gm6046
G'day,
Here is a quick picture run down on how I built my Ebike. It took about 2 months to build.
I started with a brand new Raleigh M200 mountain bike.
I bought some 75mm styrofoam sheet to shape some covers to hide the battery and controller inside the bike frame
Shaped foam finished
I covered the foam with tinfoil. This is because I layered the fibreglass directly onto the foam and the resin would dissolve the foam.
First layer of fibreglass put down
Fibreglass panels removed from the foam samples
Applying body filler to smooth out the fibreglass
Body filler sanded smooth
Undercoated ready for painting
Painted up. The first coat was white, then some stickers applied, then I painted then red. Once dried, I removed the stickers to reveal the white writing.
The charge port and on/off key are mounted in a recessed panel on this side
The front panel mount. It's also made from fibreglass with an alloy sleeve inside. An adjustable width alloy rod sits inside the sleeve and it locates the panels.
The controller mount and rear panel mount. This bolts to the existing drink bottle threads. The fibreglass panels have 2 alloy locating spigots made into them, this helps align everthing easily when removing and refitting them
Rear torque arm for the hub motor
Ping 48v 15ah battery mounted on a folded alloy cradle. The cradle is attached to the frame via the drink bottle threads, there is a layer of foam rubber between the cradle and battery.
All done
The next job on the list is to fit front and rear disc brakes.
Thanks for looking
Stuart
All done
Thanks for looking
Stuart
