
Gary Salo
Golden Motor Canada
Check out my iOS APP Android APP
Have a look at My Ebikes Here
Have a warranty issue with GM Canada? Click Here
Golden Motor Canada
Postby veloman » Wed Jan 18, 2012 12:13 pm
No rear torque arms on an alum frame with Magic Pie? :?:
Hubs for sale: viewtopic.php?f=9&t=63121
LiCo batteries for sale: viewtopic.php?f=9&t=70579
Mush! Mush you electrons! Push harder!
Moped build: viewtopic.php?f=12&t=60209
Small motorcycle build: viewtopic.php?f=10&t=51259&hilit=+ke100
Main ride: Old School Specialized Stumpjumper FSR, Yescomusa rear DD, 77v lifepo4, 12fet Infineon set to 26amps.
veloman
1 GW
1 GW
Postby sangesf » Wed Jan 18, 2012 1:28 pm
As usual.. Pretty sweet..
How much would the average Joe have to invest in all that?
Below or above $2000?
sangesf
Postby jpgey » Wed Jan 18, 2012 2:44 pm
Very nice !
How did you manage throttle ? One throttle connected in parallel to both controller ? And did you manage power balancing front/rear ?
jpgey
Postby Golden Motor Canada » Wed Jan 18, 2012 2:49 pm
veloman wrote:No rear torque arms on an alum frame with Magic Pie? :?:
I dont think they are nessasary. I did put rear one on a few other bikes that did not have such a good mounting surface but this bike seems fine.
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby Golden Motor Canada » Wed Jan 18, 2012 2:58 pm
sangesf wrote:As usual.. Pretty sweet..
Retail...Roughly..
2 x mp3 = 800
3 x battery = 1425
Rack 30
Cycle analyst 150
Bike 800
Lights 30
Plus taxes is over 3500, Ouch :) Its a long way from a 3 or 4 hundred dollar kit!
But in my mind since I represent Golden Motor I think I deserve the best they have :)
I have the wife convinced I built it to sell it, but that's a laugh! would you sell it? Good thing she doesn't read ebike forums :)
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby Golden Motor Canada » Wed Jan 18, 2012 3:16 pm
jpgey wrote:Very nice !
I spliced the two wire harnesses from the motors into one. Here is a video from when I did it the first time..
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
PreviousNext
Who is online
Users browsing this forum: boisrondevens and 7 guests
