Giant DH Team, Cromotor, 18fet Lyen, 111v Lipo
Re: Giant DH Team, Cromotor, 18fet Lyen, 111v Lipo
Postby kfong » Fri Jan 27, 2012 1:27 pm
That is not quite true if you are trail riding or doing any type of agressive riding. You use the saddle and frame to hold the line. I've had bruises even from my setup. I am curious about the maximum width that is reasonable for trail use. If all you do is street riding, then I can see you getting away with it.
kfong
Postby crusoe » Fri Jan 27, 2012 2:16 pm
Ya, I agree with kfong. but then again, i'm sure if a body was built around the battery case it would alleviate those problems and turn into a motoX style.
what are you running battery wise kfong?
crusoe
Postby hillzofvalp » Fri Jan 27, 2012 2:21 pm
How man magic shines total do you have, doc? 2 for trike, 2 for dh...
hillzofvalp
Postby kfong » Fri Jan 27, 2012 3:18 pm
I'm currently redoing the battery setup to lipo's this year. I've been avoiding them due to the fire hazard until I had a setup that I felt comfortable with and I think I have a way to prevent the fire from getting out of control. I also had the problem of not fitting 5amp hr packs into my triangle space without making it wider than I liked. I plan to put 14.8 Amp hours in my triangle (12S 6P 2650mah) I was able to keep the width narrow by going with smaller capacity packs. This involves more wiring but I was not willing to sacrifice any pedaling performance. With the way I ride, I know my knees don't stay parallel to the frame. Single track requires a lot of body movement. My battery cover is very smooth and I still get bruises on my knee from time to time. With the new lipo setup, it's just slightly wider than my konions. I would stick with the konions if I could but need the higher capacity and voltage. I'm not even sure the lipos can take the trail abuse, so I will be doing everything I can to keep them secure and protected. The Konions took 3 years of solid pounding and until recently they have shown to be rugged. I had a bad spot weld that eventually failed from fatigue. Here is the build viewtopic.php?f=6&t=12654&start=150
Too bad there isn't more ebikers where I live, I would like to try a bike with such wide packs to see if it's something I could deal with. Moving to 1kw this year but have the rest of the pack in the rear. Not ideal for performance but it's the setup I like currently. I'm only interested in single track trail riding so this bike setup works very well for that. My requirements are a bit different from street riding. The bike gets constantly bashed as well. Even replaced the frame last year.
crusoe wrote:Ya, I agree with kfong. but then again, i'm sure if a body was built around the battery case it would alleviate those problems and turn into a motoX style.
kfong
Postby Doctorbass » Fri Jan 27, 2012 5:25 pm
hillzofvalp wrote:How man magic shines total do you have, doc? 2 for trike, 2 for dh...
2 for the trike,
4 for the DH :twisted:
4 for the mongoose :twisted:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby crusoe » Fri Jan 27, 2012 6:41 pm
How is it running only at 44v kfong?
crusoe
Postby waynebergman » Fri Jan 27, 2012 7:35 pm
I have found a width of battery that works low like under my down tube can be just fine but when I move it up on top of the top tube it is very uncomfortable for pedaling out of the saddle. I have two duplicate packs and tried at one point to put my front fork pack on the top side of the top tube and it was bad. So if its low enough as long as the crank arms clear its fine but up higher your knees may hit bump into things if pedaling out of the saddle. I like my set up with one pack under the down tube and one pack on the front forks up high.............wayne
Link to first build Giant DH-------- viewtopic.php?f=3&t=33849
Mid Drive work in progress--------- viewtopic.php?f=28&t=49467
waynebergman
Postby kfong » Fri Jan 27, 2012 9:18 pm
At first I thought it might be a bit too quick on single track. I like to pedal the whole time. If I'm not tired I'm usually standing and more than half the time peddling. At full throttle I can no longer keep up with the peddling which was a concern. Max speed now is close to 24mph. The good thing is the throttle response is very smooth, so I can usually find a good compromise. It's the higher torque that made me want to go to this voltage. The bike is a riot on hills, the more technical the better. Another reason for the higher voltage and capacity Is I can ride to my trails and get there faster. Then cruise at the slower pace that single track demands. It's very much like tree skiing for me. You need to be focused or you end up eating bark. I'm pretty sure I would not want this setup to be any faster. This bike was built only for single track use. I have other bikes if I need speed, but then it would not be for single track. Even my new DH bike might not be my first choice, since it's more for wider trails. It won't be as nimble. It is setup better for speed and wide trails. I have not ridden a DH Giant, so I don't know if it would be similiar. DH have a higher rake angle.
crusoe wrote:How is it running only at 44v kfong?
kfong
Postby binlagin » Tue Feb 21, 2012 10:54 pm
A quick update and new problem!
It's been a while since my last update but I figure I'd wait until I have some good news to post about!
Today I received my dropouts from Kiwi!
I had todo a little bit of filing to get the dropouts to fit nice and snug. Great work!
Every thing was moving along smoothly... until I slid my cro-motor into place.
As you can see the tire is rubbing on the swing arm. Where do I even begin to start to straighten this out?
I also completed my battery casing with Method's LVC protection. This turned out quite well... it holds 10 batteries inside the frame nice and snug! I've even taken it out and pedaled it around the block and the batteries did not budge. Due to the lack of a proper camera, I apologize for the low quality and low number of photos.
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby briangv99 » Tue Feb 21, 2012 11:25 pm
A bit of dishing should fix that, loosen all the right hand spokes half a turn and tighten the all left spokes half a turn. Repeat if more clearance is required.
briangv99
Postby Doctorbass » Tue Feb 21, 2012 11:31 pm
From what i see, it is not the wheel that is offset, but the orientatio o fthe axel that is angled. If you take a of the wheel alignmebt, it is not parallel to the bike lengh.
