Keyne's DH Comp Build - now with liquid cooled HX35! :)
Re: Keyne's DH Comp Build - now with VIDEO! :)
Postby keyne » Thu Oct 20, 2011 5:11 pm
We had a rather out of season snow fall of 20cm here. I took the bike out a couple of days later (I missed the best of it) to have some fun in the snow. I threw together the video below:
I'm slowly killing off my 9x7 9C, it definitely has less torque than it used to have. Luckily the 8x8 has just turned up so I'll look at making a swap sometime.
Since I drilled the holes in the 9C side panels the motor is definitely much louder which I don't really like.
Other things to note: the 'pod' is off the bike as the speedo is being worked on. I've managed to fit a 6 pot gatorbrake on the front, still need to do some work to get the rear to fit. I plan to overhall the forks and also swap out the rear shock for a Fox dhx 5.0. at 2:17 I was trying to show all the steam coming off the motor - it was getting a good work out in the snow, and when it cut all the way through the snow it would get down to sand which is also pretty tough work for it :D
keyne
Postby GCinDC » Thu Oct 20, 2011 5:52 pm
great vid. looks familiar. i'm looking forward to the snow! it'll definitely slow the rig down tho!
keyne wrote:I'm slowly killing off my 9x7 9C, it definitely has less torque than it used to have.
i know the feeling, especially after using up the first Ah of the pack. are you getting more sag than before? colder temps will do that too. i'm inclined to think it's more with the batt - not sure if smoked (but alive) 9C's actually perform worse, all other variables being equal..
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby Kiwi » Thu Oct 20, 2011 6:29 pm
cool video.
If magnet temp goes above 80deg then the magnets will loose their strength.
Kiwi
Postby keyne » Sat Oct 22, 2011 1:30 am
My 9C is now officially dead :(
dead 9c
My temp gauge stopped working today, but I rode it anyway - it was fun while it lasted, but it eventually let out some magic smoke and now all the phases are shorted... I had a hard ride home! (Of course it had to be the same day that I had already done a 3 hr standard mtb ride with my wife)
I definitely need to find a way to cool the motor effectively, if I just put the 9C 8x8 on there I'll either have a bike I have to constantly be careful with or I'll just end up smoking that one too! :shock: I just don't think air cooling is going to cut it...
Plan is to strip down the bike to do some maintenance (service the fork and shock, put some loctite on a few bolts, etc) while deciding what motor to use/abuse.
keyne
Postby kfong » Sat Oct 22, 2011 7:41 am
Bummer, Keyne try the Magic Pie. Follow this post to understand why.
viewtopic.php?f=3&t=31490&start=390
This would be the motor I would go with if I was going for a DD hub. Another choice is the 2812, an even slower wind. Dogman's review on it. viewtopic.php?f=4&t=27364
You still might look into venting if you have long hills.
I like my BMC V2T, but only because I have not tried either of the above motors for trail riding yet. My hill climbs in Michigan are not long enough to build up heat in the motor. I'm also not running high voltages like you are so this motor would not be a good choice for you.
kfong
Postby GCinDC » Sat Oct 22, 2011 9:06 am
what were the conditions under which it smoked? pulling high amps (80-90A?) at low speed?
GCinDC
1 GW
1 GW
Postby kfong » Sat Oct 22, 2011 9:27 am
I bet most likely long ass hill climbs at high sustained voltages, motor is not able to dissipate the heat build up. The video of the terrain he is riding in is very mountainous. I wish I had such a large area to play with. Too bad the temp gauge gave out.
GCinDC wrote:what were the conditions under which it smoked? pulling high amps (80-90A?) at low speed?
kfong
Postby keyne » Sat Oct 22, 2011 3:30 pm
The current limit was set to 65A, I wasn't riding any very long hills, just doing loops of some tracks with short (200m) gradual (8%?) climbs and descents. It actually died on the flat in the end, but I hadn't given it a rest for about half an hour of quick riding.
Inside I found remnants of melted copper scattered about where some of the copper had melted.
keyne
Postby sn0wchyld » Sat Oct 22, 2011 4:57 pm
keyne wrote:The current limit was set to 65A, I wasn't riding any very long hills, just doing loops of some tracks with short (200m) gradual (8%?) climbs and descents. It actually died on the flat in the end, but I hadn't given it a rest for about half an hour of quick riding.
:shock: :shock: :shock:
the melting point of copper is like 1000deg C!! must have been from a short or something...
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby Doctorbass » Sat Oct 22, 2011 5:33 pm
Sorry to see you blown something.. I feel that liuke will come here with in the next minute.. it detect pretty good all blown things :D :lol:
Temp gauge is definitively something to have and watch!.. what was the temp you saw just before it blow?
usually temp rise faster at high temp.. like exponential..
The next improovement the E-S community must work on is finding an easy and efficient way to cooldown our DD motor
DOc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby keyne » Sat Oct 22, 2011 5:34 pm
I think the insulation melted off and resulted in a short which melted the copper.
