Re: Your Creation's Before & After Pics
Postby Tommy L » Sat May 26, 2012 9:28 am
Build Number 4 :)
We bought this FS bike for my son's 10 birthday 9 years ago. He now drives a VW Jetta diesel.
I asked him if I could ELECTRIFY his bicycle. He smiled and said: "Sure!"
FS Hoolagan Supercycle 26" Mountain bike
9C 2810 DD Hub Motor
89.6v nominal 28S1P Headway 38120HP with 0.25 T6 Aluminum busbars with stock Headway busbars stacked on top :)
C7225 Controller (running at 30amps)
CA-DP V2.23
Twist Throttle 1/2 length
This bike handles very well. Max speed so far is 40mph/64kph and can sustain 34mph/55kph up a grade with headwind :)
The Aluminum frame seems to have good rigidity with triangles in all the right spots and the rear swing arm is steel :)
Steel Swing Arm
C7225 mounted up in the triple tree (triple clamp) for good cooling
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
viewtopic.php?f=4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy L
Postby kmxtornado » Mon May 28, 2012 1:43 am
Dude, that Catrike is awesome! I got a Catrike too, but not electrified. Yours must be fun! Here's a project I'd been working on. My project probably doesn't count since it was electric to begin with, but I've added a few mods today that I thought I'd share with the group.
BEFORE: Sharper Image Razor mini foldable escooter
AFTER: Mods include license plate, rear light, headlight, 24v to 36v system, SLA battery to LiFePo4 battery, variable throttle, bell, water bottle cage mount, folding handlebar mirror, handlebar LED light, and LED strip.
The lights are pure white, but for some reason the camera captures it with a blue hue.
- My very first e-bike conversion ever: http://endless-sphere.com/forums/viewtopic.php?f=3&t=32668&p=474570#p474570
- Build Blog (more detailed than the above thread): http://e-bikeconversion.blogspot.com/ (20mph)
- Ultra mini folding bike upgrade (in-progress): http://endless-sphere.com/forums/viewtopic.php?f=3&t=33471 (12mph > 18mph)
- Recumbent Tadpole Trike completed Aids Life Cycle ride from SF to LA: http://kmxtornado.blogspot.com (27mph flats)
- Catrike Speed (in process)
kmxtornado
Postby amberwolf » Mon May 28, 2012 10:57 pm
This is teh bike I'm using for the Fusin 1000W geared motor review/test.
viewtopic.php?f=4&t=39877
It started as just a Diamondback Coil FS frame from Mdd0127, with a simple rear spring shock (cant' remmeber what damping it has).
Plus an old needs-rebuild Manitou Skareb fork off a frankenbike I got for next to nothing a while back, which I've proposed various uses for but not actually used at all, until now.
This is the first pre-motor test ride configuration.
Then the first motorized variation.
Quickly filled out to "full kit" for commuting to work:
Note that the mirror folds for leaning against things:
Now the "real" motorcycle-class taillight and turn signals/markers are added, in a very quick and dirty job last night. Plus a temporarily-mounted car headlight, because the nicer-looking motorcycle one I'd intended to use was burned out. :( Plus changing to a 26" front so I can use the front rim brakes till I get the disc mount built, then can go to 24" again.
Still quite a ways to go, especially for polish, but I figure the first hundred miles are going to need a LOT of reconfiguration to get it where I want it, so no point in making it pretty yet.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Jason27 » Tue May 29, 2012 12:36 am
I love that recumbent trike.. Great work !!
My ebike:
Diamondback with 800 watt hub motor with AllCell 48V 12AH Lithium Manganese battery pack.
36v hobby king lipo as backup.
"Conquering the hills of SF"
Jason27
Cannondale Hooligan
Postby Venus » Sat Jun 02, 2012 2:31 pm
Nothing too cosmic, but I haven't seen any other Hoolies electrified.
