Philistine wrote:when the zombie acolypse comes at least you will be dragging away from them in style.
Brettster wrote:... when i plugged in v3 ca the wheel spins very slowly,i think it may have something to do with the throttle settings in ca.
Brettster wrote:Thanks for your help teklecktic, My CA3-DPS has v3B17 firmware.
5.Setup Throt In ........ Live Data = < 3.95V >
1.ThrI -> Cntrl Mode
{ [ | Current |
2.ThrI -> Min Input
[.99] Volts
3.ThrI -> Max Input
[4.50] Volts
4.ThrI -> Fault Volt
[4.49] Volts
4. Set Thrl->FaultVolt auto-shutdown feature for damaged throttle connection.
- Set Thrl->FaultVolt about half way between 4.99v and the actual measured ViMax e.g. for the example above (4.99+3.93)/2 ~= 4.5v.
Users browsing this forum: EdwardNY and 7 guests
