MAC motor + Trek 4300 build
Re: MAC motor + Trek 4300 build
Postby o00scorpion00o » Wed Apr 11, 2012 2:16 pm
2.5 kw/hrs of LiPo, that would give me 50 miles with my mac at 35-40 mph, Nice!
I bet you are glad to be riding the mac again ? I can't wait to get mine back running!
o00scorpion00o
Postby neptronix » Wed Apr 11, 2012 2:50 pm
veloman wrote:Do you have problems with the chain coming off the chainring when shifting the rear? That's what I found, so I keep the front derailleur. I see you got a more normal looking stem now. And front suspension again?
Yes, i do. If i shift while hitting a bump, i'm screwed.
However, a front derailleur is both useless and doesn't jive with a frame bag too well.
I'm sure there's a better solution.
Scorpion: yes, i love having it back in action! But i feel like it's so slow now, in comparison to the 20" pie on 6kW.. :lol:
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby o00scorpion00o » Wed Apr 11, 2012 3:12 pm
well in a 20" it probably has tonnes of torque, but the amount of power you have to dump into it is not a fair comparison :D
+ the fact the mac can do 40 mph on 16S is really cool and helps keep battery weight down!
o00scorpion00o
Postby neptronix » Wed Apr 11, 2012 8:36 pm
Eh, the 20" magic pie just sips amps and wants high volts. The battery weight ends up being the same. The 8T MAC at higher speeds, like any other fast wind motor, just guzzles amps so you need higher amp hours.
The watt hours end up being equivalent for me. I do some fairly long distances.
neptronix
Postby o00scorpion00o » Thu Apr 12, 2012 4:12 am
Having said that, I had to make a 15 mile trip yesterday.
I went full throttle 99% of the way at 30 mph, and cruising at that speed the pie is fairly efficient, about 900 watts on level ground 1000 max. I think that is pretty good, and it was a little breezy.
When I was running 24S 1P I didn't really pay too much attention to the watts being consumed as I was having too much fun at 40 mph!
But the mac consumes around 2200 watts at 40 mph. The fact it can do 40 mph on 16S tells me it's a more efficient motor.
The pie isn't too far behind because with halls controller set to 120% it can do 34-35 mph max on 16S
On a motorway bridge my friend pat passed me with his mac on a 48V ping and his controller is set to about 45 amps, so he was pulling around 2200 watts.
I modded the 12 fet for 80 amps on 60 volts and he passed me, If I was on 24S there is no way in hell he would have passed me, I just didn't have the voltage on 16S, so I couldn't pull any more watts to get me up faster, and Pat was behind me before even climbing the bridge and it's pretty steep as the motorway goes over a little river so the motorway is raised a bit.
A geared pie sized motor I would love to see and it wouldn't even need to be such a slow wind!
But I do think the pie is too slow a wind, I wonder how it compares to the crystalyte HT motor, or the HS
I still think high torque motors on higher volts is better, but the pie is just a bit too slow, needing 100 volts for 40 is crazy, that would get you 60 mph with the cromotor or the crystalyte 54xx
o00scorpion00o
Postby chroot » Thu Apr 12, 2012 1:20 pm
hey o00scorpion00o and neptronix, Please come over check this thread and answer the question.
Here the link viewtopic.php?f=3&t=38688
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby o00scorpion00o » Thu Apr 12, 2012 1:39 pm
chroot wrote:hey o00scorpion00o and neptronix, Please come over check this thread and answer the question.
Right oh, I'm coming over! :mrgreen:
o00scorpion00o
Postby olemetry » Fri Apr 27, 2012 11:00 am
Thanks for your posts in this thread. I always learn something.
All of my bikes were recently stolen including my Schwin Claimont Golden Motor DD setup. It weighed a ton and I toped out at about 26mph. It was a blast and I will forever be hooked.This thing was geo-caching beast! But the thiefs didnt take my 12s3p pack so Im looking for a new build.
I think I'm gonna get a MAC motor, but I just wanted to verify. What do you think of of the geared 1000W rear high-power #MAC500RkitHP (I think it is 6T?) on a Specialized Rockhopper Comp Disc? Is it OK to run this on a 29er? Or should I stick with 26"? I live in New Orleans so there are absolutely no hills - but a few broken levees. Only flat bumpy roads. What sort of speed should I expect? I also have some 4s laying around to build 16s if necessary. Let me know what you think. Thanks again for all yalls posts!
olemetry
Postby neptronix » Fri Apr 27, 2012 11:34 am
Well, you should consider the 8T. On 12S, it should do a pretty solid 30mph constant, a bit more in a 29" wheel.
6T on 12S might be pushing it. You'd be doing 35+ mph, which is coincidentally close or over to the motor's constant power handling limit. 16S would get you over 40mph, which is enough power to blow the motor in a short period of time.
16S on the 8T in a 29" wheel would get you a bit over 40mph ( 41-42? ) which is OK for short jaunts , but again.. really pushing it!
