kfong wrote:Modding the motor plates with CF sounds like a great idea for saving weight, but sounds bad for heat dissipation. I will be courios on how it holds up.
keyne wrote:......
1x 12v solar water pump - pc cooling pumps have great specs but are usually only rated to 65degC, this one is rated to 110degC. With the whole system hooked up I get a flow rate of about 1.7L per min with water, a bit less with the 33% antifreeze I use.
For those who don't know, antifreeze is also antiboil, so the 33% coolent I'm using is good from -15 to 105 degC. It also stops corrosion which is pretty important given how the cooling tubes work in the motor.
gotta go...
keyne wrote:Yeah I should really post some updates:.....
Just this morning I'm building a roll-able scissor-lift stand for the bike to make it easier to work on and have installed a sealed regen switch on the front brake. I can't think of a time when I use the front brake and don't want regen (maybe if I wanted to do a burn-out?), but to allow wheelie control I didn't put one on the back brake.
...roll-able scissor-lift stand for the bike to make it easier to work on
Users browsing this forum: Google [Bot], Holocene, slayer and 8 guests