I didn't have a functioning temp gauge for the whole ride, so I can't provide any info on that, sorry.
Definitely achieving effective cooling is my current priority. I'll finish off my attempt at a liquid cooled HT35 first up.
keyne
Postby Doctorbass » Sat Oct 22, 2011 6:04 pm
keyne wrote: I'll finish off my attempt at a liquid cooled HT35 first up.
Great!.. I will follow that :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby GCinDC » Sun Oct 23, 2011 8:20 am
keyne wrote:Definitely achieving effective cooling is my current priority. I'll finish off my attempt at a liquid cooled HT35 first up.
take lots of pics!
btw, something i found interesting when playing with the ebikes.ca simulator, is that a 2807 will never overheat pulling 65A at 66V but at 96V will overheat in 7.1minutes! it notes:
Overheat In: This is a prediction on how long it would take the motor to overheat (reach 150oC) based on a simple first order thermal model that assumes the motor is not spinning and in still air. The actual time to overheat on a vehicle moving outdoors and associated air cooling would be substantially longer. It none the less provides a good relative indicator of how much the motor is being stressed until we develop a more complete model.
actual times surely vary. is there real world data on fried 9C's anywhere?
GCinDC
1 GW
1 GW
Postby Andje » Sun Oct 23, 2011 9:33 am
i know that i ran my 9c 9*7 at 100v peaking at 65 amps and never burnt it. It would get up to about 90 km/h at those power levels on flat. I did commutes flat out burning through 750 watt hours in 12 km/s for about a month just fine. It did get hot though; I'm sure I was at it's limit.
I burnt through two hs35's under the same conditions, neither died during peak use or extreme use; both burnt out due to insulation and wiring issues.
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby Kiwi » Thu Nov 17, 2011 3:15 am
Finished my clients bike.
So nice, very underpowered though, he is putting slicks on it and using it for commuting.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=33767
Going to put mine together loosely now I have the adapters and see if I want to peruse the build, or move on to a mid drive nuvinci custom frame.
I also found this on another site, interesting.
Kiwi
Postby crusoe » Sat Dec 17, 2011 6:13 pm
Hey keyne, just wondering how you keep the controller in place?
crusoe
Postby keyne » Sun Dec 18, 2011 8:26 pm
The controller is held on by 4 bolts. They screw into 4 T-nuts which are inside the composite enclosure.
Lot of photos and posts to come in the next few days. I've made some significant changes to the bike. (also re-installed the rear brake after having to remove a barbed wire fence from my arm - where was my go-pro that day? :? )
keyne
Postby binlagin » Mon Dec 19, 2011 12:07 pm
I think i need some new underware... I just discovered this build thread. Yes! I second the more pics idea!
If I can make my DH comp look 1/2 as good as this... I'll be more then pumped!
Where did you source your carbon fiber? And how much should it cost? I've done some fiber glass work on my motorcycle racing fairings... is CF comparable in ease to work with?
Thanks dude! Keep up the good work
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby keyne » Mon Dec 19, 2011 4:17 pm
There are lots of online sources for carbon fiber. Just need to find one in your area.( eg. http://www.uscomposites.com/) CF is much more expensive than fiberglass, but is much easier and nicer to work with. Just treat it like fiberglass and you'll be fine.
keyne
Postby keyne » Tue Feb 07, 2012 6:37 am
It's been a while since I posted here, but I've been working on solving this annoying motor overheating problem.
I fried my air cooled 9C (babied it for a bit then got impatient), constantly overheat my X5305 (which I only don't fry because it was my only remaining motor) I thought about going to a bigger motor with more thermal mass, like the X54XX, but we're trying to reduce unsprung mass aren't we?
Now I think I've pretty much solved the problem - motor overheating is now a thing of the past. Liquid cooling is the way to go. Hal did a liquid cooled hub on his albino build but never told anyone how it went, so I thought I'd give it a crack.
In some ways this is pretty low tech and very much a prototype, but it shows it is possible and definitely does the business.
I don't have a lot of time for this post, so I'll just go straight to the pictures:
The brief was, cooling tubes into motor without using a custom disc rotor. So I got a custom disc side panel made with an oversize bearing.
Room for two 5/8" copper pipes and 3x 8awg phase wires and 1x 9 stranded data cable :)
Probably the most important photo, but somehow I lost most of the ones I took of this process. This is the stator partially finished.
Note the carbon fiber inserts which when epoxied in to the stamped stator form a cooling channel. The rest is just pipes and wires and springs to stop the pipes kinking etc. Also a thermistor under the windings. Not to mention the hall sensors I added (this was one of the original sensorless versions)
Needless to say, this was a high temp curing epoxy.