By the way, hate to say this, but nothing accelerates like the pie. It hauls ass like a big crystalyte. The MAC has great power output for it's size.. but it may leave you wanting.
neptronix
Postby olemetry » Fri Apr 27, 2012 1:14 pm
Thanks guy. Now that I look a little closer, I think I see what you are saying. You recommend 8T just because of my intention to run 12s correct? Cellman gives a warning of 48V on 6T, but gives a warning of 60V on 8T. I do want another Golden Motor like the 20" molded wheel you have, but that will have to wait for a differnt build. I also want to freewheel with the Rockhopper, putting the controller in batteries like you have in a bag and then just unplug it and remove it to ride the bike regularly.
I assume that the 8T does not come with a 7-speed attached and yall kinda went back and forth in the thread about which one is a good one. Can you recommend who I should get the 7-speed from? What about the torque arms - I dont think I have anyone around here than can custom make them.
Also, what do you think the shipping is approx. from cell_man to New Orleans? I sent him a letter, but as you know it takes a while. Thanks again man. You do us all a great service!
olemetry
Postby neptronix » Fri Apr 27, 2012 1:57 pm
No prob.
Yeah, 48v on the 6T will do about 40mph on a 26" wheel. That's just too much.
I run 57v ( 15S ) on my 8T in a 26" wheel, and yes, it is operating the motor close to it's short term limit. On a 29" sized wheel i would be more concerned.
I think you'd be pretty happy with the 30-32mph speeds that the 8T in a 29" wheel would pull. If you want faster, i'd go to a motor that can handle more power.
The 20" magic pie is a novelty motor, in reality! you can't even hit 30mph on 72v :lol:. I am going to tag team up with gary at golden motor canada and see if we can get them to do a custom winding for approx. 20mph on 36v in the 20" wheel. It would then be more like a 9T MAC motor. The 20" pie, can handle 41-42mph continuous for a good period of time but that requires 125v nominal, which is a bit on the crazy side.... :)
BTW the magic pie cogs like a son of a bitch, so you will definitely want to keep it for another build :)
The MAC motors don't come with a gear cluster. You'll want a 7 speed 11t DNP freewheel, UNLESS you can find a shimano megarange with an 11t gear, which is far superior.
Forget having custom threaded freewheels made. Not gonna happen. threaded freewheels were marked for extinction in the 1990's and no company is serious about manufacturing them anymore.
Sorry, i don't remember the shipping cost, but i recommend the SAL shipping method. Sea freight can take 2-3 months and there is no guarantee that it will arrive.
olemetry wrote:Thanks guy. Now that I look a little closer, I think I see what you are saying. You recommend 8T just because of my intention to run 12s correct? Cellman gives a warning of 48V on 6T, but gives a warning of 60V on 8T. I do want another Golden Motor like the 20" molded wheel you have, but that will have to wait for a differnt build. I also want to freewheel with the Rockhopper, putting the controller in batteries like you have in a bag and then just unplug it and remove it to ride the bike regularly.
neptronix
Postby kevo » Sun Apr 29, 2012 10:45 pm
Neptronix wrote: The MAC motors don't come with a gear cluster. You'll want a 7 speed 11t DNP freewheel, UNLESS you can find a shimano megarange with an 11t gear, which is far superior.
Can a 9 speed Shimano cluster be used with the MAC if the rear stays are slightly expanded and a spacer is used :?: (like described by Illia on ebikessf for the BMC)
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby neptronix » Sun Apr 29, 2012 10:59 pm
Hm, that's a question for a bike store. I believe the gear spacing is narrower, so the width of the total assembly may be similar. I'm not entirely sure though.
neptronix
Postby veloman » Mon Apr 30, 2012 12:54 pm
I don't see the need to use an 8 or 9speed freewheel. I only use about 3 gears on my 7sp freewheel as it is. Make it easy on yourself and get a 7sp freewheel and get a cheap 7sp rear shifter.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby kevo » Mon Apr 30, 2012 9:40 pm
To each his own, I like to pedal :D
kevo
Postby neptronix » Mon Apr 30, 2012 10:08 pm
Oh, you'll understand the recommendation for a 7 speed freewheel and a huge single front chainring as soon as you get a setup with good power ;)
With my 7 speed, i use about 4 of the speeds. That's at 26mph on the MAC at 36v. I run a 50T chainring. This allows me to pedal along at the motor's top speed, or kick down 2-3 gears to help on super steep hills.
On the magic pie build, i will have a grand total of 1 gear, and will pedal the whole time in that one gear. Some of the biggest hills will drop my speed by i dunno, 2-3mph.... so no need for shifting :lol:
On my lady's 350w MAC tuned to 36v/28A, we do use 6 of the 7 gears for hill climbing.. pushing a peak wattage of about 1000w.
