Giant DH Comp Drop Out adapters and conversion
Re: Giant DH Comp Drop Out adapters and conversion
Postby Kiwi » Fri Feb 17, 2012 10:28 pm
hmm.
You perhaps could have wedged a screwdriver in the axle clamp to open it up a bit. It would seem there is some dimensional differences between different bikes. I had 2 swing arms here to try on each. Also check that the boss is square with the adapter plate, that the welding has not caused it to pull to one side a bit.
The gaps ok. Looks like the adapter has pulled right up.
Nice to see a bike in the vice.
Kiwi
Postby GCinDC » Tue Feb 21, 2012 9:08 am
kiwi, i've been a busy beaver trying to finish my build but just want to thank you for taking all the time you did to make this thing up! if you factored in your time, they should cost more like $1000, no?
it took a bit of work, but now that they're in, i feel so much more confident in the rear wheel than i ever have with my other rides.
thanks so much for the extra work, especially considering whatever challenges popped up in your life.
oh, btw, the adapter slots were about 9.6x wide? my 9C and hs3540 were about 9.85, so there was a little filing to do, and i found i could file both slots at the same time, ensuring the file was flat (instead of rounding the slot), and in the same line as the axle.
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby Kiwi » Wed Feb 22, 2012 3:16 am
Thanks heaps. Happy to help.
Kiwi
Postby binlagin » Wed Feb 22, 2012 10:03 am
I received my drop-outs last night!
20 minutes of filing and grinding and they slipped right in!
Actually... my cro-motor slides in easier then my HS. Who woulda thought?
Thanks alot for all the hardwork Kiwi! The wait was WELL worth it!
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby crusoe » Wed Feb 22, 2012 2:32 pm
2x to what binlagin said! Thanks for the awesome work kiwi!
crusoe
Postby Kiwi » Tue Feb 28, 2012 1:55 pm
Second lot of adapters have been cut. Moving in to my shop this week, so might be next week to put them together.
Kiwi
Postby Duc998 » Tue Feb 28, 2012 5:07 pm
woooohooo! thanks kiwi I've been trying so hard to be patient :mrgreen:
Just in time too for me, My pannier rack snapped yesterday due to the battery weight on cheapy ebike build. Cant wait for the stability of the dh comp.
Giant DH Comp 03 build in progress 72v 18s3p 9C 9x7 12fet Infineon controller set 45amps
Duc998
Postby GCinDC » Sat Mar 10, 2012 4:26 pm
Kiwi wrote:I did my best but hold no responsibility if you tear your bike and your self apart putting 15kw into a CroMotor or something silly like that.
I'd never hold you responsible, so rest easy.
Just thought you'd be glad to know the adapters are just fine after a little abuse :twisted: :
GCinDC
1 GW
1 GW
Postby Kiwi » Wed Mar 14, 2012 8:49 pm
Thats awesome! Love your storm trooper son! Enjoy.
To others that are waiting, keep waiting.
Going to weld up second set of adapters tomorrow, all going well.
Kiwi
Postby darkone040 » Mon Apr 02, 2012 4:30 am
i dont have the skills or knowledge to do this but would it be possible to extend the dropouts 1 or 2 inches to make extended swingarms
or would that put too much strain on the three bolts that are holding the dropouts onto the swingarm. thinking of for high power applications so no wheelies
less weight means more fast
darkone040
Postby shorza » Mon Apr 02, 2012 7:50 am
shorza
Postby Kiwi » Mon Apr 02, 2012 4:50 pm
hmmm, horizontal dropout swingarm extension. I think it would kill the bolts. It would be a from scratch redesign.
Might be better to mount a battery on the front forks to keep the front down.
Kiwi
Postby darkone040 » Tue Apr 03, 2012 9:51 am
hmm yeah thoguht it might, cheers for the reply
adrian
darkone040
Postby GCinDC » Tue Apr 03, 2012 10:10 am
seems it's been a couple months and just checking in to say that i've been changing the wheel a lot lately, and am very pleased with how easy this adapter makes it.
i just flip the bike, loosen the axle bolts, remove pincher bolts - i have to wedge a screwdriver where the nut is to keep it from moving, but that works fine. then i draw the derailleur out of the way and wiggle the axle up and out. i really wish i had 150mm dropouts, that's for sure, and the only challenge is to make sure the disk doesn't bend against the side coming out, and spreading the frame a little bit to get the axle in.
GCinDC
1 GW
1 GW
Postby dnmun » Tue Apr 03, 2012 12:53 pm
greg, from that picture it looks like the threaded part of your axle is bent. i guess it is no matter now since the cover sheared off.
dnmun
Postby GCinDC » Tue Apr 03, 2012 1:10 pm
hey dennis!
dnmun wrote:greg, from that picture it looks like the threaded part of your axle is bent. i guess it is no matter now since the cover sheared off.
the bent axle is that of the hs3540, which strips easily and appears not to be very hard.
the sheered side cover is old rounded 9x7, hence the threaded flange. that 9x7 axle is very hard. i've been swapping them out over and over these last couple months, so sorry for making it confusing.
GCinDC
1 GW
1 GW
Postby pchen92 » Sun Apr 08, 2012 3:26 pm
Hi,
I have bought a Giant DH team today. Wonderfull bike :D
My rear spacing is 140mm, is there any adapters left ?
Thanks :mrgreen:
pchen92
Postby shorza » Fri Apr 13, 2012 8:47 pm
I too are after these.
PM has been sent.
shorza
Postby Kiwi » Mon Apr 16, 2012 5:43 pm
I made 5 more, but I think they are all accounted for.
Can do another run of 5.
Heres the order status
Second run (post this week)
6.moonshine -paid -shipped
7.shorza -paid-shipped
8.Steevetooke -Paid -shipped
9.Duc998 -Paid - shipped
10.pchen92 -paid -shipped
Third run (3-4 weeks)
11.Kiwi (me, one day I will have my bike running!)-not paid
12. Jeremy-NZ
13. Max Banks-NZ
14. Smedge
15.
WARNING!! He who pays first gets first.
Kiwi
Postby moonshine » Fri Apr 27, 2012 9:41 am
Kiwi,
Have you shipped the dropouts to the people leftover in the second run?
03 Giant DH comp w/ 05 swingarm, cromotor in 26" large marge, Kelly KBL96251, 24s4p
Build Thread: viewtopic.php?f=6&t=40031
moonshine
Postby shorza » Fri Apr 27, 2012 10:15 am
I got this reply from kiwi on Monday:
You should see the adapters in the next 10 days based on shipping estimates.
shorza
Postby moonshine » Fri Apr 27, 2012 10:36 am
SWEET thanks shorza. I'm in the US so it should probably take a little longer for me. You haven't received yours yet? Even after a week? hmmm...
moonshine
Postby Alan B » Fri Apr 27, 2012 10:39 am
Nice adapter, Kiwi.
Alan B
1.21 GW
1.21 GW
Postby shorza » Fri Apr 27, 2012 4:36 pm
He did say within 10 days, it's only been 5. Give it another week at least.
shorza
Postby pchen92 » Sat Apr 28, 2012 4:29 pm
For me too it'll be a little longer I think.
pchen92
PreviousNext
Who is online
Users browsing this forum: loco13 and 10 guests