Maybe check the torque plate if they are at the correct position.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby waynebergman » Tue Feb 21, 2012 11:39 pm
If you have the time read the thread I just started regarding my Giant DH....... viewtopic.php?f=3&t=37026
Long story short from that post is you may want to get some shorter spokes for the left side and re lace just that side of the rim. Make sure to lace the left side with all the spokes on that side as outbound within the flange. Don't go like normal half inbound and half outbound on that flange. I am going to try 5mm shorter for the left side so I can dish it around 1/4" or so. Kiwi's drop outs are awesome but I think everyone is going to need to do this for a wider tire to sit in the middle of the swing arm. No big deal for me but it also had me stumped for a bit. MadRhino set me straight.
waynebergman
Postby binlagin » Wed Feb 22, 2012 6:13 pm
Dr., is there a way to easily tell if my wheel is properly aligned? I too had the feeling it might be this...
My adapters seem to be installed properly.. maybe they just need a little bit of "encouragement"
100km/h+
binlagin
Postby Doctorbass » Wed Feb 22, 2012 6:26 pm
binlagin wrote:Dr., is there a way to easily tell if my wheel is properly aligned? I too had the feeling it might be this...
Your wheel should be parallel to the triangle frame, that's it.
Here is a little bit of "encouragement" :
Good luck!
You can do it!
Do your best.
Do the best you can.
Work hard.
Keep up the good work.
Take it easy.
Don't worry.
That's okay.
It's going to be all right.
Everything will be fine.
No problem.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby oatnet » Sun Feb 26, 2012 12:30 pm
As Doc points out this is definitely axle alignment, not a dishing issue. Could the right side torque plate be reversed? If you hold the two plates together, do both the original and new axle holes line up?
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby binlagin » Sun Feb 26, 2012 6:27 pm
Thanks for the advice guys.
I have did some shaving with a Dremel to the dropouts and created a little more clearance to center the axel. I ended up dishing the tire a bit as-well... but the tire is lining up alot better now!
Here's a video of me trying out the Cromotor and everything else with a low powered controller. In this video i'm running 44v @ 15AH. The torque on this motor is awesome!
I can't wait to hook up the rest of my batteries and switch the controller for the Lyen, but there is only so much time in the day! At least spring is right around the corner :D
100km/h+
binlagin
Postby fractal » Sun Feb 26, 2012 7:41 pm
nice!!! i just cant wait to ride!!!! nice progress on your bike!!!
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby Accountant » Mon Feb 27, 2012 2:38 pm
44v @ 15AH only ?
Motor will get anorexic.
Very cruel.
Accountant
Postby binlagin » Mon Feb 27, 2012 4:43 pm
Yes, she's starving!
I plan on swapping out controllers tonight for my 18FET Lyen @ 111v! I hope that provides this beast enough juice!I just gotta make sure not to kill the Controller, because I think that will be the limiting factor in my setup!
A question for the electrical guru's... How does Paralleling my batterys pack reduce the amp's being pulled from each Pack configuration? Is it simply divide AMP's being pulled by number of paralleled packs?
100km/h+
binlagin
Postby izeman » Tue Feb 28, 2012 4:45 am
Accountant wrote:44v @ 15AH only ?
15ah is only the capacity of the pack. he didn't mention the current. if it was a typo and he meant 15a current - then i agree -LAME *ggg*
bmc trailfox, mac12t, 12s lipo: viewtopic.php?f=6&t=32267
klein mantra, hs3540, 24s lifepo4, 20" rims: http://endless-sphere.com/forums/viewto ... =3&t=38848
izeman
Postby izeman » Tue Feb 28, 2012 4:50 am
binlagin wrote:A question for the electrical guru's... How does Paralleling my batterys pack reduce the amp's being pulled from each Pack configuration? Is it simply divide AMP's being pulled by number of paralleled packs?
no need for a guru here. this is simple math. if you parallel a pack it's like one big pack.
so paralleling 2 6s1p packs with 5.000mah gives you 6s2p with a total of 10.000mah.
as each cell still is capable of eg 25c, the pack can now provide double the power.
each cell only sees half the current when power stays the same. (or a third if you put 3 in parallel, and so on ...)
it's now not 6x 3,7v, it's 6x 7,4v. so each cell has 7.4v, and as P=U*I your assumption is correct :)
izeman
Postby Timma2500 » Tue Feb 28, 2012 6:21 am
Surely he was just referring to battery capacity :)
Besides i don't think it'd plough through the thick snow that easily if it was only running 15a!
Paul :D
Intense M3 DH, HT3525 / 5kw, 18fet, 20s 10ah nano lipo
Norco Empire 5, 80100 130kv / 5kw, HV160, 12s 12ah lipo
Under Construction
Timma2500
Postby binlagin » Sat Mar 03, 2012 7:17 pm
I just got back from testing out the 18FET Lyen controller programmed at 65A on the Controller and 95A on the phase with the Cromotor... all I can say is OMG!
I took it down the street and got it up to 65km/h in a blink of an eye before I ran out of street. I took it to the park and ripped around in the snow.. WOW... this thing is awesome!!!!
I can't wait for all the snow to go away now!
I'll post a video tomorrow!
100km/h+
binlagin
Postby markobetti » Sat Mar 03, 2012 7:29 pm
you are going to love the top speed also...Just find a street that meets you requirements :)
markobetti
Postby rojitor » Sat Mar 03, 2012 8:04 pm
Seems the giant dh is getting popular ;) very nice setup binladin!
rojitor
PreviousNext
Who is online
Users browsing this forum: agniusm, dan974 and 8 guests
