GCinDC's Giant DH Comp
Re: GCinDC's Giant DH Comp
Postby gensem » Fri Mar 30, 2012 1:54 pm
andreym wrote:
gensem wrote:Dual RSP-1000 48v in series?
Not cheap but its reliable and will charge 100v around 25a
they are WAY MUCH HEAVIER compared to car1248 ones. And bigger in size. And much more expensive. So what is the point of using them?
2.5kw of charging power instead of 600w?
3,8kg only
edit: my mistake... it tough car1258 was the 600w BMS battery charger.
Im not sure about the diferences.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby andreym » Fri Mar 30, 2012 2:00 pm
gensem wrote:2.5kw of charging power instead of 600w?
3,8kg only
my car1248 weight only 1.3kg each and outputs 30a at 50volts = 1500w, so for 2 of them it will be 3kw in 2.6kg,
still 1.2kg less than overpriced RSP and 500w more powerful :D
Avanti D8 CroMo frame, CroMotor :) + MAX-E controller. 18s10p zippy compact in Pelican 1300 case. 1.8kwhrs total usable capacity.
fast 1.2kw charger old GT iDrive e-bike
andreym
Postby gensem » Fri Mar 30, 2012 2:37 pm
3,8kg only
Do you know where to order the cart1248 with international shipping?
gensem
Postby andreym » Fri Mar 30, 2012 2:48 pm
gensem wrote:Do you know where to order the cart1248 with international shipping?
Unfortunately they are over on e-bay: http://www.ebay.com/itm/260847005833
and the seller told me he is not going to get more :(
andreym
Postby GCinDC » Sun Apr 01, 2012 2:19 pm
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby GCinDC » Sun Apr 01, 2012 8:56 pm
aka how to sheer off the thread on disk...
GCinDC
1 GW
1 GW
Postby knoxie » Mon Apr 02, 2012 4:51 am
Oh No Greg :( you just aint having any luck? you need a bomber mate, that's it I'm ordering you one! on the house :wink: hmm suppose its a bit beyond liquid metals ability?
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby GCinDC » Tue Apr 03, 2012 9:54 am
knoxie wrote:you need a bomber mate, that's it I'm ordering you one! on the house
address sent in PM :lol:
yeah, it's been a very destructive streak, that's for sure.
i've always intended to lace the M/C tire onto the hs3540, so let's just consider the old 9C just the test platform. :mrgreen: it will go nicely on another bike, once i replace the side cover:
the sheer failure is well known, right? but i'd expected the threads would get sheered, not that the entire thing would crack off. :lol:
dbaker prolly had loctited the threaded adapter on. good stuff.
so moving along... i put in a good four hours last night rebuilding the DH Comp, starting with the upgraded hs3540.
the lyen ebike tester show that the blue hall wasn't working (solid red light)
but with a multimeter, i discovered a short between Blue and GND! Dang it! This then echoed in my mind... :lol:
John in CR wrote:Be sure to change out the hall wires too.
I could have ignored halls and installed sensorless controller, but would have preferred to use the sensored controller. so carefully removing the sidecover... can you see the frayed cloth? that was visible from outside and i suspected there was damage to the wires...
but with a magnifying glass i couldn't see any exposed wires:
hmm. i checked the halls with the ebike tester again, and they all work - see the red lights going on and off when the magnet passes?
so the short must be in the wires, and if not now, maybe just when compressed in channel, so let's give the wires some more room:
i then taped up the wires where the cloth was torn, tossed the wheel back together, tested it on the bench and it sang beautifully! i ran it no load, WOT for several minutes, and watched as the motor temp went from 16C to 20C. woohoo!
i tossed it on the bike, and then lined the brake up perfectly with some washers - it rubbed with last motor and i couldn't stand any more NOISE. we learn. we learn...
i used a wire tie to clamp the wires away from the disk screws, just to make sure there wasn't any rub, and fired it up:
no longer singing, that's for sure. and when i put my ass on it and tested in the alley, you'll notice there's no mechanical rub under pedal power but with some throttle..:
yeah, we're used to this now...
no worries. just time to fire up the brand new sensorless controller. oops, gotta replace the connectors with bullets, and might as well watch some hulu:
i tossed it on, and it tested fine, though a bit anemic... well, we'll see in the morning... i think it'll make it to work at least. i actually had trouble falling asleep cause i was excited to ride it. :twisted:
and it did:
i had the old lipo in the pocket again, connected by alligator clips to power temp sensor, and damn, i never got above 64C! the controller was probably programmed with conservative settings so no idiots would burn up their motors:
Overall impressions of this build so far:
- brief jerky start from standstill
- surprising low torque during initial acceleration
- lackadaisical throttle response after coasting
- curious grumbing in middle range, wasn't sure if it was something in the motor, but it disappeared at higher speed
- eventually got up to max 38mph downhill, which was fresh after slowpoking around
- brakes feel good, and thankfully are now quiet due to proper alignment (lesson learned: tighten axle before aligning :idea: )
- need to reprogram to get regen?
so let's see if i can make it through the day without destroying anything - i might even like to get thru the week, but let's not temp fate.
ebikes are reliable, just as long as you're willing to work on them all through the night, if that's what it takes. :lol:
GCinDC
1 GW
1 GW
Postby grindz145 » Tue Apr 03, 2012 10:19 am
OMG Greg, that looks so sweet!
