"Strong" Build. pic heavy.
Postby Brentis » Thu Dec 15, 2011 1:35 pm
Started with this.
Strong GT S top class e bike my left nut.
Bought it used locally for $400. originally sold from Canadian Tire for 800-1000.
More than I wanted to pay, but I could not make/have made a frame like this for less. So I splurged.
He had new batteries put in to sell it, so now I have a new 30lbs lead weight.
I plan for this build to be a fast street bike. :wink:
Strong minus some dead weight.JPG (58.88 KiB) Viewed 2827 times
Doesn't look a race bike yet.
Strong. 20's mounted. Looks like a race bike to me..JPG (57.12 KiB) Viewed 2828 times
That's a better stance. :mrgreen:
Strong. 20inch HS3540 52v11.5ah.JPG (56.11 KiB) Viewed 2827 times
Now with some power. a123 pack.
Just a pic. though.
Strong demands Lipo. :twisted:
Dropouts are massive. 175mm wide without wheel installed.
175mm dropout. no wheel. Can squeeze or stretch, being steel..JPG (54.79 KiB) Viewed 2827 times
Being steel the swingarm can be squeezed, stretched, welded. Beautiful.
All steel, flat, 10mm 175mm wide dropouts. Lovely..JPG (51.64 KiB) Viewed 2827 times
Factory torque arms/wire protection.
side of torque arm.JPG (49.99 KiB) Viewed 2827 times
inside of torque arms.JPG (46.2 KiB) Viewed 2827 times
Unknown motor.JPG (53.86 KiB) Viewed 2827 times
This is the original motivator.
Brushed 36v 500w peak.
Only 16lbs. laced in rim with tire, screw-on brake, 7spd freewheel.
Pretty light actually.
Since "Ghetto" donated it's motivation.
The Motor Crystalyte HX 3540 mounted in 20 inch wheel..JPG (209.59 KiB) Viewed 2827 times
I may try fitting it on the Miyata. single speed lady bike. Options.
The future includes
Fork/shock upgrade.
Cycle Analyst
Lipo @ 88.8v 40amps to start. I am looking for an honest 60+kmh.
according to the simulator I am looking @ 66kmh. Perfect.
Maybe real brakes on this build. :wink:
Lots more to come
Stay tuned...
Ghetto Build 1.
ScootBike Build 2...
Strong Commuter Build 3...
Brentis
Re: Strong. Build.
Postby spinningmagnets » Thu Dec 15, 2011 9:09 pm
This isn't a common shape of frame, but I like it a lot. Regardless of battery chemistry, that is a great place to put the weight. It seems that male bicyclists in the USA still do not want uni-gender frames, and this seems to be a good compromise that allows a low top-bar for a comfortable stand-over height, while still "looking" as strong as traditional male frames.
edit: Nice upgrade on the gas shock, I hear they are a big improvement (though pricey)
Last edited by spinningmagnets on Thu Dec 15, 2011 9:20 pm, edited 1 time in total.
spinningmagnets
Re: Strong. Build.
Postby Gordo » Thu Dec 15, 2011 9:17 pm
+1 :D
I was just thinking the same thoughts. Practical, has (HAD) disc brakes and strong layout, with a good 48V battery and a 1KW frock, off we go with a simple first build for anyone.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Re: Strong. Build.
Postby Philistine » Thu Dec 15, 2011 11:38 pm
That is an awesome frame to work with, so many options. You will be able to fit a stack of lipo into that cross bar area.
Philistine
Re: Strong. Build.
Postby biohazardman » Fri Dec 16, 2011 12:07 am
I like the frame as well nice find. Looks like a dream for an RC build with that 20 inch wheel in there
Just pretend that everything is OK maybe no one will notice.
Golden Motor Schwinn first build http://goldenmotor.com/SMF/index.php?topic=279.0
Giant BMC build viewtopic.php?f=6&t=235&start=390
Short ride vids viewtopic.php?f=3&t=20346&start=60#p321703
biohazardman
Re: Strong. Build.
Postby dogman » Fri Dec 16, 2011 7:56 am
Perfect frame really. Just bolt or weld angle iron to the dropouts, and convert it to a pinch style dropout. screw the factory torque arms. It should corner really smooth with the battery there, possibly a tad low, but definetly carried good in the center.
Here's my 1/4 thick 1" x 1" angle pinchers.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Re: Strong. Build.
