This is by far the nicest bike I have ever owned. I paid $525 for it and it is the best money I've ever spent on a bike.
<--- The old bike and Build ThreadAnd my new Novara Method
And starting the build off is the battery placement. I think I'll go with this configuration, everything doubled up. I'll have room for 12 batteries even though I only have 9 at the moment. I thought about fiberglass but I think I'll use some abs plastic to make the encasement. Probably 1/8" thick abs.
I'll be running a 12fet ecrazyman controller that has 4310 fets. I have modified it with usb programming, a temperature sensor/alarm, speed switches, and regen if I choose to do that down the road. I have two 60mm fans on the way to run off of an 18v power supply inside my 9c hub motor that has a temp sensor/alarm and cooling holes. I might run 88v 20c turnigy lipo but for now I'm planning on just 66v.
Parts will come next week and I'll update as progress is made!
