GCinDC's Giant DH Comp
Re: GCinDC's Giant DH Comp
Postby andreym » Fri Mar 23, 2012 1:12 am
GCinDC wrote:
andreym wrote:why don`t you want just to plug your famous series-parallel adapter to the main leads only?
oh, i'd be happy to do that. but how big is it?? looks like 2 feet long! i just saw doc said it was small, but would you mind measuring? thanks!
According to datasheet it is: 11.02 x 3.44 x 1.65” / 284.5 x 87.4 x 41.9mm
and 1.27kg weight
but actual weight is a bit more - around 1.5kilo.
Avanti D8 CroMo frame, CroMotor :) + MAX-E controller. 18s10p zippy compact in Pelican 1300 case. 1.8kwhrs total usable capacity.
fast 1.2kw charger old GT iDrive e-bike
andreym
Postby sn0wchyld » Fri Mar 23, 2012 2:52 am
Doctorbass wrote:
GCinDC wrote:
sn0wchyld wrote:did you check the side cover bolts?
i did, but maybe i missed it. sounded more like a rub at low speed, but perhaps that's consistent w/ screw head.
here's how it sounds on the bench. there was a distinct moment when it lost power, hence my assumption it's a hall. but after taking this apart, it's not clear what was making the sound, except perhaps some fat shrinktube on a phase wire, and it does look a bit rubbed.
what are you going to do with the old mx rim/tyre/spokes?
needs to be relaced. had planned to install hs3540, but have been rethinking that. kinda curious what a cromotor would be like in it! :lol:
tbd. that reminds me i need to weigh it!
On the last vid, the sound is what look like a missing phase or shorted phase wire.. or hall wire.. check by disconecting each phase wire one by one. Each time retry runing it. If the sound nearly dissapear but your motor only have less power, it is that phase wire the problem
Doc
does sound too frequent on that last vid to be a single point on the wheel... unless the rpms were far higher than it looked...
is the noise only there under power? ie free-wheeling is silent? if its still noisy with no power then that'd pretty much rule phase shorts etc out wouldnt it?
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby GCinDC » Fri Mar 23, 2012 9:25 am
Doctorbass wrote:On the last vid, the sound is what look like a missing phase or shorted phase wire.. or hall wire.. check by disconecting each phase wire one by one. Each time retry runing it. If the sound nearly dissapear but your motor only have less power, it is that phase wire the problem
thanks, doc. these phase wires perplex me, esp the term 'shorted' - when ever i check for continuity between the phase wires, i always get zero resistance.. so they all seem shorted. i do this of course with the multimeter, checking for resistance, and touching the green phase with one terminal and the yellow or blue with another... i don't understand that. but it's true for every motor i've tested, so it must be by design... so a 'shorted phase' means one where the the short occurs 'prematurely' in the leads, or in the coils?
if one phase wire is shorted, the sound may go away if i disconnect one?? i will try it...
but i will also try connecting to new sensorless controller to see if it runs (to rule out the halls). then i'll make the pilgrimage to dbaker's to borrow ebike tester and try that. :mrgreen:
andreym wrote:According to datasheet it is: 11.02 x 3.44 x 1.65” / 284.5 x 87.4 x 41.9mm
thanks! it's a nice size compared to MW. maybe time to order TWO. :mrgreen:
i might be a bit concerned about charge rate for my old lipo pack. one cell has been dragging, so i gotta keep a close eye on balance there... thanks! maybe now i won't charge like a girl.
GrayKard wrote:You must live in an alternate universe where there are 30 hours in a day.
haha, if true, doc lives in a universe where's there's 60hrs in a day! i just take lots of pictures... at home kids take up all my time, but eventually they fall asleep. :lol:
chroot wrote:I can't wait 2 cromotors coming for me next week.
are you keeping up a build thread? what donor bike?
snow, as promised, 9x7 + ~4.5lb Alum Excel Rim + ~8.5lb Shinko 244 tire + Some Giant Tube + Spokes:
and imagine my horror when i hopped on GT this morning and noticed Old Faithful 9C side cover was COMING OFF?? wtf? emil, did we unscrew this when you were over? i can't imagine it unscrewing on it's own!