Postby Ykick » Fri Dec 16, 2011 8:29 am
Looks like a great frame! Perhaps upgrade the suspension fork/shock but it looks like a great place to stash Lipo or whatever chemistry you choose.
Ykick
Re: Strong. Build.
Postby Brentis » Fri Dec 16, 2011 1:06 pm
Thanks Guys.
This frame is what sold me. Components can be upgraded simply enough.
Unless you can weld, attaining this bike as a rolling chassis is a great find.
I only have basic hand/bike tools and almost no room for my bikes, let alone, Proper shop tools.
Bonus :wink:
dogman wrote:Perfect frame really. Just bolt or weld angle iron to the dropouts, and convert it to a pinch style dropout. screw the factory torque arms. It should corner really smooth with the battery there, possibly a tad low, but definetly carried good in the center.
The attachment mongoose pinch dropout.JPG is no longer available
My thoughts exactly :mrgreen:
I have been inspired by your set-up for sometime now, Dogman. :)
I may drill and bolt up a couple pcs of angle. I don't weld.Yet :wink:
If I can save up my pennies/patience,
I would really like to epoxy or weld up a proper pinch set-up to the inside of the swingarm.
Making just about any motor compatible.
The caliper mount needs to move way in/disc way out to be compatible w/HS3540.
Maybe incorp. onto pinch dropout.
Lots of room. 20mm Min. Would give clean look on the outside. :wink:
I want to keep as manufactured a look as possible.
Ignore bad camera angle. Looks like the swingarm is pinched, but nuts are finger tight.
20mm room for inside clamping dropouts.1.JPG (58.89 KiB) Viewed 2671 times
Caliper removed.1.JPG (81.56 KiB) Viewed 2671 times
Cut off the wheel lock. Paint. Should look good.
dogman wrote:...screw the factory torque arms. ...
The protector and the dropout.JPG (42.29 KiB) Viewed 2671 times
Yeah. the tang on the right is the anti-torque device.
To small for the 10mm flat C-lyte. :roll: An opportunity. :!:
What's wrong here? :roll: Can't believe I didn't notice earlier.
Rear shock. Installed upside down.Duh.1.JPG (60.28 KiB) Viewed 2671 times
spinningmagnets wrote:This isn't a common shape of frame, but I like it a lot. Regardless of battery chemistry, that is a great place to put the weight. It seems that male bicyclists in the USA still do not want uni-gender frames, and this seems to be a good compromise that allows a low top-bar for a comfortable stand-over height, while still "looking" as strong as traditional male frames.
If the zoom fork is a tell. This shock is nothing special.
Both came standard.
Both will eventually be upgraded.
Interesting,I never considered this bike unisex. :)
Since I don't wear a dress, and mount like cowboy, I was blind to it. :lol:
A few more pics.
Could probably be mod. for 16s Life4po. Cycle Analyst eventually.1.JPG (53.75 KiB) Viewed 2671 times
Standard Sla installed.JPG (65.16 KiB) Viewed 2671 times
Using a dusty exc.bike as a bike stand. Dont be fooled by random bike parts in photos ;  ).1.JPG
Using a dusty exc.bike as a bike stand. Dont be fooled by random bike parts in photos ; ).1.JPG (53.99 KiB) Viewed 2671 times
out with the old, on with the new 1.JPG (59.71 KiB) Viewed 2671 times
Stay tuned...
Ghetto Build 1.
Brentis
Re: Strong. Build.Pic Heavy.
Postby Brentis » Fri Dec 16, 2011 6:54 pm
A few more pics/comments.
The old, bagged up & ready to go..JPG (52.87 KiB) Viewed 2636 times
The old, 3Quarter.JPG (52.03 KiB) Viewed 2636 times
Lining the rear wheel up..JPG (60.44 KiB) Viewed 2636 times
rear dropout brake side.JPG (62.89 KiB) Viewed 2636 times
Gutted of old spring contact power transfer..JPG (49.49 KiB) Viewed 2636 times
30lbs. o' Lead. 18 x 4.5 x 6 approx. intenal..JPG (59.26 KiB) Viewed 2636 times
Ignore measurement from pic.
Internal space is 18"L x 4"+w x 3.5" deep.
I am planning to reuse the battery case.
Modifying it to open, for monitoring purposes.
Hope to fit 24s 2p. Lipo. 8ah format would be sweet.
Time to skim hobby king for measurements. :wink:
See what combo I can come up with.
Stay tuned...
Ghetto Build 1.
