Hi All
I bit the bullet at the end of last year and decided to wean myself off the car. (I have always wanted to make my own electric car but that's a whole other story!) So I've got a pretty much new 2010 Kona Ute, fitted with Yuba bags as the stock Kona ones liked to take on water.
I've done a fair bit of research and am going with a front mounted eZee motor from ebikes.ca, and a 48V 20Ah Ping battery with high rate BMS and 5A charger. Sure that's a big battery but with a background in electronics I will be able to sleep a lot better at night knowing that I can run the motor flat out and be well within the capabilities of the battery, as well as being able to upgrade the motor later if I need to. It's only a couple of extra kilos and not much more expensive than the 15Ah version
I plan to fit lighting and run it straight from the main battery also which is another reason I opted for the higher capacity. Not sure exactly where I'm going to mount it all yet!
But that will be part of the adventure.
I will probably buy a CA too at some stage but I want to get the basics sorted out first.
Stay tuned for the installation and testing.