All 3 bikes are pedaled >75% of the time.
neptronix
Postby GMUseless » Mon Apr 30, 2012 10:46 pm
I'm running 50:11 on my MAC 6t and the rear dérailleur only serves as a chain tensioner. I often shift the front rings, but never the rear. Planning on this, I got a good quality Shimano XT front D, and a $10 SRAM x.3 rear D.
The MACs have such good low end torque, you simply won't be using your low gears. If you like pedaling, start with an 11t rear, get the widest bottom bracket you can to allow clearance for the largest front rings that will fit. At 50:11 my input is mostly ghost above 30 mph.
GMUseless
Postby neptronix » Mon Apr 30, 2012 11:04 pm
Yeah, 50:11 is basically useless above 30mph, unless you got a 29er or something. The vuelta USA chainrings are great. a 55T could help you out :). I have a 60T for my 20" wheeled magic pie.
I can pedal up to, i think, 28mph on 11t-20T.. pretty sad :lol:
http://www.vueltausa.com/components/chainrings/se-flat-chainrings.html
50T barely clears my frame with a standard bottom bracket. The Trek frames are shaped just right for it. If i went to a wide bottom bracket, i'd have chainline issues leading to faster wear. Bummers.
neptronix
Postby veloman » Tue May 01, 2012 2:19 am
Hey hey, my top gear is a tiny 44x11 and I sometimes legit pedal it at 32mph. yeah, it's a fast cadence, but not that bad. I usually drop to the middle ring when coming to a stop, and start in that gear (11 tooth). Sometimes I've move it to the 12 or 13 cog if I am starting on a hill or want to get off the line fast. Mostly it's just to baby the gears on takeoff. The 8T on 1200watts has no problem getting off the line. Absolutely kills a DD at the same power level.
I do have a 53 large ring on my next build, so then I can pedal it slower at fast speeds.
But yeah, I never need more than 3 gears. Of course, i don't ride massive hills either. I'd say 8-10% is the steepest, and they are quite short.
veloman
Postby motomech » Tue May 01, 2012 7:51 pm
I had the same problem, the frt. deraileur interfering with the bottom strap of the Falcon EV bag. I was able to get it mounted just above the strap by "locking" it in the big ring position and then moving it up, but it's still close to the bottom of the chain when on my 44/11 gear.
Instead of locking it by clamping the cable on the frame as some have do here, I spread the deraileur open by hand and dropped a sm. 9 mm socket in the open space. The spring tension holds it in there, so I now have a serviceable chain guide.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby neptronix » Tue May 01, 2012 9:00 pm
cool beans.
Probably due to the geometry of my bike, i don't have that problem on my Treks. I can fit a 60T on the suckers and it doesn't interfere with the falconEV bag either ( but it's a close call )
^-- my Trek 4300
neptronix
Postby motomech » Tue May 01, 2012 10:24 pm
Question, "At what point does an Ebike become an Emoto?
Answer, From the rear down tube on back.
motomech
Postby neptronix » Tue May 01, 2012 10:57 pm
:mrgreen: :lol: good one, man.
That's totally true. That's the direction my builds are heading in. I think it happens to everyone who really dives into this. The end of this downward spiral is building something like liveforphysics puts together.
I started out in a 250w cell_man MXUS geared motor kit. Now i am pushing 7000w into a magic pie and 2500w peaks into a MAC. I am ordering an eTek ( motenergy ) 22lb motor and am going to run it chain driven on a hardtail or maybe a xtracycle style configuration.
Pray to your selected diety that you are not afflicted this bad :twisted:
neptronix
Postby veloman » Thu Jun 07, 2012 2:32 am
neptronix wrote::mrgreen: :lol: good one, man.
I think I may have hit the sweet spot for the Mac and my riding, at 1200-1300watts on the 8 turn. Acceleration is plenty to stay in front of city traffic with minimal or no pedaling. I don't ride fast roads and so it's pretty rare that I ever want more power. Efficiency still hangs around 19-21wh/mile with minimal pedaling in this heat. I will boost it to 1500watt and see how that goes, but that is nearing the more abuse territory, and I am getting it fairly hot as it is (88 C). It tops out at 33-35mph on a flat road. Yes, sometimes if I'm stupid and ride a fast road i want more speed, but I can avoid those roads nearly all the time.
The 6 turn on a 45lb bike setup with 2000watts was pretty snappy. Does anyone regularly ride their Mac at 2kw and can you report any issues? For me, I hit peak power constantly since I have to stop so often.
veloman
Postby nonlineartom » Thu Jun 07, 2012 5:53 am
I ride my 10T at 1600W. Although it only pulls that on hills, cruising top speed is about 800W with no headwind, even on 2 mile long hills it's fine, about 2000 miles so far and only a sticky clutch, sometimes won't freewheel but a speed bump or two gets it working. I'm sure it would handle 2KW forever, but that's the 10T can't speak for the 6T
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
nonlineartom
PreviousNext
Who is online
Users browsing this forum: Deutch420, Liberatorbike and 7 guests
