Farfle's Race bike
Re: Farfle's Race bike
Postby bzhwindtalker » Wed Sep 14, 2011 4:45 am
Are those the 6s 8ah? Thats probably my next battery buy. How will you secure them to the frame?
bzhwindtalker
Postby Microbatman » Wed Sep 14, 2011 1:03 pm
Great build!!!
Finally someone putting a full suspension 20 inch bike together that does not weigh a ton and is strong as an ox. Also like the stealth real bike look.
Super job on the swing arm.
Love the idea of just modding the lower arm and keeping the rest stock. Makes duplicating this easier than having to fab a hole new rear assembley.
Who made the swing arm?
Keep up the great work. You have raised the bar.
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Postby Farfle » Wed Sep 14, 2011 3:39 pm
Microbatman wrote:Great build!!!
Thanks mate :D . hoping it performs as well as it looks! got the rear wheel spinning today, albeit the wrong way :(
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby Jay64 » Thu Sep 15, 2011 8:56 am
Great build man. I look forward to seeing it.
Farfle wrote:Thanks mate :D . hoping it performs as well as it looks! got the rear wheel spinning today, albeit the wrong way :(
Just turn the bike around and hammer the throttle. You might need to get some bar end mirrors or something though. :lol: :lol:
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby Farfle » Wed Sep 28, 2011 9:47 am
Good news :D Battery mounting is done Bad news... :( not posting anymore pics until the race!
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby Thud » Wed Sep 28, 2011 10:35 am
CHICKEN!
:mrgreen:
get some......
Thud
Postby Farfle » Wed Sep 28, 2011 1:09 pm
Thud wrote:CHICKEN!
That's me, maybe one more picture tho...
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby nicobie » Wed Sep 28, 2011 2:22 pm
It that a saw blade you re-purposed as a disc? :shock:
I noticed the old fashioned expansion slots/plugs.
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Whiplash » Wed Sep 28, 2011 2:43 pm
It does look like a diamond blade doesn't it?!!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby Farfle » Wed Sep 28, 2011 2:43 pm
nicobie wrote:It that a saw blade you re-purposed as a disc? :shock:
Very good eye, it is indeed a saw blade, $20 harbor freight cheapo 12" thin kerf blade, bolted on with the sidecover screws.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby amberwolf » Thu Sep 29, 2011 12:11 am
Ok, how well does it work?
I've been trying for months now to find something large enough to fit outside the older 9C 2807's diameter far enough to still allow calipers to clamp around it, but hadn't found anything yet. Been trying various motorcycle shops and people who have them, etc., with no luck yet (usually getting laughed at, called a moron, or just plain ignored).
I thought about cutting a circle out of a stainless steel tabletop I have, but it's too valuable to me as a tabletop, unless I simply can't find anything else.
I looked at all sorts of other things I could repurpose, but had somehow not thought of saw blades. :roll:
I'm pretty sure I can find one of those used, in sufficient diameter, so if it actually works well with bicycle disc calipers, I'd be happy enough with that. Can't be too hard to cut the right inner circle diameter out of, and drill the bolt holes. :)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby bzhwindtalker » Thu Sep 29, 2011 1:48 am
Looks like you will have "some" braking power with this disc and your tire choice ;)
bzhwindtalker
Postby dbaker » Mon Oct 10, 2011 6:15 am
Now to make the caliper mount :D
dbaker
Postby veloman » Wed Oct 12, 2011 10:24 pm
Flip that stem and get rid of the riser bars to get lower. A race bike shouldn't have you sitting upright at all. You wouldn't have as much of a problem with flipping over with lots of torque, and you would be more aero.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby bzhwindtalker » Mon Oct 24, 2011 11:23 am
now that the race is over, could you give more details on this racedog? I saw you had a Kodak playsport bolted on the forks, please upload some HD vids ;)
bzhwindtalker
Postby Farfle » Mon Oct 24, 2011 11:52 am
Here's a couple pictures of the bike, we are still driving home, but will be here some nice HD video, and a better image of the caliper.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby nicobie » Mon Oct 24, 2011 2:58 pm
After seeing the bike in person, about all I can say is that it impressed the heck out of me. Lots of small details well done. Definitely not crude.
The rider wasn't too shabby either... 8)
nicobie
Postby Toorbough ULL-Zeveigh » Mon Oct 24, 2011 3:27 pm
the pessimist engineer sees a glass that’s twice as big as it needs to be.
the optimist engineer sees that the glass has a 100% safety tolerance.
http://what-if.xkcd.com/6/
there is zero consequence to ignoring ayn rand
Postby amberwolf » Tue Oct 25, 2011 12:09 am
And I'd really like to know how the sawblade brake disc worked out. :)
amberwolf
Postby Thud » Tue Oct 25, 2011 8:21 am
I took this bike for a short spin araound the pits.
The rear brake worked just fine! & I was quite impressed with the pull this motor/battery combo displayed even at the end of the battery cycle....nothing like a twin Rc powerd super bike, but definatly falls into the Performance catagory (with a capital "P") this bike was the one to beat before LFP arived with the murderers row of e-bikes (paulD & his own Golden motored tire burner)
It was fun watching Jay64 scrubbing the tires around the race track for a couple short laps before sutting off due to low voltage & not wanting to destroy Farfles already abused batteries.
I can only imagine how it accelerated with the Lightweight Jockey (ringer :D ) team farfle brought down to demonstraight the build. Good Job all the way around & the details were all covered. Truley a great build.
get some......
Thud
Postby etard » Tue Oct 25, 2011 8:52 am
+1
Farfle offered the bike up and I got on not expecting much having missed the races, tested the throttle and WRF did it just pop a power wheelie??!! Gunned it and the grin came over me. I handed it to Thud and said you have got to try this bike out! I have to be honest, I never thought a hubmotor would impress like this bike, and on half dead batteries nonetheless. Saw disc worked a treat too, I would have never known it wasn't standard equipment if he hadn't told me.
We want vids man! I want to watch on BIG screen! Lol. See you guys at the Death Race in April!
etard
Postby acuteaero » Wed Oct 26, 2011 12:41 am
A couple of race photos of this awesome bike-
I too greatly enjoyed taking a spin up and down the pit row on this fast and well-sorted bike. Kudos to Farfle for building such a balanced, well put together bike, and congrats for the 2nd place finish!
acuteaero
Postby AussieJester » Wed Oct 26, 2011 1:25 am
I hadn't noticed the 'pegs' you have added, unitli seenz them in the pics with Aiden riding the bike, first i thought they were
your version of crash protectors as per used on faired motorcycles
to help decrease damgae in the event of the eniventable fall...THEN i notice them in the pic
of it on the motorcyle-ishkay stand, very clever Farfle! very clever indeed!...i think they
would also double as crash protectors to, though :P :-)
Well done too Aiden, great to see a e-wiminez in mixing it with the bois :lol: And congrats to
you on such a well presented frocked e-racer Farfle, its a very impressive turned out e-bike with
performance to match.. 8) :wink:
KiM
AussieJester
Postby dogman » Wed Oct 26, 2011 6:02 am
Congratulations on such a well thought out race entry. Love the way the steel wishbone came out.
Coming in second just proves what I learned in the DR last spring. The rider is the key element, once you have a reasonably fast bike put together. Your gal must be awesome! Clearly Paul is.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Farfle » Thu Oct 27, 2011 2:06 pm
Definatly hooked on racing... next year may include a monster 110kv 200mm outrunner, a whole lotta 4110s and some optical sensors... my wallet is gonna hate me...
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Next
Who is online
Users browsing this forum: Brute, Google [Bot] and 4 guests
