Specialized Enduro Comp / BMC Build Thread
Re: Specialized Enduro Comp / BMC Build Thread
Postby oatnet » Tue Jul 12, 2011 5:14 pm
nicobie wrote:Thanks for the link. Exactly what I was looking for.
You'll love them, they are nice and light. :D
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby oatnet » Tue Aug 09, 2011 8:55 pm
Ambrose asked to see inside the battery box, I realized I had other pics I could post of it, so here you go:
The bottom of the box, where the 8gah wiring exits the box, each to a power switch, which fits into slots I cut into the bottom fins. Note the right side of the photo, the resistor in heatshrink, around the switch. I flip the OTHER switch first, and the resistor lets a the current trickle in to charge the caps in the controller. This avoids a surge at power-on, and gives me a nice way to power up the CA without powering up the full system - to check, or when wheeling the bike out of the garage... When the controller is charged up - a moment or so after the CycleAnalyst boots... Then I close the switch with the resistor, and the system has full current. I originally planned to epoxy the switches in, but the build seems fine as is. The wiring is hid from side view by the flaps the switches are installed in, and from the frunt by the bottom of the hinges.
(62.99 KiB) Downloaded 64 times
The box sitting open, the two 8gau wires, wrapped in protective heatshring, terminated in 45a andersons (clamped and soldered) inside the case. You can see the bolts/locknuts/washers I used to secure the case to the clamps. I originally planned (6) clamps for this, but tested the waters with only (4), and it seems solid so I stuck with it. I have no idea what the long vertical object is, sitting on top of the case
(65.54 KiB) Downloaded 64 times
A 50a circuit breaker with 8ga and (2) 45a andersons; it will go in the middle of the pack to give maximum protection by dividing the voltage.
(35.17 KiB) Downloaded 64 times
Here is the first 8s16ah block of cells going in. It is standing up so that you can see the blue heatshrink I put around each anderson connection to keep them in solid contact. On the bottom is red plastic (from the lid of a storage bin we used as a litterbox) that goes over a layer of high-density foam, covering the bolt heads. More of the foam is at the base of the box (top of the picture) and has blue lines watermarking the height of the sub-packs. Note the channels carved in the foam for the power leads.
(55.73 KiB) Downloaded 64 times
The first sub-pack installed. Note the power lead top left, tucked into place in the foam. the other side of this battery is connected to the circuit breaker, which is wrapped in red heatshrink (bottom right) and tucked into place.
(51.45 KiB) Downloaded 64 times
Another layer of plastic, with the warning label indicating that this battery box is not safe for babies. Who Knew?
(49.96 KiB) Downloaded 64 times
The second battery in place, more blue heatshrink overlapping the anderson's' heatshrink, to protect/clamp the connectors.
(67.56 KiB) Downloaded 64 times
My first go with this motor was 48v, so I only had two 8s sub-packs in there with a big slab of foam. You can see how the wiring can be neatly folded away on the left side.
(64.13 KiB) Downloaded 64 times
The back of the completed battery. Note the strain relief on the andersons, the clamps, and you can even see one of the power switches hidden away on the bottom of the case.
(88.51 KiB) Downloaded 64 times
Here I am adding the 4s sub-pack to bring the pack to 60v nominal, or 74.7v off the charger, and about 67v under load. The lid was easily able to hold all three sub-packs standing on, this box is strong!
(70.99 KiB) Downloaded 64 times
Image大鸡巴 Motors
oatnet
Postby oatnet » Tue Aug 09, 2011 9:50 pm
Here is the charging setup:
I got a bunch of these Vicor PSUs for really cheap, loaded with (8) 48v4.2ah cards that can be adjusted from 35v to 58v. Here Ihave them configured as 2s4p, which means I could pump 16.2a from 70v to 116v. It would require 240v to supply that much current though, and while this is 120/240v unit I only have 120v.
(104.5 KiB) Downloaded 58 times
Here is the charging port on the bike!
(94.3 KiB) Downloaded 58 times
Image大鸡巴 Motors
oatnet
Postby ambroseliao » Thu Sep 22, 2011 1:06 pm
It looks like all of the photos are gone. :(
Ambrose
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby deepfraught » Thu Sep 29, 2011 9:06 pm
+1 curious to see the inside of box if the pics can be reposted!
ebony and ivory A2B Metros, testing 5065 and 6374 Commuter Booster beta, Hyena Hadron mkIV tested and H4060 test pending, GNG belt/chain BB drive test pending. Sold Tornaro mid-drive Nuvinci N360 Zoco Rossa and other flakey e-bikes. 2012 Every day pedal commuter 10kkm+
deepfraught
Postby oatnet » Sat Oct 01, 2011 5:46 pm
Hopefully we have seen the end of the disappearing images... I'm gonna keep the original post intact, to see if they ever come back. Here is a repost of the same pics, with the same commentary attached (assuming I got the comments back in the right order!). :D
-JD
The bottom of the box, where the 8gah wiring exits the box, each to a power switch, which fits into slots I cut into the bottom fins. Note the right side of the photo, the resistor in heatshrink, around the switch. I flip the OTHER switch first, and the resistor lets a the current trickle in to charge the caps in the controller. This avoids a surge at power-on, and gives me a nice way to power up the CA without powering up the full system - to check, or when wheeling the bike out of the garage... When the controller is charged up - a moment or so after the CycleAnalyst boots... Then I close the switch with the resistor, and the system has full current. I originally planned to epoxy the switches in, but the build seems fine as is. The wiring is hidden from side view by the flaps the switches are installed in, and from the frunt by the bottom of the hinges.