Brentis
Postby spinningmagnets » Fri Dec 16, 2011 7:19 pm
I don't want to sound like I'm being picky about a great frame, I just want to take this opportunity to point out some things I think will be useful if someone wants to weld up something similar.
Some frames have the pivot for the rear suspension arm ON the rear sus arm, and some have it on the main frame. By having it on the rear-sus arm, chain stretch and derailler cycling is reduced when the rear-sus arm cycles during compressions. As another option, if the pivot is on the main frame, it opens up the option for a BB_drive, and giving the motor some gears (at least two, and 3 is better) dramatically reduces motor+controller heat, and also spreads out the motors performance envelope across a wider range of speeds.
Another minor frame-choice variation is the rear-sus arm that is shaped like an "on its side" letter C, with no lower chain stay. A chain doesn't need to be broken or re-linked to take it off or on, plus...the lack of a lower chain stay also means its easier to experiment with a variety of non-hub solutions.
Concerning the two top bars, I like the shape because it allows a battery cradle that loads and unloads from the top, A minor variation that I want to suggest is a longer head tube to give that joint better strength, if the head tube was two inches longer, the two top bars could be two inches higher, and I would go so far as to suggest using ractangular tube for the two top bars rather than the common round tube. That would be just as strong, and slightly thinner while allowing the same width of battery pack.
Either way, I am glad to see frames like this being produced, and I will point to them as examples that have specific benefits that should be more appreciated...
spinningmagnets
Postby joe tomten » Sat Dec 17, 2011 2:11 pm
I do in fact want to weld something together, and my eye is on a 20 or 24" wheel, suspended longtail thing.
This is a great find, and the dual tube battery carriage and x-frame support structure makes a whole lot of sense.
Been collecting a few craigslist steel frames to start practicing on. But the whole suspension situation is a little overwhelming to jump into without a physical model on hand to relate to.
That along with the desire to do something w/regards to a jig set up that would help me keep the whole thing under control during setup and brazing.
joe tomten
Postby nicobie » Sat Dec 17, 2011 2:51 pm
I wonder where a guy could find one of those?
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Brentis » Sat Dec 17, 2011 6:41 pm
nicobie wrote:I wonder where a guy could find one of those?
This was a craigslist special.
Hunt all the local sources.
Eccentric LBS's, hock/pawn shops, flea markets, etc.
The Strong is at least 4 years old, the tech. even older :roll:
I believe I found a frame like this years ago @ the LBS, marketed as a Powabyke.
Looks like modern Powabyke's are a little different set-up though.
I am fortunate that in my area, there is more money than brains.
Lot's of examples, of year old unattended/dead batt. bikes and scooters.
Classifieds are littered with them.
Be patient,hunt, then jump when you find a good one.
Good luck.
joe tomten wrote:I do in fact want to weld something together, and my eye is on a 20 or 24" wheel, suspended longtail thing.
spinningmagnets wrote:I don't want to sound like I'm being picky about a great frame, I just want to take this opportunity to point out some things I think will be useful if someone wants to weld up something similar.
P.S.
As I tear down and rebuild Strong. I will take lots of pics and measurements.
As some may like to weld something similar up.
Ghetto Build 1.
Brentis
Postby Brentis » Sat Dec 17, 2011 6:59 pm
A few more updates...
Shock, battery, kick stand removed..jpg (105.7 KiB) Viewed 2521 times
Look @ that stance. Chopper style?
Bolt up a small bar/arm where the shock was, and you have a Lowriding Hardtail :?:
Shock removed..jpg (108.14 KiB) Viewed 2521 times
The other side
KS Kind Shock 261..jpg (107.72 KiB) Viewed 2521 times
Anyone have real world experience with this?
Research doesn't find much.
So much space..jpg (106.02 KiB) Viewed 2521 times
In a flurry of parts removal, I cut the cable to the rear derailer. :roll:
Though I use 1 of 7spds, 11 tooth.
I'm gonna need that for easy chain line adjustment. D'OH
Call it 15mm space..JPG (53.64 KiB) Viewed 2521 times
Maybe inside pinch bolt with integrated derailer mount.
Local delicacy.jpg (105.24 KiB) Viewed 2521 times
Actually quite nice. Spicy Cock Soup :lol:
Stay tuned...
Ghetto Build 1.
Brentis
Postby Hobbit » Sat Dec 17, 2011 9:38 pm
A builder of e-bikes AND a lover of spicy cock soup!!!!!!
