Kepler wrote:Took the new Fighter over to Stealth today to show John and Al. Managed to get a bit of footage of the bike in action with Al riding it and doing what does best.As you can see, the little BPM has plenty of torque and has no problems popping the bike onto its back wheel and holding it.
Kepler wrote:Working on the custom controller for the Fighter at the moment. The controller has been up speced with 4110 Fets and 100V components. All HV wiring has been done in 12gauge silicon cable which should be plenty for the power output. High current solder traces are all beefed up with solid copper bar too. As you can see, the controller is tiny and a piece of cake to install internally. With the bike frame being used as the FET heatsink, hopefully heat will be kept under control. Should have all the mods completed tonight ready for installation tomorrow.
Cowardlyduck wrote:Kepler wrote:Took the new Fighter over to Stealth today to show John and Al. Managed to get a bit of footage of the bike in action with Al riding it and doing what does best.As you can see, the little BPM has plenty of torque and has no problems popping the bike onto its back wheel and holding it.
Looks nice.
How does it go off road and up long steep hills?
Cheers
Justtoby wrote:Thanks for the vid, it looks great.
Did you put helium in the front tyre?......Al makes me mad as I really want to learn to wheelie like that.
Lenk42602 wrote:Kepler wrote:Working on the custom controller for the Fighter at the moment. The controller has been up speced with 4110 Fets and 100V components. All HV wiring has been done in 12gauge silicon cable which should be plenty for the power output. High current solder traces are all beefed up with solid copper bar too. As you can see, the controller is tiny and a piece of cake to install internally. With the bike frame being used as the FET heatsink, hopefully heat will be kept under control. Should have all the mods completed tonight ready for installation tomorrow.
Kepler,
Would you mind providing any additional detail about the controller you put together for the BPM? What did you start with? Other than the fets, larger cap, bigger wires, what else did you do to handle the increase in voltage?
Thanks,
len
ManxE wrote:Well done Kepler - it looks really agile. Like a Velociraptor compared to the Bomber's T-Rex!
Can Al also do stoppies on it now that the back wheel has less weight?
I guess John & Co were suitably impressed!
Does that make me the alpha tester??Kepler wrote:Essentially I am unofficially beta testing some new setup's for him which at the end of the day is good for everyone.
full-throttle wrote:here's a true story: someone just bought a Bomber, brings it back the next day to check if there's something wrong with it. Apparently it 'doesn't do wheelies'. So John calls "Hey Al, could you come over here for a moment and make sure this bike is alright"
Needless to say what happened next - Al pulls a massive wheelie, hands back the bike "Yeah, it's alright"
Hyena wrote:
Some people seem to think you need big power to do a wheelie but it's all about balance once the front wheel is up (either under power or by yanking it). Not to detract from Keplers bike or anyone elses but I'm sure Al could hold a wheelie with only a 200w bafang
Rix wrote:Beutiful Fighter Kepler,
Don't know if its just the the video, but other geared hub motors Ive seen sound noisier than that. Is your BPM any noisier than a gearless hub motor? It sure doesn't sound like it is. Once again, super nice build. Spoke with Darrin last night, he says my bomber may be here next week. Can't wait!! Been a long 6 weeks. I thought for sure that I would get bumped back a little when Darrin and John suggested I switch my order to the bomber. Apparently not. Great Guys and a great company. So.... When you gonna do a comparo between your fighter and a stock fighter. I am curiouse if there will be any accelleration differences. Your fighter at 2KW and a stock fighter at 3KW would suggest that the stock fighter would be faster. However, factor in your fighter's much lighter rolling weight and the geared hub, I wouldn't be suprised if it could beat stock fighter. Thanks for showing your build details and posting the video. Rubberside down, or, at least one wheel. Rix
Kepler wrote:Had a very interesting commuter type ride with my friend on his Fighter and me on my Fighter this morning.Total distance was just over 12km. As a re-cap, his Fighter has the stock HS35 motor but is running 18S 75V LiPo. We have the current limit set on his bike to 55A so it has over 4000W available. Mine is set to 30A. He weighs about 80kg and is a bit lighter then me.
We road wheel to wheel or side by side for the full ride and both just peddled lightly. I nearly fell off my bike when I saw the difference in economy.
By the figures below, my bike managed a whopping 40% better efficiency.This was at a moderate average speed of 33kph
We also had a bit of drag race from about 30kph until I ran out of legs. He was slightly quicker then me but not by much. I only lost one bike length to him over the distance. You can see from the numbers below, both bikes peaked a little higher the set amp limit but this not unusual to see.
I could see one of the big advantages I had was that my bike seemed to glide for much longer when not under power. Although when coasting down a hill, both bikes seem to maintain the same speed. This surprised me as I thought my ability to fully free wheel would have seen me pull away under coast. However, this wasn't the case.
Finally, noise wise, although they had a different sound, the actual noise level between the two bikes were very similar.
sn0wchyld wrote:
I'd love to see a drag race from a standing start... and at what speed did the Hx fighter start pulling away?
Users browsing this forum: bowlofsalad, o00scorpion00o and 8 guests
