Brentis wrote:GWhat church is that in the background @ the end of vid.
GCinDC wrote:thx. ....locusts, next...
Duc998 wrote:Anyone know if the falcon ev bag would fit this dh comp? Im looking at having my 9 5ah zippys in the frame.
Crunchy spot? Sure it's not the bearings? Those shocks are meant to be pretty good. Have a read at the manual and play around with the settings. Sag should be 20-30%, so you may need a new 2.8" stroke spring. Back off both of the compression screws and adjust the rebound to where riding it feels somewhere in between pogoing and sticky. You can adjust the bottom out protection by adding more air pressure, lowering the air volume and increasing HSC dampingGCinDC wrote:the rear shock (manitou swinger 6 way) is dog doo - has a crunchy spot and sag like an old lady - so i'm looking for an upgrade/replacement. don't really want to pay top dollar, as i'm most concerned w/ bottom out protection. i'm thinking fox dhx 4 or 5 w/ a 600+ coil.
Sounds like the SPV "platform damping". It's there to make the bike more pedal-able. DHX "boost valve/propedal" has similar circuitry. You cannot get rid of it completely, but can lessen the effect by increasing the air chamber volume and decreasing the pressure in the air chamber to 50psi (careful not to go any lower as the IFP will aerate). Doing this will also decrease bottom-out protection, so more HSC and/or stiffer spring might be needed.GCinDC wrote:under constant pressure, the rear sags and inch, then stops, seems to get hung up, but with continued pressure suddenly drops another couple inches quickly, and then continues to compress steadily until it approaches the bottom.
full-throttle wrote:increasing the air chamber volume and decreasing the pressure in the air chamber
Duc998 wrote: Im looking at having my 9 5ah zippys in the frame. I can buy a dh comp second hand medium size frame but holding out till I know if the faclon bag would fit.
Duc998 wrote:Hyena has done my setup. Great bloke
Duc998 wrote:Are you going to put a kick stand?
GCinDC wrote: still not sure if i wanna use the hs3540 or the 9x7 9C. or eventually get a MAC. the idea was to have this a lightweight, high torque, low speed dirt bike, in addition to GT high speed commuter, but i know i'll want to commute on it...
anyone know of what i can get to upgrade the bearings on the hs3540?
GCinDC wrote:Hyena, got a solution? Plaster it w/ High Voltage stickers so no one touches it?![]()
Hyena wrote:I think the larger DD hubs will be tough to beat for offroad use and torque when you can just dump a heap of current into them.
Lenk42602 wrote:GCinDC wrote:thx. ....locusts, next...
actually, my sources tell me it begins to hit the fan ths march......
• SPV Air Pressure: The air pressure that controls the SPV compression damping qualities and
characteristics. More air pressure creates a firmer platform and increased compression damping. Less
pressure creates a lighter platform and more supple response.
• SPV Volume Adjustment: The volume adjuster located on the SPV shock reservoirs. This adjuster controls
how firm and progressive the position-sensitive compression damping feature acts. The smaller the volume
in the SPV chamber, the more progressive and position sensitive the compression damping becomes.
GCinDC wrote:Thanks for a good laugh. No. My comfort bike had a nice one, but I'm sure there's nowhere to mount one on a DH Comp!
Quite hazardous I'd imagine on a rough downhill track.Hyena, got a solution? Plaster it w/ High Voltage stickers so no one touches it?
Duc998 wrote:Pickup my DH Comp tomorrow morning, Cant wait. First thing I'm going to do it see if I can fit my pack into the triangle. Was up till 2am last night searching through ES for DH comp build and loved Doctorbass's badass build...
full-throttle wrote:Hope this helps... From what you described before your shock is either set to be very progressive or it may have faulty internals (hope not)
Duc998 wrote:GCinDC wrote:Thanks for a good laugh. No. My comfort bike had a nice one, but I'm sure there's nowhere to mount one on a DH Comp!
lol I've never had a quality bike but guess I will get used to ittold u I'm a noob
. But those high voltage stickers aint a bad idea
searching through ES for DH comp build and loved Doctorbass's badass build... But wont be going anywhere near those specs... I'm using the same 6s zippy's as Doctorbass's, Mine are 25c he's are 20 - 30c could'nt find the exact C rating in his thread, I've attached one of DocterBass's DH comp pics and looks like I'll fit the 8 zippy's but the 9th will be difficult, Sure I'll work something out. I'm lucky I've got hyena's backup and he's not too far away
I'm on the second run for kiwi's dropouts, Have you gotten yours yet? Look like I'll have to wait a few weeks for those...
Cant wait to see more update's on your build GC
cheers
DoctorBass DH Comp build ( hope u dont mind Dr)
Users browsing this forum: skyliner and 9 guests