Brentis....are you married? :oops:
"The Precious"
Rans Fusion, Crystalyte H4080, Crystalyte 75V 50A stock controller,
66.6V 18s3p 24Ah zippy lipo.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=37934
Love.
Hobbit
Postby Brentis » Sat Dec 17, 2011 10:57 pm
Sorry Hobbit.
I share my spicy cock with another.
Ready for a hot bowl..JPG (51.61 KiB) Viewed 734 times
Looks like someones hungry :lol:
Seriously though,
my baby.JPG (56.35 KiB) Viewed 738 times
I love her. We are engaged.
She picks me up when I am down.
Supports me in every way.
I use the kitchen as a bike shop.
If that's not love, I don't know what is. :mrgreen:
I just love Chinglish. Other miscommunications.
I can be easily amused.
Local delicacy.jpg (105.24 KiB) Viewed 732 times
That is the best example I have found yet.
Come on.
If you are going to export to a foreign country....
Unless this is only made of male chickens. :roll:
That is a mighty bird on the packet.
Ghetto Build 1.
Brentis
Re: Strong. Build. pic heavy.
Postby mushymelon » Sun Dec 18, 2011 12:35 pm
Great start Brentis. I've got mine stripped down and taking measurements. Two 6s lipos fit perfect side by side in the frame, two high possibly three high under the seat. Im thinking 24s3p. Every time i read the lipo threads, I get a little overwhelmed. I hope the Zephyr is finished soon.
Im thinking of modifying the front of the frame where the steer tube is to accommodate for dh triple crown forks. looks may improve too.
Kitchen workshop thats great, my shop is freezing right now.
This is great inspiration, should be fun to see how these Stong builds turn out.
Custom Strong build
viewtopic.php?f=6&t=45719
mushymelon
Postby Brentis » Sun Dec 18, 2011 1:14 pm
mushymelon wrote:Great start Brentis. I've got mine stripped down and taking measurements. Two 6s lipos fit perfect side by side in the frame, two high possibly three high under the seat. Im thinking 24s3p. Every time i read the lipo threads, I get a little overwhelmed. I hope the Zephyr is finished soon.
Thanks Mushy.
Apologies for misleading you on measurements earlier. :roll:
I don't know where I came up with 210mm dropouts.
Our communication about the Strong frame, really got the ball rolling for me.
I have had this bike sitting around since May. Only rode it a couple of times.
"Ghetto" was so much more fun.
So "Rat Scoot" will stay as is for now,
and I will combine "Ghetto" with "Strong" as a winter project.
I really like how it looks/ feels.
Nice cockpit for my 5'9" 200lb mass.
LiPo can be daunting. Read all the, for noob links. Then read them again.
I still am apprehensive, but willing to learn.
You just cant beat the size and power of LiPo.
In addition to the Zephyr,
Consider Method's boards.
http://www.methtek.com/2011/11/12/lvchvcparallel-boards-10/
Or, I'm considering
http://www.hobbyking.com/hobbyking/store/__10952__Cell_Log_8M_Cell_Voltage_Monitor_2_8S_Lipo.html
1 for each pack. Easy constant monitoring.
Options.
I really hoped to reuse the stock battery box, but am having a hard time getting more than 24s1p in it as is.
Likely have to build a battery box of my own, to take advantage of the open battery cage.
I plan my first upgrade to be a proper fork.
Dual crown DH, if it'll fit. I have yet to remove mine for measure.
No more speculation. :roll:
Will a 1 1/8" fork work, what modification do you think we need?
I will stay tuned to your build to see what you come up with.
Best of luck.
Stay tuned....
Ghetto Build 1.
Brentis
Re: "Strong" Build. pic heavy.
Postby Brentis » Sun Dec 18, 2011 1:49 pm
For those following this build, thinking they would like to try and weld up something similar.
Check out this build thread.
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=27859
Beautiful work.
Similar concept as Strong, but looks even stronger.
Top job Tri-lobe.
Ghetto Build 1.
Brentis
Postby Brentis » Wed Dec 21, 2011 1:07 pm
Some more pics for consideration.
swingarm pivot. quarter inch thick tang's.JPG (57.02 KiB) Viewed 663 times
2 1/2" across, 1/4" tangs.
Is this sufficiently strong for 20lbs wheel @60kmh?
Lateral strength?
I guess I'll find out :roll:
BB on swingarm.JPG (52.65 KiB) Viewed 663 times
Bottom bracket is a part of the swingarm.
Should have minimal chain growth, if I'm not mistaken.
With the horizontal dropouts I should be able to run a single speed.