HS3548
Lyen 12 fet
14s3p 15Ah Turnigy 20C
2x ebikes.ca torque arms
DB15 balancing plug
Currently running 45A Bat 110A phase. Bike is very wheelie prone if I don't use the 3 speed switch at low speeds. Tops at 62 kmh on the GPS.
Gets some crazy looks everywhere I go!
Venus
Postby SamTexas » Sat Jun 02, 2012 4:00 pm
Venus, that's a beautiful bike, especially the battery box. How did you make it?
SamTexas
Postby sn0wchyld » Sat Jun 02, 2012 5:56 pm
SamTexas wrote:Venus, that's a beautiful bike, especially the battery box. How did you make it?
+1 looks clean!
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby voicecoils » Sat Jun 02, 2012 9:19 pm
Awesome Venus, I've wanted a Hooligan for a while. Wheelie machine?
You've got the battery weight in a nice spot.
voicecoils
Postby Timma2500 » Tue Jun 05, 2012 12:21 am
Before
After - as of 23/12/2012
Setup is: 2007 Intense M3 frame / 3mm box insert, Fox DHX5.0 shock / Ti spring, 888 RCV Bomber forks, drilled / sensored HT3525 / 10mm thick pinch bolt torque arms, 26" Sun Ringle MTX rims / 2.7" Maxxis Minion DH tyres, Hope M4 brakes, 203mm floating rotors, braided lines, 18fet Cell_man 4110 controller, 20s 10ah Nano lipo, CA / 70a limiting. Weight: 35kg
Paul :D
Last edited by Timma2500 on Sat Dec 22, 2012 11:44 am, edited 1 time in total. View post history.
Intense M3 DH, HT3525 / 5kw, 18fet, 20s 10ah nano lipo
Norco Empire 5, 80100 130kv / 5kw, HV160, 12s 12ah lipo
Under Construction
Timma2500
Postby hillzofvalp » Tue Jun 05, 2012 1:35 am
like
hillzofvalp
Postby Staver76 » Mon Jun 11, 2012 8:08 pm
Before
After
Staver76
Postby peterumba » Mon Jun 11, 2012 9:10 pm
After
My shaft drive Biomega with an ezee motor and 36volt slab lipo on the back rack. Hardest bit was threading the wiring through the toptube. Built in the middle of nowhere on the Welsh borders UK
peterumba
Postby Lessss » Wed Jun 13, 2012 12:39 pm
Trail a bike to pushbike conversion
Batteries to be added as saddlebags
500W motor 48V sensorless controller.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://www.ubuntu.com/
Lessss
Postby nicobie » Wed Jun 13, 2012 1:48 pm
I bet that looks cool with 2 people going down the road :)
How does it handle?
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Kirk » Wed Jun 13, 2012 6:46 pm
Well I've gone as far as I need until the end of riding season for everyone else. This fall she is going to get a Cargo Monster extension from Terra Cycle in Portland, OR http://www.t-cycle.com/CargoMonster.htm That will move the rear wheel back 18 in. and the battery can go on a platform between the chain stays. Which will allow me enough room and carrying capacity to go from 12s6p to a 18s6p battery. It will be a nice stable, fairly fast, reasonably good cargo carrier for touring.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
Postby Suspect » Thu Jun 14, 2012 8:14 pm
24 V, 300 W, planetary reduction of 14.4. It weights about 21 kg with the 12.5 Ah battery.
After:
(216.61 KiB) Downloaded 5 times
Suspect
Postby Lessss » Fri Jun 15, 2012 6:41 am
size matters
pic reposted so it shows
Lessss
Postby JoramsWeapon » Fri Jun 15, 2012 7:19 am
Where did you get that planetary reduction? Can you post a link please it would go handy with my upcoming BMC mid-drive build.
