Keyne's DH Comp Build - now with liquid cooled HX35! :)
Re: Keyne's DH Comp Build - now with liquid cooled HX35! :)
Postby megacycle » Sun Aug 19, 2012 7:23 am
I was thinking to put a copper jacket over the fins on the side of the controller were the fets are bolted, the fins then making the coolant channels ( no pulling the controller apart :D )or burst fire freeze spray with a hydrocarbon propellant and piezo igniter for afterburn and faster heat draw, for :twisted: buyouts :lol: .
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby liveforphysics » Fri Apr 19, 2013 4:20 pm
Nice job! I've seen a couple water cooling hubmotor attempts before this one that looked like they would be less effective than simply drilling the covers or adding oil, but this one is exceptional in how you bonded the outer layer of water jacketing in a location that can absorb some stator heat effectively.
My favorite way to know if a cooling system is working is to simply watch the delta between water into the radiator and water out of the radiator. If you know the flow rate, and you know the delta, you know it's ~4.2J/gram of water raised 1 deg C. A Joule is a watt-second of energy.
So, just as an example calculation if you measure your flow rate at say 100L/hr through the cooling loop, and you observe a peak delta-T you can hold across the radiator continuously of say 10degC difference between inlet and outlet temps, then you know the rate your system can shed heat.
Crude calculation example would be something like 4.2KJ/Kg*100L*10degC = 4200KJ/hr of heat transfer, which is ~1.1Kwh of thermal energy transfer per hour capability. If you were operating the motor at a point where it was say 80% efficient, this would enable it to handle 5-6kw of input power continuously. That would make it better than any air or oil cooling alone setups to the best of my knowledge, but of course these are just make-up guess numbers just to show how to do the math. For the numbers to mean something you will need to take real data from your setup of course.
Great job!
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby keyne » Tue Apr 23, 2013 9:03 pm
Thanks Luke,
It's been a while since I've posted here, also a while since I've ridden the bike. (Damn PhD getting in the way :? )
The best cooling numbers I saw were about 700W (8deg drop, 1.2L flow). Done by measuring temp difference between entry and exit of the motor (to include heat loss from the tubing). This was however before adding the themal epoxy to the windings and the motor definitely cools even better now (I was seeing up to 25degC delta T between coolant and windings, this has dropped to 15degC max), I just haven't formally measured it since the change - I should probably do that. I wouldn't be surprised if I'm getting 1kW of cooling now.
I doubt my bike ever gets ridden for long at the 80% efficiency point, but then on my trails there's no way to keep 6kW on for long either! :P
Oh yeah, just to make it go faster I've added blue flames to the side panels :D
Last edited by keyne on Tue Apr 23, 2013 9:06 pm, edited 1 time in total. View post history.
keyne
Postby Obiwan007 » Fri May 31, 2013 7:07 pm
Lets see a picture of those flames. I am keenly interested in your build here as I am starting my second and am doing it on a DH Team frame. Did you ultimately use those 3" tires? How have you liked them? Any problems width wise for getting them in the frame? I used 3" tires on my first build http://www.endless-sphere.com/forums/viewtopic.php?t=46942 but that was on a symmetrical swing arm arrangement. My DH team has the non-centered drop-outs but I still want to go with a fat tire style like yours and my previous one. I am planning on going with bicycle tires and wheels this time and am concerned about the height of that tire. How tall does it stand above the edge of the rim?
Tim
Obiwan007
Previous
Who is online
Users browsing this forum: cruzxia, stevetooke and 14 guests