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby kfong » Fri Mar 23, 2012 9:30 am
Locktite!
kfong
Postby Skippic » Fri Mar 23, 2012 9:37 am
I touched only the one I have and the round cover 9C. I think it was Charlie :mrgreen:
Skippic
Postby GCinDC » Fri Mar 23, 2012 10:14 am
Skippic wrote:I think it was Charlie :mrgreen:
2years and 2 months, the kid doesn't stop. all day long. the weather's been nice so after dinner, we hit the park. wed night i took the gopro.... :lol:
GCinDC
1 GW
1 GW
Postby dbaker » Fri Mar 23, 2012 10:53 am
Charlie IS moving fast :mrgreen:
dbaker
Postby deecanio » Fri Mar 23, 2012 11:27 am
:) Go Charlie, looks like theres enough room for a couple of turnigy packs under his scoot? :lol:
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby Whiplash » Fri Mar 23, 2012 2:47 pm
LOL! I always thought a friction drive on one of those little scoots would be a blast! LOL!
I can't believe that in a year my daughter will be that crazy!!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby chroot » Fri Mar 23, 2012 6:43 pm
No, I have not keeping up a build thread and I am build a Farfie inspiration Genesis V2100 with the custom extended arm waiting for my cromotor coming next week. I would post new build thread when it complete. 8)
I still riding same old Tidalforce ebike with 9c motor. Anyways, Have you ever ride dbaker's cromotor ebike yet?
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby GCinDC » Fri Mar 23, 2012 8:49 pm
charlie's having a good year:
playing catch up - here's a boring vid of the late night. don't waste your time. i'd edit it, but there's nothing there. took forever to make and way too big, unless you just love garages...
at the end i installed at 44t chainring. hot dog!
and the next morning i hopped on it to a symphony of grinding sounds...
so i took apart motor and examined for rubbing. hall wires untouched. the one is fat cause i'd spliced in sensor leads...
some shrink tube inside got rubbed. stop the press. somebody call a doctor.
this evening we were going on a family bike ride to picnic by the kenwood cherry blossoms. but the GT was failing. odd power surges here and there. and i misplaced the trailerbike hitch to pull son. so i got home with an hour to try to fix up the dh comp. i whipped the motor back together and hooked up the sensorless controller:'
30 min to go, i tossed it on the bike, spun fine. tightened everything up. then horrible rubbing. snowchyld was right: metal on metal was a screw head hitting the caliper. i had tried to get away w/o a washer inside the dropout adapter, and when i did a final axle nut tighten, i must have pushed the calipers just enough to rub the motor! that explains that.
i think a hall is down too, but having a rear brake will make up for going sensorless.
so i added a washer, put the bike back together. but not in time for the picnic!
my wife took off hauling two kids and i had to drive. or did i? i had another 10 min, and realized there'd be no place to park, so whacked on the controller, put the rest of the bike together, tested it in the alley, and then took off with son in front of, his feet on my feet.
a couple miles on the bike path without pedaling once. :mrgreen:
so yeah, emil, if we get a break in the weather this weekend, let's race. :twisted:
GCinDC
1 GW
1 GW
Postby Skippic » Fri Mar 23, 2012 9:43 pm
I'm charging my battery to 4.3V :mrgreen:
Skippic
Postby GCinDC » Fri Mar 23, 2012 9:50 pm
Skippic wrote:I'm charging my battery to 4.3V :mrgreen:
you'll have the start advantage w/ sensored controller, and i'm inquiring from lyen how to get my speed switch working cause there's no connector for it and it's stuck on 2, so you may have a chance... you may have to pedal tho. :lol:
GCinDC
1 GW
1 GW
Postby deecanio » Fri Mar 23, 2012 10:35 pm
Greg, what do you mean spped switch? on the 12 fet sensorless (im looking to hook mine up immenently)
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby GCinDC » Fri Mar 23, 2012 10:50 pm
deecanio wrote:Greg, what do you mean spped switch?
meth and lyen sell as bell/whistle for $15. allows 25% 50% 100% throttle, for switch settings 1,2,3. (controller settings are programmable - hyena programs sp 3 to 120% i think :twisted: )
i set to 1 to conserve batt when super low and go max 20mph @ 500W. handy therefore if you get stopped... :mrgreen:
came into vogue hereabouts?
GCinDC
1 GW
1 GW
Postby deecanio » Sat Mar 24, 2012 11:49 am
ta, more reading to do then!
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby andreym » Sat Mar 24, 2012 4:40 pm
GCinDC wrote:thanks! it's a nice size compared to MW. maybe time to order TWO. :mrgreen:
I really hope that was you g***r( 64) on ebay who bought one at Mar-23-12 08:23:46 PDT
because right now they are all gone :shock: I wonder who could buy the rest 10+ of them?
andreym
Postby GCinDC » Sat Mar 24, 2012 6:30 pm
as a matter of fact, that was me. :mrgreen:
wanted to try one first since there was no break in shipping two. perhaps i should have got two after all..
