Re: Your Creation's Before & After Pics
Postby t44florida » Tue Jan 17, 2012 10:51 pm
deleted
t44florida
Postby SamTexas » Tue Jan 17, 2012 11:14 pm
t44florida wrote:Yes sam... it floats up and down at the seat arms.
Great. Do you have a picture of the rack's pivot point?
SamTexas
Postby boppinbob » Wed Jan 18, 2012 5:35 am
before
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Postby Golden Motor Canada » Wed Jan 18, 2012 10:12 am
Before
Townie 8 Speed with internal cabling. The cables run inside the frame for part of thier run.
After Conversion.
Added two Internal Magic Pie 3 Motors, a rack with three batteries, lights and a Cycle Analyst. I Built this bike once with my first two pre-release MP3 Motors. It was a quick build with little effort to keep the "clean look".
Then I completly stripped it when I received my second set of MP3 pre-release motors. Since the wiring harness has changed nothing is compatible with the frist two motors so everything had to be replaced, motors, levers, buttons, trottle, etc.
This time I took alot of care to give it as clean of a look as possible. I routed all the wires through the frame along side or the original cableling.
I think it turned out pretty good and I absolutly love it!
After looking at that last picture of my bike I can see I should level the battery rack as it was before. I think it looks better that way.
Gary
Victoria Day Sale on now! Click here to Save 100 on Any kit and Any battery combined
Gary Salo
Golden Motor Canada
The world is going green with Golden Motor Canada
Have a look at My Ebikes Here
Have a warranty issue with GM Canada? Click Here
Golden Motor Canada
Postby veloman » Wed Jan 18, 2012 12:13 pm
No rear torque arms on an alum frame with Magic Pie? :?:
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby sangesf » Wed Jan 18, 2012 1:28 pm
As usual.. Pretty sweet..
How much would the average Joe have to invest in all that?
Below or above $2000?
sangesf
Postby jpgey » Wed Jan 18, 2012 2:44 pm
Very nice !
How did you manage throttle ? One throttle connected in parallel to both controller ? And did you manage power balancing front/rear ?
jpgey
Postby Golden Motor Canada » Wed Jan 18, 2012 2:49 pm
veloman wrote:No rear torque arms on an alum frame with Magic Pie? :?:
I dont think they are nessasary. I did put rear one on a few other bikes that did not have such a good mounting surface but this bike seems fine.
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby Golden Motor Canada » Wed Jan 18, 2012 2:58 pm
sangesf wrote:As usual.. Pretty sweet..
Retail...Roughly..
2 x mp3 = 800
3 x battery = 1425
Rack 30
Cycle analyst 150
Bike 800
Lights 30
Plus taxes is over 3500, Ouch :) Its a long way from a 3 or 4 hundred dollar kit!
But in my mind since I represent Golden Motor I think I deserve the best they have :)
I have the wife convinced I built it to sell it, but that's a laugh! would you sell it? Good thing she doesn't read ebike forums :)
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby Golden Motor Canada » Wed Jan 18, 2012 3:16 pm
jpgey wrote:Very nice !
I spliced the two wire harnesses from the motors into one. Here is a video from when I did it the first time..
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby jpgey » Wed Jan 18, 2012 3:51 pm
Thank's, and do you have already technical spec for MP3 pre-release motors ?
jpgey
Postby hillzofvalp » Wed Jan 18, 2012 6:48 pm
How did u regen 45A?
hillzofvalp
Postby Golden Motor Canada » Wed Jan 18, 2012 7:06 pm
jpgey wrote:Thank's, and do you have already technical spec for MP3 pre-release motors ?
Is is unlikely there will ever be any tech sheets other then what was on the original release posters. I have learned to expect no ducumentation or technical drawings.
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby Golden Motor Canada » Wed Jan 18, 2012 7:07 pm
hillzofvalp wrote:How did u regen 45A?
I have both motors on 100 percent regen as their are still no usb cables available to turn it down. So when rolling along full steam and you just touch the brake levers that what you get.
