Timma2500 wrote:SnOwy,
Yeah Tench probably has the best charging setup on the site! I'd love to replicate it but wouldn't even know where to start...![]()
I've never seen the DB connectors before, but they might be the way to go. Do you have any pics of your setup? What do you use to charge your 24s pack?
And how do you balance using the battery medics?
I'm an electrical numpty and feel that this side of the build will be the hardest to figure out for me by far...
Paul
EDIT: Ah yes, i've seen those connectors before on pc's etc. Do you have any links on where to buy some?
Timma2500 wrote:Some progress...
CA turned up, thanks Jay!
Battery cover made, screwed on directly with 4 x M5 titanium screws. I'll be charging the batteries in bike this time so no need for a QR.
New seat, WTB V Speed. Same as my last bike had. My current seat cains my ass after a few kms and i end up limping the next day lol.
Placement for the CA in-frame. I'll do some cutouts for the display and buttons. It'll take some getting used to, looking at it at a 90deg angle but i only want to use it as a fuel gauge, mostly when stopping to let the HT cool down so it'll be fine.
Spokes are on the way from Ebikes.ca so it'll be wheel building time again soon, i just rebuilt Mel's BigHit's front wheel lastnight, converting it to 24" to match the rear.
SnOwy - female on the bike side makes sense, good thinking. Are these plugs able to be screwed down to a flat surface?
Yeah i think i'll go for a 37pin as well. Why do the battery medics do that, have you figured out why?
Haha yeah i'd love to copy Tench's setup, if he reveals exactly how he did it i may try to copy it. Maybe...
Paul
M3 is cool, i might have some in my RC spares stash. Tolerance will be ok, i'll muck around with it till i get it right... The cap sounds like a good idea, i'll try thatsn0wchyld wrote:yea mate m3 is the usual sizing i think. they can be a bit of a pita to get a good close fit, as you've only got a mm or less tolerance if you want the screwed down piece to be 100% flush. Mines just mounted in a pvc case so its kinda crude. you can make a basic cap for it by buying another male plug and cutting the pins off the back, and sealing it up with some silicone or similar.
sn0wchyld wrote:I'm guessing the way trench did it was with 2 blocks of plastic, with the internals gouged out to fit the wires/plugs etc, before the two halves were screwed or glued together to form one piece, with all the connections housed internally. damn it makes me want to buy a mill.
sn0wchyld wrote:not sure yet on the bm's. I've got an idea that might reduce the problem, though I need to test it before I know if it'll work at all. It would basically mean you'd use unmodified BM's (less drain current) but in balance mode, so although they take a while to balance a pack, you could set them to start from 3.9 or 4v during a bulk charge, which should give 'em enough time to balance the pack (well enough atleast). I'll let you know how it goes.
Timma2500 wrote:A quicky update:
I ended up getting some 13ga Sapim spokes through Justin @ Ebikes.ca. The HT's oem holes are waaaay too large for 13ga so a quick zip with the drill and a 3mm drill bit sorted that.
One laced wheel. My first hub motor lace-up, bitch of a job but got there in the endJust gotta do some final trueing and tensioning and it'll be good to go.
Next jobs: make a start on the torque arms, cut a hole in the frame / make internal mount for the CA, start on wiring...M3 is cool, i might have some in my RC spares stash. Tolerance will be ok, i'll muck around with it till i get it right... The cap sounds like a good idea, i'll try thatsn0wchyld wrote:yea mate m3 is the usual sizing i think. they can be a bit of a pita to get a good close fit, as you've only got a mm or less tolerance if you want the screwed down piece to be 100% flush. Mines just mounted in a pvc case so its kinda crude. you can make a basic cap for it by buying another male plug and cutting the pins off the back, and sealing it up with some silicone or similar.
Yeah that sounds about right, probably easier if you've got a mill... one day!sn0wchyld wrote:not sure yet on the bm's. I've got an idea that might reduce the problem, though I need to test it before I know if it'll work at all. It would basically mean you'd use unmodified BM's (less drain current) but in balance mode, so although they take a while to balance a pack, you could set them to start from 3.9 or 4v during a bulk charge, which should give 'em enough time to balance the pack (well enough atleast). I'll let you know how it goes.
What do you mean by unmodified BM's? Are your's modded?
Paul
Ta mate! Yeah its got bolt on dropouts but i'll be keeping them on there, can't be bothered to make complete new ones at the moment! I've got an idea for torque arms that will slip in to the dropouts so i'll work with that for now. Nah i won't be extending the wheelbase any more than i have with the front frame extension, that lengthened it by around 80mm which will be heaps.sn0wchyld wrote:lookin very shmick mate! And I've just noticed that you've got removable dropouts on that thing... that'll give you some great options for custom ones! are you going to extend the wheelbase a bit?
Were they getting that hot before you modified them? What mode are they in before 4v? Do you know how many cells each can handle?sn0wchyld wrote:I modded my BM's for higher discharge current, basically adding a 6ish ohm resistor in parallel with the ones that are already there. The main problem is they now really require a fan blowing on 'em to keep em from getting too hot (the resistors can just handle it ok, but the little fets they use get REALLY hot without some air blowing on them). So I want to wire 'em up in such a way that I can use the balance mode, and have each 6s string stay in balance with its neighbours. that way I can leave them unmodded, and have them enter 'balance mode' at around 4v or so.
sn0wchyld wrote:I found recently too that tolerance can be overcome by large amounts of hot glue. I just riged up a 5ah booster pack for my handlebars, best part is its 1 plug to parallel the new 24s 5ah pack with my standard 10ah pack, both at the discharge leads and at the cell level. easy 50+km maniac riding range now!
sn0wchyld wrote:What happened to that ple80 that you bought a while back? is that on a bike yet? I'm already thinking of other options for my mid drive build that'd make mine kinda useless, but at $300 im determined to at least use it once before I get rid of it...
Ossielocal wrote:Now thats a very nice Build .
Kepler wrote:Actually better to use a thin strip of double sided tape across the buttons on the CA and then re fit it. Next cut out some 2 or 3mm thick discs to fit in the holes and stick to the double sided tape. You now have some extended buttons for your CA
Timma2500 wrote:Update: I've ordered the Battery Medics and some 5s harnesses, 2 medics should do the trick for a 20s 10ah pack i think? Anyone?
Hyena wrote:Nice one mate, looking shmick!
Bolts to hold the CA in though ? You butcher
I would have used urethane or silicon or something to stick it on from the inside. Luck the rest of the build is sexy
Fingers crossed you get some good ones, I ordered 5 from HK recently and only 1 was ok, the other 4 were inaccurate as shit.
With 2 medics you can balance half your pack at a time.
Personally if you want a good balance charging solution I'd get a 10S hobby charger and split your packs into 2 10S halves and parallel charge them.
If you want to do an all in one balance connector I recommend centronics over DB25 - they're easier to plug and unplug and it's less likely you'll short pins
Users browsing this forum: comradegerry, EdwardNY and 5 guests