GCinDC
1 GW
1 GW
Postby andreym » Sat Mar 24, 2012 6:44 pm
GCinDC wrote:as a matter of fact, that was me. :mrgreen:
I`m glad you are lucky :mrgreen:
considering your ~700wh pack i doubt you will ever want 2nd to use them in series :)
However you still can ask your friend dbaker if he have one spare in case you decide to leave one at work and the second one at home. That was the way it worked for me.
anyway to make it 41.5v you will need to short the pin D1 to the pin A3
and to make it power on the pin B3 should be connected to A3
after it powered on, you can use voltmeter to adjust the pot on the top of the case to the exact voltage you want.
I believe the following picture will explain where to solder AC-in(P1-P2) and DC out(P4=positive and P5=negative) wires :)
and do not forget to use at least 12awg :idea: wires for DC output - I tried 14awg initially and those were hot to touch after 2-3 minutes of use, So I replaced mine to 12awg.
andreym
Postby GCinDC » Mon Mar 26, 2012 7:50 am
andreym wrote:the following picture will explain where to solder AC-in(P1-P2) and DC out(P4=positive and P5=negative) wires
andrey, you make it too easy for the other 10! :mrgreen: thanks, i will need this soon!
that is: IF i get ONE ebike running. both are DOWN right now. i'm so mad, frustrated and embarrassed.
GT i drive:
- halls & phase wires test beautifully on ebike tester (get one if you don't have one)
- tried TWO identical working controllers, same problems - wheel spins but with no power whatsoever, and (slowly) at different speeds using speed switch!
- i've never seen anything like this.
- 83V everywhere
- perhaps the magura throttle line? maybe the inline resistor broke. i'll test a diff controller. that may explain random pulsing i had last week.
- or, maybe a rat crawled in the motor after charlie loosened the sidecover? i can test with another motor...
ok, that's a plan of action at least. less mad now.
DH COMP
enjoying the island?? :mrgreen: i wished we could have raced - that way this controller could have lived for longer than TWO rides! :oops: :x
- a hall is dead - or more likely shorted somewhere on the axle - that white plastic woven sheath is shredded near the bearing, so it was surprising it ran on friday
- but on Saturday, i poked the programming connector with multimeter probes and probably ruined the chip - :x
- that's just a suspicion. i was trying to find a 5V source for my temp sensor, and since there wan't a speed switch connector. one connector gave 5V between the black and other wires, but later lyen reminded me that was the programming connector when i asked him how to solder to the board to add a speed switch connector. might as well build up the bike right and do the proper upgrades. so i popped the controller, added the speed switch, but could not get the bike to run after that! even w/ speed switch disconnected. and something smelled a bit funny. :shock:
i may have blown the chip. i'm going to try to program it next, to see if it's alive.
if not, i'll be pretty pissed, as this destructive streak is getting out of hand.
i hopped on my road bike to commute this morning, but the gears are broken.
GCinDC
1 GW
1 GW
Postby binlagin » Mon Mar 26, 2012 8:11 am
Yea GC.... I can totally relate. I had problem after problem with my ebike this weekend and I'm still not back on the road after investing at least 20hours into it.
I'm feeling frustrated and defeated... but I understand that this is all part of the process. I'll try again tonight or tomorrow!
Good luck getting your bikes back on the road.
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby GCinDC » Mon Mar 26, 2012 9:45 am
it's been a while since i programmed a controller. from a bit of research i've learned:
- cool XPD: open-source keywin e-bike lab replacement doesn't support new EB3 boards
- the EB212 programming cable different wiring scheme than EB312's
so now it's up to priority mail. :lol:
and if i'm bored tonight, i can rebuild DH Comp with 9x7 fatty M/C wheel and sensored controller. :D maybe even try to solve rear brake alignment issues... 8)
GCinDC
1 GW
1 GW
Postby GCinDC » Mon Mar 26, 2012 2:03 pm
nice monday entertainment, recognize anything FT?
GCinDC
1 GW
1 GW
Postby GCinDC » Mon Mar 26, 2012 3:46 pm
As for the GT w/ sensored motor, its the old CA. Won't come on and when connected the wheel spins at anemic ~25 percent.
When CA disconnected the motors spin fine. New CA works fine when connected.
Either way I'll be riding an ebike to work tomorrow, with or without CA.
GCinDC
1 GW
1 GW
Postby full-throttle » Mon Mar 26, 2012 6:52 pm
GCinDC wrote:nice monday entertainment, recognize anything FT?
Just a few locations and the rider :)
Thanks for sharing. The drop from the bridge looks scary :D Like the bit of riding up the brick wall too 8)
full-throttle
PreviousNext
Who is online
Users browsing this forum: No registered users and 4 guests