It's all about sleepless nights when it comes to ebikes man.
My sensorless experience was MUCH worse, I'm glad to hear you're in much better shape!
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby GCinDC » Tue Apr 03, 2012 10:31 am
it needs a cleanup. i didn't bother to wire-tie the wires, thinking i'd have to cut them off when something broke!
and i'm still trying to figure out how to bungee this bag. i forgot to mention that i thought the hall failure was actually due to a loose contact in the connector, that was yanked out because of the pressure of the bungee! turns out it didn't matter after i fixed it, but lesson learned... no more wrapping it around those wires!
and for my own reference, here's are the settings of my sensored controllers:
GCinDC
1 GW
1 GW
Postby grindz145 » Tue Apr 03, 2012 10:37 am
That's some serious current for sensored operation. Be careful if you lose sync! Get off the throttle quick, or else bye bye mosfet :)
grindz145
Postby GCinDC » Tue Apr 03, 2012 11:43 am
grindz145 wrote:That's some serious current for sensored operation. Be careful if you lose sync! Get off the throttle quick, or else bye bye mosfet :)
i've had a pair of the eb212 controllers programmed with those settings since Nov 2010, and i can assure you, i've not been careful... :twisted:
as far as the halls go, however, break out the marshmallows... (that said, the flat sided 9C in the JRH wheel that i ran all thru 2011 is still going..)
i might need to double-check the rshunt value, but on this morning's commute, the CA was reading close to 40A continuously up hills w/ sensorless that it used to read closer to 60A w/ sensored.
with the hs3540, you'd think i'd get a jump on a 9x7 @24s (especially if i sneak another 5s on board :wink: ) if ever sailorboy gets back... :roll:
but now with this sensorless jobbie, i'm thinking i'll need to up the rated current to at least 60A... :lol:
GCinDC
1 GW
1 GW
Postby grindz145 » Tue Apr 03, 2012 12:29 pm
Greg, that current is fine with Halls, but once you "loose sync" on a sensorless controller, I would worry, very different scenario.
I missed it, who is sailorboy?
O wait is EB212 sensorless? I'm confused... :oops:
grindz145
Postby GCinDC » Tue Apr 03, 2012 1:06 pm
grindz145 wrote:Greg, that current is fine with Halls, but once you "loose sync" on a sensorless controller, I would worry, very different scenario.
should i aim the gopro at the fet side of the controller to capture it? :lol:
eb212 sensored. eb312 sensorless. more at lyen.com
a local ebiker. i'd suggested we race before he went on vaca... to which he responded:
Skippic wrote:I'm charging my battery to 4.3V :mrgreen:
GCinDC
1 GW
1 GW
Postby grindz145 » Tue Apr 03, 2012 1:10 pm
Haha, thanks for getting me up to speed 8)
grindz145
Postby GCinDC » Tue Apr 03, 2012 5:51 pm
the love that keeps on coming...
GCinDC
1 GW
1 GW
Postby Skippic » Tue Apr 03, 2012 6:24 pm
Yeah, and I accidentally charged them up to 4.46V. Lucky you it was raining ^^
Skippic
Postby GCinDC » Wed Apr 04, 2012 7:20 am
5 miles thru the city at 7:30am w/o hardly stopping. :mrgreen:
the total time/moving time delta was just me dicking around in garage before heading out...
and to get up to max speed 42mph, i had to do pauld's death race tuck. :lol:
up that same hill last night, i pedalled hard to get to 30mph.. :roll:
it's interesting riding w/o regen. i bet the motor (and controller) have a lot more time to cool down, cause when i'm running regen, the motor and controller are ALWAYS pushing amps, one way or the other...
no news on the fast chargers yet. i am somewhat concerned they won't shut off at voltage, and if the fan continues to run it may draw unwanted attention, but it does seem like an excellent value and form factor.
for now, i'm using the meanwell psu, and turnigy accuwhatever, which starts with an alarming fan whine:
should i hit it with a drop of oil?
oh yeah, i've not been balance charging, just lipo charging, but if i plug in the 5s balance connector, it seems to balance anyway... does that make sense? that just by virue of paralleling balance leads during charge that it would balance??? is so, what's the point of balance charging!?
