Page 671 of 673
Re: E-S Stealth Electric Bike Owners
Posted: Nov 27 2019 8:41pm
by KarlJ
To anyone running the ANT BT BMS..... thanks to a small miracle they now have an app for iphone in English!
hence can make changes to the settings without questioning the translation or trying to get the software to work on android which was painful
Posted: Nov 28 2019 5:47am
by st35326
KarlJ wrote: ā†‘
Nov 19 2019 5:28pm
which controller do you run now?
I run 22S and charge to max 90V typically even less for commuting 88V ...
dont want to break the stock controller running 92.4V
Sabvoton 72150
My stock controller is in the trash
Posted: Nov 28 2019 5:48am
by st35326
FL bomber wrote: ā†‘
Nov 20 2019 10:38am
What's the easiest way to replace the rivet nuts on battery compartment? Would a small dab of J-B weld work, to stop them from spinning. Also need a few button head bolts.. I know they are M6 but are they fine threaded and what length to order?
st35326... That Excel rim setup looks impressive.
That's a 17in rim.. what size spokes?
19" Excel rim
Posted: Nov 28 2019 5:52am
by st35326
Does anyone have an SKF part numbers for the two non identical bearings inside the Bombers 5304 motor? I've got an old spare I want to rebuild but want to avoid pressing in junk bearings.
Upadte, the proper SFK bearing part number for the 5304 on the Bomber is:
6005-2RSH
6004-2RSH
Posted: Nov 28 2019 9:31am
by Allex
st35326 wrote: ā†‘
Nov 28 2019 5:52am
Does anyone have an SKF part numbers for the two non identical bearings inside the Bombers 5304 motor? Ive got an old spare I want to rebuild but want to avoid pressing in junk bearings.
End of the video
Posted: Dec 01 2019 11:20pm
by KarlJ
should be standard M6 bolts, normal thread pitch and bout 1" long should be fine
Posted: Dec 07 2019 6:11pm
by KarlJ
Long ride plans yesterday ruined by what appears to be poor quality manufacturing and poor design
Seat assembly failure at the two attach points. Bike has 5260kms on the dial as total 2770 of which are mine.
Holes drilled within 1.25d of the edge of the material, bolts too short, no washers used on Allen key (outside) side. Where the material is folded into the square only tack welds at the ends vs fillet two edges and grind back.
Iā€™m hoping despite me not being the first owner that Stealth will repair it. After all this is 100% manufacturing and design flaw, not caused by abuse or misuse.
Posted: Dec 07 2019 8:58pm
by Theodore Voltaire
What year is your bike Karlj? My 2013 has 3 bolts up there, and 2 down at the bottom, 5 total.
I think Stealth has beefed up that support on later bikes.
Posted: Dec 07 2019 9:22pm
Blatant copycat at a light
Posted: Dec 08 2019 11:29am
by litespeed
The nerve of some people! šŸ˜œ
Tom
Posted: Dec 08 2019 5:35pm
by KarlJ
Theodore Voltaire wrote: ā†‘
Dec 07 2019 8:58pm
Funny thing was a mates future Beta had the same failure and its a 3 year old bike :(
Posted: Dec 08 2019 10:54pm
by KarlJ
Winning stealth to the rescue, no hassles and one is in the mail to me today!
The old one will go back for repair.
This is why stealth is a win for me, if I bought a cheap Chinese bike there would be no such joy.
Posted: Dec 09 2019 6:37am
by Cowardlyduck
Yeah a few of us including me had similar failures. While it does suck, Stealth have been good and repaired them all AFAIK.
Cheers
Posted: Dec 09 2019 7:40pm
by Rix
KarlJ wrote: ā†‘
Dec 07 2019 6:11pm
Long ride plans yesterday ruined by what appears to be poor quality manufacturing and poor designF5C811D5-2F60-441F-8004-6F383EDBADA5.jpeg
glad Stealth hooked you up. When I broke mine, Stealth promptly replaced it. Looking at the bottom pic, it looks like one of your cracks is old and has rust on it. Looks like it finally let go over time? Did you notice any cracks before this?
Posted: Dec 09 2019 7:44pm
by Rix
Dec 07 2019 9:22pm
If I was you TV, I would be really mad right now. The audacity!!!! :wink:
Posted: Dec 11 2019 9:47pm
by KarlJ
Rix wrote: ā†‘
Dec 09 2019 7:40pm
KarlJ wrote: ā†‘
Dec 07 2019 6:11pm
I figured out where the squeaking / creaking was coming from i guess that was the crack working its magic, in the process had tightened every bolt on the frame and lubed the rear shock bolts.