No derailer. Simple. The way I like it. :mrgreen:
Front of swingarm narrowed for unwanted front derailer...JPG (60.44 KiB) Viewed 663 times
Could have been alot stronger.
Damn that front derailer.
Plenty of room for a 3inch rear tire..JPG (62.28 KiB) Viewed 663 times
Would love to run a proper Moped tire.
Pirelli ML75 16x 2.75" should fit.
More to come...
Ghetto Build 1.
Brentis
Postby Brentis » Thu Dec 22, 2011 5:08 pm
More pics of the dirty Pivot area.
Minimal chain Growth.jpg (107.73 KiB) Viewed 635 times
BB on swingarm.JPG (52.65 KiB) Viewed 635 times
Strong. swingarm space.JPG (56.86 KiB) Viewed 635 times
6" between front of triangle and the tire.
RC :?:
Lots of options.
I received a PM from a member asking to buy the unknown brushed geared hub.
Hub only. I have other plans for it
http://www.endless-sphere.com/forums/viewtopic.php?f=9&t=34819
He has been searching the classifieds for two years.
Currently has 3 frames. Wants low mileage motors :wink:
He has paid as little as $150cdn for a toast battery example.
Great deal. We are lucky both being in southern ontario.
Lots of used Ebike choices.
This model offers the most upgrade potential.
Very Noob friendly dropouts.
I want 1 more roller, to build a pair. :mrgreen:
Nice to ride with someone on similar paced machines.
Anyways I have competition now.
Ghetto Build 1.
Brentis
Postby heathyoung » Thu Dec 22, 2011 10:16 pm
Pleanty of room for a controller at least!
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby Brentis » Fri Dec 23, 2011 12:28 pm
More Pics..
The Old and the Real.JPG (56.89 KiB) Viewed 616 times
The Old and the Real2.JPG (54.2 KiB) Viewed 616 times
The Battery case can handle 16s4p a123 cyl.
Unfortunately I have 16s5p. D'oh.
Custom battery box for me.
Chilwee indeed. lol.JPG (53.58 KiB) Viewed 616 times
What you see, is what you get.
No stats or info. :roll:
Installed shock into proper postion2.JPG (70.29 KiB) Viewed 616 times
Installed shock into proper postion3.JPG (70.61 KiB) Viewed 616 times
Hope using it upside down didn't damage it.
Front tire Kenda K-Rad 20 x 2.125.JPG (61.48 KiB) Viewed 616 times
Lots of tread left.
Rear Kenda K-Rad 20 x 2.125.JPG (58.39 KiB) Viewed 616 times
One to many burnouts. :mrgreen:
90mm drum.JPG (75.36 KiB) Viewed 616 times
90mm Front Drum. I like..JPG (60.96 KiB) Viewed 616 times
90mm. Designed for cargo bike use.
I'm comfortable with this and regen. upto 60kmh.
Ghetto Build 1.
Brentis
Postby Brentis » Fri Dec 23, 2011 12:45 pm
A couple more...
Another angle.JPG (62.69 KiB) Viewed 615 times
Low rear third.JPG (65.57 KiB) Viewed 615 times
Lookin down..JPG (57.86 KiB) Viewed 615 times
Does fit long(16s).JPG (61.15 KiB) Viewed 615 times
Doesnt fit sideways(5p).JPG (48.56 KiB) Viewed 615 times
Fingers width gap..JPG (57.62 KiB) Viewed 615 times
I will use the drum as long as I retain the Zoom fork.
I will upgrade to hydros with Fork.
This model of fork is surprisingly thick.
The standard anti torque device, wraps around the fork then captures the brake arm,
Sturmey Archer brake arm anti torque device..JPG (73.37 KiB) Viewed 615 times
Sturmey Archer brake arm anti torque device.2.JPG (67.46 KiB) Viewed 615 times
Much to small in diameter for this fork.
Considering I'm more Red Green than Mike Holmes. Eh :wink:
Do you think a piece of wood between brake arm and fork, then a quality hose clamp will hold?
Ghetto Build 1.
Brentis
Postby monkeychops » Mon Jan 02, 2012 11:02 am
I've got a similar bike which I'm slowly upgrading.
I'd be interested to know what kind of torque plate / torque arm you use and whether you re-use the rear disc brake.
Also wondering where I can get a 16s4p a123 battery if it would fit inside the stock battery case...
monkeychops
Next
Who is online
Users browsing this forum: Google [Bot] and 5 guests
