haha thanks fractal, there is so little to show right now...
here is some more pics of the bike, and the hs motors i am going to rewind.
- handlebars.jpg (152 KiB) Viewed 3994 times
- handlebars2.jpg (135.14 KiB) Viewed 3994 times
- leftside.jpg (161.26 KiB) Viewed 3994 times
- right side.jpg (129.7 KiB) Viewed 3994 times
This is the reason for using the Aline 2009; the rear dropouts will be replaced with a custom set cnc'd by our very own magudaman!
- reardroput.jpg (159.53 KiB) Viewed 3994 times
- magnet rings outside.jpg (131.35 KiB) Viewed 3994 times
Here you can see the flange I will need to have machined down so as to get the two magnet sections flush with each other before I epoxy them together.
- magnet rings.jpg (146.71 KiB) Viewed 3994 times
One stator stripped of wires, but the wire cutters I was using gave me horrendous blisters... I will do the other one once I am healed. There is a small flange on the stators that I will also need to machine down, and I will need the axles pressed out and then replaced with a double wide one that I will need to have made. Luckily there is already a keyway in the hs motors, so I don't need to worry about knurling and tapering tolerances, just a shaft that will fit turned on a lathe with a keyway and then the ends flattened somehow to fit the dropouts.
- stators.jpg (146.24 KiB) Viewed 3994 times
I am also thinking seriously about using Makita cells for this build so as to be able to fit them into the frame around the curves. I was sold on Oatnets box on the front idea, until I got the bike and hung my battery backpack from the front. I'm really not sure about the top heavy feeling, and I also didn't like the feeling of overstear that I was getting, like once you started turning the bars one way they wanted to keep going that way. We will see... I am now thinking that with the 8ah nanos out of my price range until september, I will perhaps opt for a much cheaper set of 300-400 makita cells and save money by doing the labor; in that case I will design a full on fiberglass case to fit around the frame and contain the batteries, the contactor, and any other random electronics I may add to this project. I am considering a lot; I may go so far as to get an Arduino and run a control interface on a screen taking readings from thermistors, shunts (i may skip the CA), starting the bike with an rfid tag reader, integrated shifting lights and brake lights... the list goes on. This will be a year long project as far as I'm concerned; it's a bit of a tease to have the bike so early.