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby itselectric » Sat Jan 21, 2012 11:38 am
Gary
Have you tried to fully charged your batteries and regen 45amp and see what will happen? Warning this experiment may cause problem if the controller doesn't know when to shut down the regen.
itselectric
Postby hillzofvalp » Sun Jan 22, 2012 12:22 am
Lol you would have to turn on your bike on a hill to do that test... After 20 seconds of riding you can't really over volt the pack by regenning, at least on a practical basis.
hillzofvalp
Postby migueralliart » Mon Jan 30, 2012 9:47 pm
Before
after
migueralliart
Postby Ossielocal » Sun Feb 05, 2012 3:47 am
Hi guys , this is my second build and on this one i used a Ezee 400watt kit with a ping 48v 10ah Battery .
Mainly use this bike for work ..Still needs a on off switch .And i'm not sure about the range on the battery ..but it should be good for 14ks .
Ossielocal
Postby gm6046 » Sun Feb 05, 2012 5:12 am
Ossielocal wrote:Hi guys , this is my second build and on this one i used a Ezee 400watt kit with a ping 48v 10ah Battery .
Looks good, what was your first build?
gm6046
Postby lostrack » Sun Feb 05, 2012 11:10 am
More of a Before and During... but here we go!
Didnt end up using the box....
Enjoy!
Build thread on the non hub forum...
lostrack
Postby iperov » Sun Feb 05, 2012 1:55 pm
Sorry, bad english!
iperov
Postby lester12483 » Fri Feb 10, 2012 9:07 am
Specifications:
750 watt MAX brushless hub motor
Top speed 30 mph
Battery range up to 20-30 miles MAX on a charge
48 Volt 13 Amp Hour (LiNMC) AllCell Lithium battery (1000+ charges life cycle)
2.5A battery charger included 110/240 volt outlet capable
Battery charging time is 4 hours, empty-full
Cycle computer included
26 x 2.125 inch standard white wall tires
Custom grips
Front head light included
Bike weight with battery: 65 lbs
Maximum rider weight - 250 lbs
MT6 Hybrid- Electric Bicycle 48V
48V 13AH AllCell Lithium Manganese Battery
http://www.chicagoelectricbicycles.com
lester12483
Postby rui_fujino » Fri Feb 10, 2012 11:44 pm
Diamondback S:10 FS
Original Bike
Ebike 2.0
Conhismotor 48v 1000w
LiFePo4 52v hot
FSA XC282 Handlebar
Suntour M2000 Fork (original)
750lb coil rear suspension (original)
Tektro v brake (original)
Truvativ iSoflow Chainset 52/42/30T
Shimano 11-28T freewheel
Ebike 2.0 (28mph)
Ebike 3.0
CA-DP ver2.3
HS3540 (MethTek)
Lyen 12fet Controller
FalconEV bag
20s2p(83vhot) Lipo
FSA XC282 Handlebar
RockShox Dirt3 Fork
Manitou Swinger 3-way air suspension
Avid bb7 Disc Brakes
Specialized Armadillo Crosslands tire 1.95x26(anti-puncture)
Custom rear brake light
Ebike 3.0 (44.5mph)
20s2p lipo
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Postby Ossielocal » Mon Feb 13, 2012 3:40 am
Gday gm6046 ,
My first go at an ebike was the same bike just a different kit ..it was one of these kits http://www.cyclone-usa.com/ It was alright but got a little warm and blow fuses all the time bit of a pain in the arse . This Ezee kit is pretty good i must say on the flate i get up too 40km/h which is a good enough speed for me .My old kit only manage an average 30km/h if i went to a higher gear she would blow a fuse .
Ossielocal
Postby motornews » Thu Mar 15, 2012 4:02 pm
48v 1500w 12ah
49klm speed
40klm range
motornews
PreviousNext
Who is online
Users browsing this forum: -dg, DAND214, Doctorbass, scphantm, teklektik and 8 guests