JoramsWeapon
Postby adam333 » Sun Jun 17, 2012 6:41 pm
Before:
DH Norco A-Line Park Edition 2009:
After:
Battery pack weight : 23.4 lbs ([100.8V], 24S, 2P, 30C, 16Ah Lipo) [specific energy 130-200 Wh/kg]: http://www.hobbyking.com/hobbyking/store/__19531__ZIPPY_Flightmax_8000mAh_6S1P_30C_AUS_Warehouse_.html
Bike weight with battery pack : 96.4 lbs
Bike + driver ( me @ 175 lbs ): 271.4 lbs
Max speed according to CA : 88 kph ( 55 mph ) ( Controller is limited at 45 A )
Bike: Norco A Line 2009 Park Edition, Medium frame: http://www.norco.com/archives/2009/?id=48a31c94f3e4f
Motor : Crystalyte HS3540
Controller: Lyen 150V : http://endless-sphere.com/forums/viewtopic.php?f=31&t=18605
Run time : average is roughly 90min @ 35 kph (22 mph). Distance = 50km ( 31 miles )
Charge time : 3hours @ 1/2C ( limited by my power supply ). It will go down to 45min @ 2C once the new charger is built.
Charge cost : 0.20$ / 100km ( 60miles )
Average of 26 WH/km @ 35 kmh (22 mph)
Average of 35 WH/km @ 50 kmh (31 mph)
adam333
1 W
1 W
Postby bachmaninoff » Sun Jun 17, 2012 8:01 pm
Just acquired a BikeE that's about to be electrified. Very comfortable, but I can't believe how not-used-to handling it I am at slow speed! Going fast it seems to be pretty stable though. This will be my year-round commuter for the Pacific Northwest. I'm considering a rear E-BikeKit geared kit. I like the E-BikeKits because they're connections seem to be pretty waterproof, and my E-Mongoose is a testament to that. Sadly, the Mongoose makes my rear end hurt (more-so than work) so it'll have to go. Will be on Craigslist/Ebay (local pickup) after the BikeE becomes the E-BikeE.
bachmaninoff
Postby Suspect » Tue Jun 26, 2012 11:13 am
JoramsWeapon wrote:Where did you get that planetary reduction? Can you post a link please it would go handy with my upcoming BMC mid-drive build.
I picked up the planetary sets from Matex (http://www.matexgears.com/). I made the housing myself. In the next couple of months I may make a few more if you're interested.
This is a 2-stage with 14.4:1 reduction. The ratios and torque limits can be adapted slightly based on Matex's selection. Off hand I can't remember what the input and output torque limits are but these values are on the Matex website.
gearbox, small.jpg (71.12 KiB) Viewed 1712 times
Suspect
Postby saiyan » Wed Jun 27, 2012 12:31 am
before and after picks. mainly after. :D
still 95% complete, after i buy the lipos and mount it in it will be 100%
saiyan
Postby amberwolf » Wed Jun 27, 2012 3:30 am
Suspect wrote:I made the housing myself. In the next couple of months I may make a few more if you're interested.
I have a pair of the ones used in the Currie drives, and have been looking at using them on the end of a small pancake radiator fan motor, runnign that at high speed, then to a chain or belt drive output into the bike's chain drive. I don't have a workable housing for htem yet, though, and yours would probably work perfectly (though I'd need to work out an attachment system to the motor housing).
If you decide to make more of them, let me know the cost--I'm sure it's out of my budget (or lack of one :lol:) but I figure it can't hurt to check. :)
amberwolf
Postby whereswally606 » Wed Jun 27, 2012 5:22 am
Saiyan, love the norco build, going to be doing something very similar with a norco savage and a 80/100 rc motor next year.
regards Andy
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby saiyan » Wed Jun 27, 2012 6:44 am
Thanks mate, if i had to redo i though, id go with a cromotor. Since i built it for work and commuting and around, where i live is pretty flat ground. Im topping out just under 70kph on the ca. Wanted 80-90kph....... :)
All in all im very happy. Popping wheelies in 1st is just a treat i tells ya. :)
Cheerios....
saiyan
PreviousNext
Who is online
Users browsing this forum: Peter Sternersson, Ryanthelion and 8 guests
