* I did 55 miles on this in blowy conditions and started hitting 3.v a cell and took almost the full packs capacity. I guess it did less than I expected as I got tired and the wind slowed me down but still a good range
Iv been googling electric conversions for months and keep finding myself here. I finnally ordered some bits and am now 80 percent through my build. I was adamant that I would not lose my 9 gears and rear disc and wanted a cheap conversion for small commutes and fun. Well I did 30 miles on this the other day to get a before conversion time lol. Nearly 2 bloomin hours.
I have a really fast racing bike too but after a getting knocked off my motorbike at 70mph and went into a car bonnet I cant manage the riding position or saddle,,,ouch. Here is my parts list I used to convert my bike
all prices inc delivery
MY1016 24V motor 19.99 new
350w 24v contoller £11
7kg each 12v 24ah deep cycle lucas gel x2 best offer £48 delivered
Throttle cut down to grip shift size £7
£10 for a 90t minimoto sprocket, £3 for a chain. All that for £100 but I spent around a further £20 on convertings my rare 20mm axle forks to accept quick release wheels, aluminium plates,clamps and bolts etc. Once my forks are back on il take another picture but its looking fairly tidy so far after 2 days build time. I got a 16t freewheel to fit my 54mm holed sprocket perfectly and line up with the bolts like it grew there but didnt want to spend £30 on a cheap wheel with disc mount on one side and screw on the other just incase it didnt fit in my forks. Rear bmx hubs or track hubs (110MM O.L.N) are perfect for any other front forks but not mine as I have super fat legs that rub on the freewheel So for now I settled with no freewheel as my motor draws 9amp hours and I easily have two hours run time plus a backup lithium-ion to keep it spinning, I have left it a direct constantly engaged drive bolted to my disc brake.
Im new to this so one question if anyone is bored enough or knows the answer. My motor barely drags (when I run around the garden with a pair of forks going wooo it works) BUT if the wires to the motor are held together the motor almost jams like someone threw on a brake. If I run out of battery will I need to unplug the motor for any chance of getting home or without blowing my electrics with the power generated. Iv heard people complain that the bikes with hub motors drags bad when your out of battery, could this be an easy way to reduce the drag by simply unplugging it from the controller? I just wondered if anyone has experienced this or whether its just common knowledge that a newbie has not read about yet or that its not a problem once the circuits are powered down/throttle released.
All above has been mandatory but optionals include £50 charger/balancer imax b8, £15 7ah li-ion 12v, £10 indicators, £10 motorcycle generic handlebar switch (horn, lights,indicators and motor kill switch), £15 40w leds 1600 lumens. The charger runs from a 12v source or mains adaptor meaning i can charge at my destination or top the batteries up with 3.5ah each to stop sulphation.
I also got a 9 tooth sprocket to hit the magic 10/1 ratio. I figured that at 20mph 26 inchers wheels do 250rpm x10= 2500rpm at the motor, but due to my massive tyre Im still stuck at around 2000rpm not closer to 2500 as has been sugested is good for a my1016. Untill I find a better wheel il use vbrakes while the disc is otherwise occupied lol. I havnt got this up and running untill I find a batery box so if anyone has some helpful tips or things iv overlooked let me know Cheers for everyone posting on here its inspired many a nights head scratching to pick all my parts so far.
