Re: E-S Stealth Electric Bike Owners
Postby full-throttle » Wed Mar 28, 2012 9:36 pm
Cowardlyduck wrote:Discovered a cool trick the other day
You're better off changing the Aux threshold ;) Leave the Amp limit alone
full-throttle
Postby Cowardlyduck » Wed Mar 28, 2012 9:45 pm
Oh...lol, wondered if there might be an easier way. :oops:
Haven't looked yet, but what values would I set the AUX threshold to? Is it just a simple wat or amp value?
Cowardlyduck
Postby full-throttle » Wed Mar 28, 2012 9:53 pm
Lower whatever value you got there (0.65 for Aus) to increase the limit, if you hit 0 and still want more increase the Amp limit
full-throttle
Postby Kepler » Wed Mar 28, 2012 9:54 pm
What would you know? :P :lol:
Current Rides
Carbon Super Commuter: ON ROAD http://endless-sphere.com/forums/viewtopic.php?f=6&t=47139
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
75 Volt 2.5 kW Stealth Fighter: OFF ROAD http://www.stealthelectricbikes.com/
Kepler
Postby Kepler » Wed Mar 28, 2012 9:58 pm
Cowardlyduck wrote:Discovered a cool trick the other day...thought I would share.
I got my power limit wires on the CA set to 250W at the factory. I've since installed a switch to control this, posted previously in this thread.
I discovered that the power limit was only 250W when the CA max amps was set to 60. If I set the CA to 47 max amps it would limit it to 200W when the power limit button is pressed, which I find useful for very slow conservative cruising for long distance.
Therefore, I assumed the power limit in the CA must only be a percentage of the max amps set. So the other day I tried setting the CA to max amps of 85. This gave me roughly 360W with the power limit button pressed. :D
The battery BMS does the job of limiting the Max amps draw to 60 still. I also tried 99amps and this gives me roughly 420W.
This is HEAPS useful for long distance off road riding. as I can use it in limited mode (at 420W) most of the time, then flick to full power when I need to get up a hill. :D
I would love to get a 3 or 4 mode switch eventually so I can easily flick between power modes, but that's a long way off at this stage as I have other priorities in terms of modding the bike for now.
Anyway, just thought id share. :)
Cheers
Just a minor correction. It would have been the controller's current limit stopping the current going any higher, not the BMS. Its a good point of discussion though and something I am sure will be used by others.
Current Rides
Kepler
Postby full-throttle » Wed Mar 28, 2012 10:05 pm
GrayKard wrote:
QMS wrote:Here is few pics of micro switch controlled re-gen brake setup!
I ride my e-bike in the rain a lot and was using one micro switch for regen and one for cruise. They aren't very waterproof as they both acted up in the first storm. Second storm the regen one gave out and I had to switch it for the cruise (while stopped under an overpass out of the rain). I stopped using them soon after.
You could use a sealed micro switch :!:
full-throttle
Postby QMS » Wed Mar 28, 2012 10:42 pm
Hey Full-throttle! Yes i could, and probably will if i am happy happy with the way it works in the long run!!!!!!!! Found this link!
http://sensing.honeywell.com/products/b ... 025&N=3640
QMS
Postby Hyena » Thu Mar 29, 2012 1:35 am
I have a seperate button on mine that I activate with my thumb, I actually mainly just use it and the front brakes when slowing down and the back brake largely for skidding! It seems to lock up very easy with the knobbies
And hooray for page 100. I'm going to get the mods to delete knoxies posts seeing as he doesn't actually own a stealth :P
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby Cowardlyduck » Thu Mar 29, 2012 2:27 am
Hyena wrote:I have a seperate button on mine that I activate with my thumb, I actually mainly just use it and the front brakes when slowing down and the back brake largely for skidding! It seems to lock up very easy with the knobbies
Yeah, I do the same. I think that button comes standard on new Stealth's now. I really like it, as it allows you to control everything independently.
Cheers
Cowardlyduck
Postby QMS » Thu Mar 29, 2012 2:45 am
Cheers
Hi C D. Yes it is standard on new Stealth's! When riding with gloves on it can be hard to locate the button sometimes. I wanted an automatic activation method. By being auto it also increases the re-gen percentage on an average ride :lol:
QMS
Postby Hyena » Thu Mar 29, 2012 5:43 am
Got a picture QMS ? I have a seperate motorcycle switch cluster on mine. The button I use is normally the horn.
Hyena
Postby QMS » Thu Mar 29, 2012 6:17 am
Hyena wrote:Got a picture QMS ? I have a seperate motorcycle switch cluster on mine. The button I use is normally the horn.
