Sirius e-bike
Sirius e-bike
Postby sirius » Wed Nov 23, 2011 4:22 am
Hello! I live in Croatia. My English is bad, excuse me, but the bike is good. :) I was made ​​a 48V 45A Nine Continent kit. I had a box made ​​of reinforced polyester. Controller have been replaced. The first was Infineon 9FET. I ride on Chinese 45A 15FET now.
After 5000km.......... :)
sirius
Re: Sirius e-bike
Postby dogman » Wed Nov 23, 2011 8:12 am
Seriously nice battery boxes. Too bad about the rim crack. One reason I'm such a fan of full suspension. That and my back is messed up.
dogman
Re: Sirius e-bike
Postby sirius » Wed Nov 23, 2011 9:04 am
dogman wrote:Seriously nice battery boxes. Too bad about the rim crack. One reason I'm such a fan of full suspension. That and my back is messed up.
You're right. I am searching the full suspension, too. Next year probably. Fat tires can help, maybe. And tires not much inflated.
I've put sunstour parallelogram, my ass and back are much better. :D
sirius
Re: Sirius e-bike
Postby sirius » Mon Nov 28, 2011 6:54 am
I bought this controller from the Chinese through the internet. Maybe someone has an idea how to reduce current or programmed? The box is written on the outside only 45A. I want to connect the USB cable. I am waiting for HS3540 currently. I ordered of the Crystalyte Europe. I paid and I hope to have a quick delivery. For HS3540 45A is ok? Currently I have the Nine Continent 2807. Enough is heated to climbing uphill. I'll be very grateful for the information.
My unknown no name controller
back
sirius
Re: Sirius e-bike
Postby sirius » Mon Dec 12, 2011 6:31 am
I put new HS3540 motor. Everything what people says is true. I opened the engine immediately. I pulled out a rubber ring, extended opening beside ball bearings. I put a copper pipe couplings, diameter 18 mm. The engine works well. Feel a lack of strength up to 30 km / h, but later it is faster then for 10 kilometers. I am not impressed. Cro engine is much stronger, brutally. Comparison is ridiculous. Climbing uphill is faster with a cromotor with 36V and 40A than the HS with 48V and 40A. Cromotor is no heat ......
Here I have inserted a small copper tube and there is no chance of anything more damaging wires, because the tube is in place with the axle.
sirius
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 6:35 am
My HS has a problem with the temperature. Climbing into the hills it warms. I have a 48V and 45A. The engine is quick, light, and can accommodate lots of gear. For faster cooling I glued the aluminum profiles. It works well. Heat sinks are a lot faster.
HS3540
(185.98 KiB) Downloaded 3 times
sirius
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 6:39 am
I got another idea recently. I need to install Cromotor. Cromotor may not have a problem with heat. :idea:
I bought a full suspension frame.
sirius
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 6:51 am
I made a model for the battery box, adjust the rear fork for Cromotor.
sirius
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 6:58 am
Axle went on the lathe. She sat perfectly.
sirius
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 7:01 am
Cromotor has enormous momentum. I need to do something for the rear suspension fork.
sirius
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 7:05 am
Cromotor need to feed. I put the battery pack of 48 pieces Headway 10Ah.
(140.71 KiB) Downloaded 3 times
(185.92 KiB) Downloaded 3 times
sirius
Re: Sirius e-bike
Postby Rodney64 » Sat Jun 16, 2012 7:09 am
Very nice build, the aluminum profiles how does it reduce the temperature? Im currently gathering components for my first build using crystalyte H3580 in a hot summer climate. Rod
Rodney64
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 7:13 am
I haven't yet assembled chain. I don't need him. No more heat per hill, with 48V and 50A. A cold, like it doesn't work. :mrgreen:
(124.58 KiB) Downloaded 3 times
(140.59 KiB) Downloaded 3 times
sirius
Re: Sirius e-bike
Postby kfong » Sat Jun 16, 2012 7:19 am
Nice job on the composite battery cases.
kfong
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 7:23 am
I put a Schlumpf drive. Requires special tools. I made ​​it personal.
sirius
Re: Sirius e-bike
Postby TylerDurden » Sat Jun 16, 2012 7:37 am
Excellent work and pictures. :D
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Re: Sirius e-bike
Postby sirius » Sat Jun 16, 2012 8:14 am
TylerDurden wrote:Excellent work and pictures. :D
Thanks.......... :)
sirius
Re: Sirius e-bike
Postby MattyCiii » Sat Jun 16, 2012 12:14 pm
Love that DIY Schlumpf tool! Real ingenuity.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
MattyCiii
Re: Sirius e-bike
Postby Trackman417 » Wed Jun 27, 2012 9:00 pm
NIce work on the bike! I am a big fan of your torque arm solution and your battery boxes :!:
What are you using to make your battery boxes? Fiberglass?
What are you painting the battery boxes with?
Everything looks so clean and professional. Wish I could work with composites like you can :(
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
Trackman417
Re: Sirius e-bike
Postby sirius » Thu Jul 12, 2012 3:56 pm
Trackman417 wrote:What are you using to make your battery boxes? Fiberglass?
yes, I'm using fiberglass
sirius
Re: Sirius e-bike
Postby sirius » Thu Jul 12, 2012 4:00 pm
Trackman417 wrote:What are you painting the battery boxes with?
the paint two layer, the base pearl plus the clearcoat
sirius
Re: Sirius e-bike
Postby sirius » Thu Jul 12, 2012 4:02 pm
Trackman417 wrote:Everything looks so clean and professional. Wish I could work with composites like you can
I have experience in working with plastic, not complicated, you should try
sirius
Re: Sirius e-bike
Postby Trackman417 » Sat Jul 14, 2012 8:41 pm
I sure will :D
I will send you a PM, when I get the everything together to work with fiber glass, and to make sure the stuff I buy will work :mrgreen: .
Thanks in advance :D
K2 Sidewinder
H4065 36 mph
Trackman417
Re: Sirius e-bike
Postby sirius » Sun Jul 15, 2012 5:11 pm
I sure will :D
ok, no problem
sirius
Users browsing this forum: No registered users and 8 guests
