Well, after two rounds of Makita packs from Slycayer, I have some excellent results, and so far I can't thank him enough.
600 cells purchased, 1$ a cell
534 good cells
354 Grade A cells <3.0v
180 Grade B cells <2.5v
Discharge curves show a good average capacity of 2500mah+, with most of the A cells over 2750 discharged at 2c from 4.15 to 3.3 resting.
I will almost certainly shoot for a round number, and will probably go with 40s 12p to use 480 cells which allows me to discard 5 full packs of B cells that are low on capacity. I just stacked 8 of the 5s2p blocks together and it's freaking small. 6 of them will fit easily with some creative racking!
My controller is in the mail. My motor might be mine today; i have class at noon and will find out then.
- ManyMakita's.jpg (143.21 KiB) Viewed 524 times
with 480 18650V at about 50g apiece including the packaging and such, should be about 24kg of cells alone. Then I will probably end up with at least a kilo of wire and solder on that. So maybe 25 kilo battery. Good thing I only weigh 130 lbs soaking wet! Should end up with 2953 watt hours capable of about 27000 watts at 10c. That would be epic. It would probably give me peaks of more then that, but by 30kw there is all ready about 3000w of heat in the freaking motor lol... My controller is "rated" at 300 amps peak, but I will probably keep it at 200 for the sake of it's longevity.