Hi Hyena. See page 98 for my micro switch set up! The Honeywell site also has some great switches and clusters :mrgreen:
QMS
Postby Paul_G » Thu Mar 29, 2012 6:22 am
QMS wrote:
Paul_G wrote:Is there a Bomber owner here thats handy with metal that could make me a battery box for a 2nd battery? My aluminum rack does not last more than 500 miles with an extra 25 lb battery on it. On long trips I run both in parallel.
I was thinking maybe it could mount on the seat post but be below the seat on an angle to get the weight lower as well but it would need to clear the wheels travel. If it cant be made that way a steel stronger rack would do.
I'll "try" to draw a picture :)
If interested please contact me name your price...I'm not looking for cheap....thanks
Hi Paul G. Was looking at your diagram! Definitely doable , the weight on the seat post and clearing the rear wheel travel concerns me a little though. was thinking a steel cornered frame with aluminium side panels with some cut outs for ventilation. Might be able to clear the wheel travel by elongating the enclosure a little. I am able to bolt this assembly together only as i dont have a welder yet! but if i was doing this for myself i would bolt it anyway. If you could supply battery dimensions (H W D) of TWO preferred configerations i will try to come up a design, this will include room for padding seat clamp and wiring exit port. cheers Linc.
Thanks for the offer but I want a Bomber owner as they will need to make sure it clears the wheel travel and I would want it welded steel. Also Bomber battery's don't need cooling holes as that run cool.
Paul G
Paul_G
Postby QMS » Thu Mar 29, 2012 6:32 am
Paul G
Hi Paul G. I AM A STEALTH BOMBER OWNER and the South Australian rep for Stealth Electric Bikes! In my experience the batterys get quite warm when charging! Sorry i couldnt help :cry:
QMS
Postby voicecoils » Thu Mar 29, 2012 6:34 am
Paul_G wrote:Thanks for the offer but I want a Bomber owner as they will need to make sure it clears the wheel travel and I would want it welded steel. Also Bomber battery's don't need cooling holes as that run cool.
Paul G
I think it might be a good idea to get the battery box welded to a steel seatpost itself. It's a lot of mass to have cantilevered off an aluminium/carbon seatpost.
Maybe you should ride out to Enertrac on Long Island with your Bomber Paul and see if they'll fabricate one for you. 30-35miles away from you. They have a really nice workshop and Mark's super enthusiastic about 2 wheeled EVs.
voicecoils
Postby Hyena » Thu Mar 29, 2012 6:35 am
I was referring to the one that comes standard on the new stealths
Hyena
Postby full-throttle » Thu Mar 29, 2012 6:41 am
You can see a photo of it on the North American Stealth site
full-throttle
Postby QMS » Thu Mar 29, 2012 6:43 am
Oh sorry. It is a simple momentary switch on a small bracket mounted on the lower bolt on the left brake lever. It is quite ok , just wanted to fiddle!!!!!! Sorry havnt got a shot at the moment. :( I will post one soon :mrgreen:
QMS
Postby Hyena » Thu Mar 29, 2012 7:05 am
Cool thanks, here's the pic from the stealth usa site for anyone else that's interested. It's quite subtle
stealth regen button.jpg (35.73 KiB) Viewed 324 times
Hyena
Postby QMS » Thu Mar 29, 2012 7:11 am
Hyena wrote:Cool thanks, here's the pic from the stealth usa site for anyone else that's interested. It's quite subtle
Hey Hyena here is a pic of the latest style switch :D
QMS
Postby Paul_G » Thu Mar 29, 2012 7:18 am
Sorry QMS
When you asked for the size of the battery I assumed you didn't have a Bomber.
Paul_G
Postby QMS » Thu Mar 29, 2012 7:29 am
Paul_G wrote:Sorry QMS
I think what Voicecoils wrote is probably the best idea. The seat post is not going to be the best mounting point! also i didnt realize you wanted to mount a full size Stealth LiFePO4 Battery. Your diagram did not faithfully reflect the size!!!!!!!
QMS
Postby Brute » Thu Mar 29, 2012 8:11 am
Cowardlyduck wrote:I would love to get a 3 or 4 mode switch eventually so I can easily flick between power modes, but that's a long way off at this stage as I have other priorities in terms of modding the bike for now.
Cheers
Mines got something similar . It`s called a throttle :lol: :roll:
Brute
Postby ManxE » Thu Mar 29, 2012 9:49 am
Does anyone carry a 'Limp-Home' LiPo pack to get you back without murdering yourself when you've been too throttle-happy on your Bomber rides? Setup recommendations would be apreciated if you have!
PS ... We could really do with a Stealth Bikes wiki to collate all this data.
ManxE
Postby gensem » Thu Mar 29, 2012 10:12 am
What throttle does the bomber/fighter use ?
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
PreviousNext
Who is online
Users browsing this forum: Allex, ggc and 11 guests