GCinDC
1 GW
1 GW
Postby veloman » Thu Apr 05, 2012 1:03 am
I picked up a staple today too, went right through the Mr Tuffy tire liner.... It takes a bit of force to stab a really sharp knife through them. What are the odds that a staple can point straight up on the road? Then you hit it. It was a slow leak, didn't notice it till later while I was at home.
810 115.jpg (72.69 KiB) Viewed 421 times
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby GCinDC » Wed Apr 11, 2012 9:20 am
gosh this sensorless controller is anemic. it absolutely refuses to draw more than 3kw at any time. i can't even get the motor above 65C. how frustrating! :lol: so i just programmed it, upping the phase amps from 80 to 100 so we'll see about that...
meanwhile, the bike tire's got a bit more speed, but not much with this sensorless controller, and i do miss that sensation of the big M/C tire:
as you recall, i snapped off the threaded disk flange (by braking after jump), and while i'm doing repairs, i'd been wondering if i could fix the dish issue by...
GCinDC wrote:...unscrewing each spoke (on the right side, that's laced on the rotor inside), bend the spoke enough to yank it out, and re-insert from outside of rotor, and tighten back up in nipple...? :idea:
well curiosity got the best of me, and unfortunately, in order to replace the spoke from the inside, it does need to be bent, just a bit...
otherwise it must go thru gap between the opposite side spokes and couldn't be bent back, certainly not w/o loosening all of them. the spoke can be bent back more or less (less) straight, but looks traumatized. :mrgreen:
i'm not surprised, but i decided the main goal of this operation would be to gather some spoke data to rebuild the wheel from scratch.
step 1 was to let the air out of the tube, but i was amazed how stiff the tire was. i could easily believe it possible to ride on this tire completely flat!
but then i laid the wheel down and put a lot of pressure on the tire to 'break the seal'. then with clamps i was able to shift the tire/tube over enough to peek under at the tops of the nipples.
as i'd feared, my adjustments to undish it had overly loosened the one side (left one shown). notice how the spoke isn't threaded to the top/end of the nipple:
during an MC wheel spoke hunt, i'd found this instructive image:
the obvious challenge with this wheel build is securing 12g (2.6mm) spokes with (5.5mm) butt ends in giant 8mm wheel holes:
dbaker accomplished it here with two washers, both of which bent to the shape of the hole:
i have no idea where he got the oval ones.
and now the data:
GCinDC
1 GW
1 GW
Postby binlagin » Wed Apr 11, 2012 12:31 pm
What app are you running on your Andriod device to record those statistics?
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby GCinDC » Wed Apr 11, 2012 12:41 pm
My Tracks. Nothing fancy...
So I programmed the controller. (And this proves the chip is dead on my last one. :( )
Going to try it at 100A phase for a while and see how it goes. Some quick tests had it hitting 4kw regularly, and it felt better. Still weak off the line tho. And no regen yet. Looks like I need to set up an ebrake line.
GCinDC
1 GW
1 GW
Postby GCinDC » Thu Apr 12, 2012 8:22 am
Can you describe exactly what causes sync loss? You mentioned backing off of throttle quickly. Do you have personal experience with it, and what happens?
Considering how much stuff I've destroyed lately, I've wanted to go easy, so just upped the phase amps from 80 to 100 and the rated from 30 to 37.5 (do I recall correctly that these should stay in a 2.66:1 relationship?)
And I'm much happier with performance. As I said, it draws 4kw continuously which is a lot more useful in quickly getting around cars and pulling up to a max of 46mph.
It was cold this morning, and slightly downhill, but motor temp was only 65C! This really makes me wonder because my inbound commute w/ the sensored controller and monster wheel (on 9x7) that got up to 130C, no problem!
I may also be running cooler now because I don't have regen. I do want to set that up. Now that I've got hyrdaulic rear brakes, I can't use the electronic brake lever, so am thinking of dissecting one to get magnet and whatever to glue/screw/tape onto the hydraulic lever. Anyone got pics of such a setup? I'm still surprised how few people use regen...
GCinDC
1 GW
1 GW
Postby Skippic » Thu Apr 12, 2012 8:38 am
Forget regen, just get good brakes. For the brake switch you can use a hall or a reed switch. I'm interested if regen does heat up the motor as much as you say.
Skippic
Postby sn0wchyld » Thu Apr 12, 2012 9:01 am
it does have a pretty notable warming effect... ive got my regen on a separate switch for that reason... so if i'm racing round i can just heat up the brakes, but if im on a long downhill or riding for range then the regens available when needed.
I use a micro switch, ziptied to the break leaver. that way, I can pull on the regen, and then pull a bit harder to add in the disk brake, or just pull the disk brake on its own. works like a charm.
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
PreviousNext
Who is online
Users browsing this forum: pendragon8000 and 8 guests