Christmas present to self from Wiggle.... Brooks saddle = no more ass hatchet for me Rix :lol:
Next mod streamers from the handlebars!
Posted: Dec 12 2019 6:14am
by Cowardlyduck
After building and enjoying my LMX 64 for a while now it's finally time I focus on rebuilding my Fighter.
All the parts are now ready and I've carbon wrapped my side panels and rear mud guard also.
As a comparison the LMX 64 is much lighter and better at hill climbing than my Fighter, but lacks the range and silence my Fighter has. I might still end up selling my Fighter as the LMX 64 can really do it all that much better and with a spare battery in a backpack can have almost as much range. LMX is also trying to address the noise with a belt drive so I have hope that the 64 might replace my Fighter moving forward.
We'll see though as I still really miss the complete silence of the Fighter (which the LMX will never achieve) and realistically I can't match the full 200km+ range of my Fighter, so I may end up keeping both.
I paid Stealth to replace the rear swing-arm bearings ($20 each), however one of them feels really rough and stiff. I tried installing the rear pivot bolt and it moves easily and feels fine. Does anyone know if those bearings really matter that much and should I bother asking Stealth to replace or it doesn't really matter?
Cheers
Posted: Dec 12 2019 7:17pm
by KarlJ
Cowardlyduck wrote: ā†‘
Dec 12 2019 6:14am
Cheers
only operating through a very narrow range of what 30degrees hence it could be almost ceased and you wouldnt notice it as the lever is huge.
put the bike back together!
Posted: Dec 12 2019 8:06pm
by sn0wchyld
Nov 20 2019 10:38am
drill them out and re-apply... a rivnut gun can be had for ~$30 for a 'good enough' one, and would hold better than a JB job (ask me how i know ;) )
Just standard stainless button heads should be fine, pitch isn't anything special (metric, 0.5 at a guess? my off the shelf m6 bolts fit fine, 10mm long)
Posted: Dec 12 2019 8:42pm
by KarlJ
Much better!
3 bolts improves the load sharing and welds all the way way along the joins.
Winning!
Posted: Dec 13 2019 1:39am
by st35326
Dec 12 2019 6:14am
Cheers
28 MPH top speed and sounds like a 10 horsepower zipper, with less range?? I'm good. I wish you luck with your sale though. If I went mid-drive it would probably be the Sur-Ron, as it carries a lot of speed and climbing ability at a bargain price.
Posted: Dec 13 2019 4:40am
by Cowardlyduck
KarlJ wrote: ā†‘
Dec 12 2019 7:17pm
Yeah I had a similar thought and think your right. Screw stuffing around getting it replaced as I don't know if I would even be able to get it out.
st35326 wrote: ā†‘
Dec 13 2019 1:39am
Yeah if you just get the stock off-the-shelf option sure. As for me I've built my own battery, tweaked the controller and will switch over to belt drive at some point so pretty much negating all those problems.
The biggest problem I have with my Fighter is the weight. I like to go bush riding and have to lift my bike over locked gates and barbed wire fences. I do occasionally manage it with the Fighter, but it's always a huge struggle and I've had my fair share of mishaps as a result.
On the other hand the LMX 64 is the perfect balance of weight, power and range to be able to go riding through rugged off-trail adventures and not worry about coming across a locked gate or fence line you weren't expecting.
Realistically it's not an Apples to Apples comparison though...the LMX 64 and Stealth Bomber/Fighter are totally different beasts. Which is why I might just end up keeping both. :D
Cheers
Posted: Dec 13 2019 12:21pm
Dec 13 2019 4:40am
Cheers
I can relate with this. Even for my kind of street riding I need more than one bike. I've always said there's, no one perfect bike.
Posted: Dec 16 2019 7:57pm
by KarlJ
Dec 13 2019 12:21pm
Dec 13 2019 4:40am
Cheers
You buying a bomber then too :lol:
Posted: Dec 17 2019 2:45am
by Cowardlyduck
KarlJ wrote: ā†‘
Dec 16 2019 7:57pm
With a Fighter that does 6KW, can go 85kph (with overspeed), only weighs 35Kg, has 7 pedalling gears and has 200km+ range...why would I want a heavier, slower, lower range Bomber. :P
Cheers
