cruzxia wrote:Jim
Can you please post a photo of your kick stand on your Bomber. My next project is to add a kick stand, so I am interested to see how you attached your stand.
Cruzxia
Marclink wrote:Hello I'm new to the forum I have a Stealth fighter ordered should be here June 18 can't wait I'm like a kid on Christmas...
Marclink wrote:Very funny! I've been struggling with whether to go with the bomber or not I like the weight of the fighter much better but obviously the power of the bomber. All kidding aside their New York should I move up to the bomber?
Kepler wrote:Marclink wrote:Very funny! I've been struggling with whether to go with the bomber or not I like the weight of the fighter much better but obviously the power of the bomber. All kidding aside their New York should I move up to the bomber?
I think you are on the limit of weight for the Fighter, not so much for power but more so for rear shock compliance. The Fighter uses an air shock designed for mountain bikes. The Bomber has a motor cycle shock fitted.
If the actual weight of the bike is a major consideration for you, the Fighter is the right choice. You will need to run 200 psi plus in the rear shock though to keep sag under control. I am 200lb and 6' 3" and run 180psi in the rear shock. I think the extra 20lb you have on me will still be manageable but of course running higher pressures in the the rear shock means a slightly stiffer ride. You will need to order a shock pump so you can setup the rear to suit you.
In relation to power, at 3kW, the Fighter has plenty
QMS wrote:Hi guys here is a couple of pics of my side panels painted & rear mudguard still working on the front one & the T6 alloy kickstand. Will post pics as soon as they are done.
RST fork testing follow-up.
Dry lube did not work on the RST forks, they became sticky again.
I tested another product made by SFR which is a friction modifier, that bonds with metals and alloys. It works even better than the silicone spray and shouldn’t dry out.
I tested the RST forks riding over a ½” block of wood at about 4 mph, and they absorbed this small bump.
This is the product I used
https://www.sfrcorp.com/product/protect ... ion-oiler/
cruzxia
Rix wrote:RST fork testing follow-up.
cruzxia
Cruz,
Thanks for doing the experiment on the RSTs with the drylube. I was wondering about it on light applications. I use dry lube on my 450, but I have to put it on after every single ride and like I said earlier, the percieved increase in smoothness may be in my head. That said, how is the SFRCORP ion oiler as far as attracting dirt and working after say 20 miles of wooped out riding? If its still working, I am definately gonna use it. The other idea I have been tossing around is disassembling the forks and putting some prolong super lubricant grease on the inside of the seals/tube bushings. This would keep the grease off the exposed portion of the fork tubes while keeping the the seals lubed when compressing and extending. I did this on a dirtbike many years ago. The forks were a Showa open bath and had 2 seals about 1/2 inch apart in the fork legs. I put axel grease inbetween the seals after I replaced the seals. I don't know anything about the RST Ones so maybe this isn't possible. I tried to get the pdf downloaded from the RST on their website. I am wondering if the fork is a seperate function fork, Spring/compression in one leg and rebound/openbath control in the other leg. Anybody know?
QMS. SWEEEET bomber!
Rix
cruzxia wrote:Jim
Cruzxia
Most MTB forks have dual seals. It's the first time I see a decent fork with a single seal.cruzxia wrote:The seal system on MTB forks is different to motorcycles. There is only a single seal plus a couple of bushes on the MTB forks.
Kepler wrote:You are a smart man. Based on the fact you are not a small bloke I think you have made a good decision.
Marclink wrote:Jim looks like you got a fighter and a bomber which one do you like better?
Users browsing this forum: No registered users and 12 guests