The box sitting open, the two 8gau wires, wrapped in protective heatshring, terminated in 45a andersons (clamped and soldered) inside the case. You can see the bolts/locknuts/washers I used to secure the case to the clamps. I originally planned (6) clamps for this, but tested the waters with only (4), and it seems solid so I stuck with it. I have no idea what the long vertical object is, sitting on top of the case.
Another layer of plastic, with the warning label indicating that this battery box is not a safe place to store babies. Who Knew?
Here I am adding the 4s sub-pack to bring the pack to 60v nominal, or 73v off the charger, and about 67v under load. The lid was easily able to hold all three sub-packs standing on it, this box is strong!
IMG_5239 Charging port.jpg (94.3 KiB) Viewed 1532 times
Image大鸡巴 Motors
oatnet
Postby ambroseliao » Sat Oct 01, 2011 6:42 pm
Thanks JD.
Ambrose
ambroseliao
Postby chroot » Thu Oct 06, 2011 2:01 pm
Nice FS ebike! I wanted see your opinion on Cloud9 seat and I was thinking get 2 of these Cloud9 seat from amazon with free shipping. Is it comforts sitting long trip?
Let me know :)
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby oatnet » Fri Oct 07, 2011 4:30 pm
chroot wrote:Nice FS ebike! I wanted see your opinion on Cloud9 seat and I was thinking get 2 of these Cloud9 seat from amazon with free shipping. Is it comforts sitting long trip?
Let me know :)
Thanks chroot!
I am a big fan of cloud 9 seats, comfortable and durable, they are a standard item for me, and I highly recommend them. When I was planning a line of ebikes using those TF frames I sold here, I bought and tested a good 20 seats to see what suited me. Cloud 9 was the standout product from that test. Note that this is the super-wide comfort version, and not the cheapest brand, but if you've ever permanantly lost a road bike seat in your butt cleavage, this is what you want.
This same testing phase also got me hooked on Ergon grips, On-One 'Mary' handlebars, Dimension adjustable stems, Mirrycle's, and the Thudbuster seatpost. The combination took my rides from painful to comfortable, and I have used them on every build I have done since (except no tbuster on this FS bike). I still have a few seats left from my last order of (10) :lol: I also have a wide "exercise bike" Cloud 9 seat that rocks.
Around the same time, I picked up Maxxis Hookworms, Kenda 2.25mm downhill tubes, and Panaracer kevlar liners from ES 'OG' xyster (who I learned lots from, but he left here about the time cliques started to form). I have not had a flat in 4+ years and some 20k on eBikes.
Later on, I standardized on Alex DX-32 rims, they are a great match for the Maxxis Hookworm, the 38mm rim spreads the hooky into an ideal contact patch.
Way more detail than you asked for, I guess once I get started talking on products I believe in... :oops:
-JD
Image大鸡巴 Motors
oatnet
Postby chroot » Fri Oct 07, 2011 10:18 pm
I went ahead ordered the cloud9 seat from amazon. Thanks for the review on the cloud9 seat.
chroot
Postby Beavinator » Fri Oct 21, 2011 1:38 pm
I really like this bike!! Mounting the battery pack to the forks is a smart idea and that bike looks so clean! I hope that you don`t mind if I copy you on my Norco Shore build. I was going to use a backpack but I would much rather keep the Lipo further away from me if possible. :mrgreen:
Beavinator
Postby oatnet » Fri Oct 21, 2011 7:48 pm
Thanks Beav! :D
You will be pleased by the handling. It took me about a day to get used to the quicker steering, and then I was stunned, it was like I went from a Cessna to an F-15. LiPo or LiFe will get ya there! :lol: With the volume saved with lipo, you would have space up there to mount the controller too. I did that on mrs oatnets bike, just ran 8ga phase wires for the higher motor current.
It isnt all roses of course. It is less stable on a kickstand, I'm hoping the heavy motor in my upcoming build will offset the balance better. Of course, this bike doesnt have a kickstand mount anyhow. Nose weight makes wheelies more complicated, but the rest of the time it keeps the front suspension planted. I've taken 2' drops and was able to bring the nose up, kick off the rear suspension, and nail a two-point landing. Get your mass over the handlebars like you were riding a dirtbike, and it is real easy to kick the back wheel around.
-JD
Image大鸡巴 Motors
oatnet
Postby oatnet » Sun Dec 04, 2011 3:16 pm
An enduro comp exactly like mine has come upon feeBay:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... _500wt_922
Image大鸡巴 Motors
oatnet
Postby gensem » Tue Jan 03, 2012 5:54 pm
Oatnet,
I went a little bit further and decide to solder the frame. Its a big block coz its aluminium and like to overkill a little.
This is how its looking now (bad quality cel pics)
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby oatnet » Tue Jan 03, 2012 6:42 pm
gensem wrote:Oatnet,
Nice job, that is going to work out well. I look forward to seeing the box mounted!
-JD
Image大鸡巴 Motors
oatnet
Postby veloman » Wed Jan 04, 2012 4:23 pm
There's a bunch of these fsr type FS bikes on Austin CL, in the $300 range. I already got my sweet looking fsr and khs as the current ebike. Check my thread to see how I mounted my battery, it JUST fit. Otherwise I was going to do what oatnut die with the battery on the forks.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby gensem » Wed Jan 04, 2012 4:40 pm
Doc's torque arms with two m5 and DP420 epoxy
Controller tray
I think I should start my own thread :)
gensem
Previous
Who is online
Users browsing this forum: 70ivi452, Blackssr, GCinDC, Hyena and 14 guests
