The cover plate is replaceable though, no need to take the spokes off or anything stupid.
Newer ones have steel plates apparently.
I won't be standing on the pedals anytime soon.
neptronix wrote:Gensem.
I tried your version of the keywin software.
ASV file is saving 0.0 to block time, instead of 1.
Transmit worked, no error.
If there is any change, i'm having a difficult time telling.
Seems way eager to eat more amps, but i haven't done a scientific test at all, it's 2am
Engagement at lower throttle levels seems just a bit smoother.
By the way.... at lower amp levels, mid-throttle is less of a problem. Yay! I can go higher voltage and install a speed switch now.
Motor still clunks when engaging the throttle, even lightly.. i think that is a fact of life for this motor; that's just the mechanical clutch / keyway doing it's thing. Thin aluminum covers don't mask the sound.
I will try 15S and report back later; 15S is where i had the problem with a huge jolt of power.
I will also try a 5+ second block time and see if the peak amps go any higher.
-David
wineboyrider wrote:I have been using my CA to dial down the amps at higher voltages and it works much better. My motor controller combination get's weird when you go over 1500 peak wattts. Nice posts Neptronix I want to play with the programming eventually and will keep an eye out for what you get. I have the same problems at 15s lipo, but 48v lifepo4 runs great so does 12s lipo. At 12s lipo it dumps 1200 watts continuous at full speed.
gensem wrote:wineboyrider wrote:I have been using my CA to dial down the amps at higher voltages and it works much better. My motor controller combination get's weird when you go over 1500 peak wattts. Nice posts Neptronix I want to play with the programming eventually and will keep an eye out for what you get. I have the same problems at 15s lipo, but 48v lifepo4 runs great so does 12s lipo. At 12s lipo it dumps 1200 watts continuous at full speed.
I have a CA coming my way too. Will have to test whats is better overall BT+ CA, etc.
Im also interested in the Time adjustment tool from Burtie, but no one that has it posted any optinions yet.
wineboyrider wrote:gensem wrote:wineboyrider wrote:I have been using my CA to dial down the amps at higher voltages and it works much better. My motor controller combination get's weird when you go over 1500 peak wattts. Nice posts Neptronix I want to play with the programming eventually and will keep an eye out for what you get. I have the same problems at 15s lipo, but 48v lifepo4 runs great so does 12s lipo. At 12s lipo it dumps 1200 watts continuous at full speed.
I have the plug in CA, which I usually use on my 9c setup hooked up to my BMC. The speedometer doesn't work right, but I can volt it up. But, no matter what I do with it over 1500 watts it gets really weird so I am sure programming it right would help better.
Can you make the direct plug in Cycle Analyst work with the BMC/Mac motors????????
Stall test at top of the hill failed. Stalled multiple times, had to get the bike up to 1mph.
gensem wrote: I dont think you can get real speed reading from a geared hub because of its freewheel capabilities; I ordered the CA-DP and it should work with any motor, but the speedmeter has a regular sensor to be tied to the wheel to get actual speed reading. ebikes.ca has all very well explained or their site.
I dont have anything working atm, but I ll be doing a greyborg frame built with either MAC/BMS or Xlyte HT3525 in the coming months.
Cell_man has MACs running over 2,5kw peaks, so im gessing you might have timing problems. What controller what you using?
neptronix wrote:... Block time has no effect, at least on this cell_man controller.
Racer_X wrote:Congratulations on achieving your goal, it is like the end of a chapter. Looking forward to hearing about your next goal.
I guess 20ah was too much for your ammo box? Was that a 50mm bullet ammo box by the way?
Users browsing this forum: Hero_004, jbcwv, morati, pchen92, sabongi and 12 guests
