Giant DH Comp Drop Out adapters and conversion
Metallover
Re: Giant DH Comp Drop Out adapters and conversion
Post by Metallover » Oct 02, 2014 1:51 pm
I was Scott's first customer.
We did a lot of back and forth, and he got me my adapters just in the nick of time!
The adapters were exactly the same as I've seen picture of Kiwis.
This is what I got from Scott :)
There are pinch bolts too, just not in this picture. They are working great! :)
Thank you to Kiwi and Scott!
Add your bike to the Unofficial E-Bike Garage! - http://spreadsheets2.google.com/ccc?key ... OWcg&hl=en
My Build - Vector Frame, 20s 25Ah LiPo, Max-E, Cromotor - 10.89HP on the Dyno
MAGICPIE3FOCUSPOWER
Post by MAGICPIE3FOCUSPOWER » Oct 02, 2014 2:07 pm
I am not good at English technical terms, but what is pinch bolt?
Thanks 8)
Ps thanks for the pictures, yeah they look exactly the same as Kiwi's ones.
8)
Nothing is perfect until I touch it...
Metallover
Post by Metallover » Oct 02, 2014 2:48 pm
The pinch bolts pinch the axle into the dropout :)
(Not my picture, original Kiwi's I believe)
MAGICPIE3FOCUSPOWER
Post by MAGICPIE3FOCUSPOWER » Oct 03, 2014 11:02 am
Thanks for your clearing up.
8)
millzy555
Post by millzy555 » Mar 24, 2016 2:11 am
Can someone tell me if these are still being made?, Have my eye on a DH comp
Obiwan007
Post by Obiwan007 » Mar 24, 2016 11:10 am
Yes these are available from ES member "Scott" got mine a few months back.
ScooterMan101
Post by ScooterMan101 » Oct 08, 2016 11:58 pm
Bump,
Anyone in the U.S. making these, and/or making some for other through axle frames ?
Scott
Post by Scott » Oct 09, 2016 12:33 am
Hi ScooterMan,
I am currently working on making some more. As we speak, I am making some slight adjustments to them so they will drop right into the frame without any filing needed!
Trek Liquid 10 9c 48v 10ah, top speed 28.5 mph. 55.2 mph down a steep hill. - sold
Giant DH Team build https://endless-sphere.com/forums/viewto ... =6&t=51106 top speed 70 mph
Scott
Post by Scott » Dec 31, 2016 8:38 pm
Hi all,
Below are some slight changes I have made to the adaptors. First, they don’t need to be filed down anymore to fit into the frame so they will just slide into the frame smoothly.
Here is a picture showing the diffrence, the top layer is how the new dropouts look and the middle part is the old version. This adjustment was made to both sides. The adaptors were 3D printed numerous times to insure a perfect fit!
The other change is to make a few of the brake side adaptors with a longer dropout. For motors that have the wires come out underneath the axle, the pinch bolt can’t be used. Here is a picture of a Cromotor for example:
This is what the extended dropout version will look like:
Brake side longer dropout v2.png (98.75 KiB) Viewed 520 times
Below where the motor axle sits, the dropout is spaced out 3mm on each side so the motor will drop in easily and to make room for the wires.
With that said, if anyone has any comments, let me know.
For those interested in buying these adaptors please post below and state if you would like the extended dropout version for the brake side adaptor or not.
Obiwan007
Post by Obiwan007 » Jan 01, 2017 2:52 am
Of course, I say yes for the new version with the extended drop-outs :wink:
madmaxNZ
Post by madmaxNZ » Nov 26, 2017 5:40 pm
Hi,
Are you still selling the dropout adapters for the Giant DH?
If so, the non-extended version will do.
Please reply to max.banks@scorch.co.nz.
Kind Regards
Max
"The Rib Breaker": Giant DH Comp, Crystalyte H4080 & 50A controller, 24s LiPo 15AH.
