Theodore Voltaire   1 MW
Re: E-S Stealth Electric Bike Owners
Post by Theodore Voltaire » Dec 20 2019 12:58pm
Stealth bikes are over engineered enough that you can enhance their performance to a certain degree with little concern of a catastrophic equipment failure. A Bomber sits at the top of the line, and can handle performance enhancement beyond the ability of any other model.
Post by Theodore Voltaire » Dec 21 2019 10:32pm
Rix   100 GW
Post by Rix » Dec 23 2019 7:25pm
Theodore Voltaire wrote:
Dec 20 2019 12:58pm
Nicely put.
john61ct   100 MW
Post by john61ct » Dec 23 2019 8:50pm
Theodore Voltaire wrote:Stealth bikes are over engineered enough that you can enhance their performance to a certain degree with little concern of a catastrophic equipment failure. A Bomber sits at the top of the line, and can handle performance enhancement beyond the ability of any other model.
So has anyone adapted that cool frame design to act as the front end of a heavy duty Cargo hauler?
Not necessarily a trike rear, just an extended-length rack / panier setup, good for rough terrain.
Or is that just a silly impossible idea?
FL bomber   100 W
Post by FL bomber » Dec 25 2019 7:30am
:D Merry Christmas ... good health... happyNew year :D
Rix   100 GW
Post by Rix » Dec 25 2019 3:16pm
FL bomber wrote:
Dec 25 2019 7:30am
+1. Back at you FL Bomber.
Thorsaw   1 µW
Post by Thorsaw » Jan 02 2020 12:52pm
I have recently purchased a stealth clone ebike. I've been lurking endless sphere for a while but have never posted. I wanted to see if anyone has had any luck registering/titling their stealth or stealth clone or personal build as an actual motorcycle. My bike has a qs hub motor 8000 watt continuous 12000 peak. I was hoping to buy a lighting kit and getting some DOT approved tires. There's also a company online that says it will be able to title and register my bike as long as it passes inspection and has a serial number and bill of sale. They mentioned that they've gotten five Sur Ron light bees registered and titled no issue.
I guess the question is has anybody actually succeeded in this? Thank you
FL bomber   100 W
Post by FL bomber » Jan 02 2020 3:38pm
Do I turn allen wrench clockwise to remove left side crank arm on v-box?
A New year's Eve mishap 😒 don't mix bomber
With flor de Cana. Should have used with my A2B 😲
Post by Theodore Voltaire » Jan 02 2020 5:51pm
FL bomber wrote:
Jan 02 2020 3:38pm
Yes, left side is reverse thread.
Post by Theodore Voltaire » Jan 02 2020 5:54pm
Thorsaw wrote:
Jan 02 2020 12:52pm
Can't be done in Texas. No VIN#, and no process to get one.
amberwolf   100 GW
Post by amberwolf » Jan 03 2020 1:25pm
Thorsaw wrote:
Jan 02 2020 12:52pm
depends on where you are and the local specific requirements for registering.
its different in different localities for different vehicles, so since you don't give your locality, no one can tell you anything about your particular process or needs.
so you must check with your local dmv and/or local site listing the specific regulations and requirements, then ensure your vehicle meets those specific requirements, then go thru whatever process those requirements list.
if your specific vehicle does not come with a vin of the right type from the manufacturer, and that manufacturer is not on the list (if there is one) of registered manufacturers in your locality and/or federally, it may not be registerable at all.
Thorsaw   1 µW
Post by Thorsaw » Jan 03 2020 5:41pm
I've been told by dirtlegal.com (I have no affiliation) that a serial number and bill of sale is required for Maryland and NOT a vin. If I succeed I will post my results. If I Fail I will still post so others can gawk at my misfortune. Brave New world?
amberwolf   100 GW
Post by amberwolf » Jan 03 2020 5:45pm
Post by Theodore Voltaire » Jan 20 2020 10:11am
Yesterday I was about to suggest that the Sur Ron looks like a good bike for a typical stealth owner, then I remembered that Rix, and Alex has one.
This is what I'm talking about.
Post by Theodore Voltaire » Jan 20 2020 10:20am
I also noticed that Texas has changed their moped statutes making it easier to register a bike that doesn't have a VIN. I think I could register my Stealth in Texas as a moped now if I wanted to bad enough. As it comes limited from the factory it would qualify. There's just a form that needs to be filled out and notarized by the seller that states it has less than 5 hp, and has less than 30 mph top speed. You would need lighting, but mopeds aren't required to meet DOT requirements.
Cowardlyduck   100 MW
Post by Cowardlyduck » Jan 28 2020 7:04am
Finally got my Fighter (mostly) back together and first ride was to check out a massive fire heading my way as Australia burns.
Sorry for the crappy quality photo/video...it was smokey and super windy up there!
The right hand side is the sunset...the middle/left is the fire.
I'm not in much danger where I am as I'm in the middle of the southern suburbs of Canberra, but still scary none the less!
Cheers
Custom made 18650/21700 battery packs
Modified Stealth Fighter - Force air cooled motor @ 6KW, Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
Cowardlyducks - Stealth Fighter Videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Ebike Garage - My YouTube Ebike ramblings.
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
FL bomber   100 W
Post by FL bomber » Jan 30 2020 12:32pm
Sad to see what's happening in Australia.
Hope your home stays up wind of the fire.
Stay safe C D
whitebomber   100 mW
Post by whitebomber » Feb 02 2020 3:07am
Can anyone help me out with instructions on how to connect lights directly to the battery and also a great light option for bush work. Anyone using light bars?
Allex   1 GW
1 GW
Post by Allex » Feb 03 2020 8:08am
Jan 20 2020 10:11am
Well maybe this one with streamers?
Post by Theodore Voltaire » Feb 03 2020 8:17pm
Allex wrote:
Feb 03 2020 8:08am
Why not?
KarlJ   100 W
Post by KarlJ » Feb 04 2020 12:39am
Stock RST forks have finished leaking out their oil
Is this the correct USD-8 for the Bomber
https://www.ebay.com.au/itm/DNM-USD-8-M ... ctupt=true
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 04 2020 6:17am
Another Stealth is soon to get a monster battery upgrade.
Guess which variant.
Cheers
Post by Theodore Voltaire » Feb 04 2020 9:46am
KarlJ wrote:
Feb 04 2020 12:39am
Yes, those will work.
Rix   100 GW
Post by Rix » Feb 04 2020 12:19pm
Cowardlyduck wrote:
Feb 04 2020 6:17am
Cheers
Whats the numbers for this battery?
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 04 2020 5:53pm
Rix wrote:
Feb 04 2020 12:19pm
It's 20S12P. 3Kwh.
Should be good for over 100km range on the particular Stealth variant it's going in. Any guesses?
Cheers