Now while I was at it I did some magnetics modeling of the motor in FEMM and came to the conclusion that 3mm of iron for the flux ring would be enough and that the 7.5mm that is standard was really not required - all sounded good, but I didin't have the guts to go any further until I watched justin's hub motor presentation video and saw that he basically came to a similar conclusion. So I figured while I was at it I would start to reduce unsprung weight. I got it taken down to 3.5mm in the middle, then spent a couple of hours milling bits out of the hub flanges
In all that got it down 900g. If I did it again I'd take out a few more bits, (larger cutouts between spokes and the 1.5mm or so on the outside of the disc side flange) I'm pretty sure you could get it down to at least 1kg lighter.
Now jumping to it installed on the bike:
120mm pc cooling radiator + 120mm Fan (reasonably grunty delta fan)
1x 12v solar water pump - pc cooling pumps have great specs but are usually only rated to 65degC, this one is rated to 110degC. With the whole system hooked up I get a flow rate of about 1.7L per min with water, a bit less with the 33% antifreeze I use.
For those who don't know, antifreeze is also antiboil, so the 33% coolent I'm using is good from -15 to 105 degC. It also stops corrosion which is pretty important given how the cooling tubes work in the motor.
Radiator viewed from behind
Mounts almost perfectly in the fork. Held on by cable ties of course :)
Fill port (also happens to be a pressure release valve) installed in raidator
Pretty grunty fan.
Pipes and wires all over the place at the moment, different sizes in different places because the pump had different sized inlet and outlet fittings.
Motor in place, I only painted the rotor as I plan to replace both side panels with carbon fiber versions - I think there is another 400g to be saved there.
Other side.
I'm running out of time, so I'll be brief:
I've only had it working for a while, in terms of unsprung weight, the HT3525 is pretty good. After adding stuff inside and taking stuff off the outside I came out with a nett loss of about 700g, so it's about a 6.8kg hub motor. I think I can get another 400g off with carbon side panels, and if I did it agian I could reduce the rotor a bit so a 6.3kg liquid cooled carbon fiber panelled HX35 should be possible :twisted: It certainly Handles significantly better than my X5405. It feels pretty similar to the 9C, but more torque. I have changed the shock since then so not a fair comparison.
Now what you've been waiting for - how it works in terms of cooling:
Ok, so first up I've got a 24s lipo battery pack and controller set for 65A - so about 6kW.
I've only got qualitative data at this point: There's a hill I usually include on my rides that gets the windings of a cold motor up to about 90deg C by the top, if I then ride down and do it again it gets to about 135. With my new system I rode this hill repeatedly without the fan on and after a few runs I would get the windings to about 80 at the top of the hill, but by the time I got down again it would be back down to 60. If I ran the fan it was even better, I couldn't get the motor windings over about 75 and when I stopped at the top of the hill I could just watch the temp drop at about half a degree a second!
The radiator wasn't getting that warm, so I think there is quite a large delta T between the windings and the cooling channel.
Next time I'll install a flow meter and temp sensors at the inlet and outlet of the motor to calculate actual cooling rates, but for now you'll just have to believe that it works really well! :D
I haven't had a chance to try higher currents, next time I work on the bike I'll try 80A (7kW) and see how it behaves, I think that shouldn't phase it too much. I think I could probably get away with a smaller radiator and fan.
gotta go...
keyne
Re: Keyne's DH Comp Build - now with liquid cooled HX35! :)
Postby adrian_sm » Tue Feb 07, 2012 6:50 am
Outstanding effort. Well done.
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby Spicerack » Tue Feb 07, 2012 6:52 am
Awesome, well done. Just a thought- if you were concerned about the corrosion aspect, you could run a thin mineral oil instead of coolant- maybe automatic transmission fluid or a very thin machine oil....
Norco Shore2
Was Cellman MAC rear oil cooled now 8x8 9C vented and temp probed
12 FET controller
62V 18650 home made battery pack
50 km/h
http://endless-sphere.com/forums/viewtopic.php?f=6&t=32769
Repair thread http://endless-sphere.com/forums/viewtopic.php?f=2&t=34806
Oil cooling the hubbie http://endless-sphere.com/forums/viewtopic.php?f=2&t=37972
Spicerack
Postby full-throttle » Tue Feb 07, 2012 7:14 am
Wow! Looks really good!
How's the pipe attaches to the stator? Does it go around once or twice?
full-throttle
Postby crusoe » Tue Feb 07, 2012 10:49 am
Did you build those inserts from scratch? And how exactly did you get them in there?
crusoe
Postby Doctorbass » Tue Feb 07, 2012 12:05 pm
NIIIIICE !!!! :mrgreen: :twisted:
Awsome!... you did what many of us would like to !
Hal already did that, Lowracer too i think. and now you are the third...
but you are the first to share INTERESTING data !!
Thanks for all effort!! :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
PreviousNext
Who is online
Users browsing this forum: Drunkskunk, GCinDC, planky81 and 9 guests
