GCinDC's Giant DH Comp
Re: GCinDC's Giant DH Comp
Postby Stone Meadow » Wed May 09, 2012 1:35 pm
GCinDC wrote:
Stone Meadow wrote:stop using moderate brake pressure. The idea is to get heat into the pads and bed them into the discs, so don't use unusually light braking. Rinse, repeat half a dozen or so times, then let the pads cool off to ambient temperature and they are ready to rip.
thanks! of course i forgot to clean the new pad tho i was careful not to touch the business ends. i wouldn't have thought to rinse them. i'll try that. the rotors are brand new, perhaps no name. hope that wasn't a mistake. cheers. appreciate the answer!
Don't rinse the new pads...just the discs. That's to prevent emory paper residue or the former pad's material getting mixed in with the new pads, or tearing them up.
Stone Meadow
1 W
1 W
Location: 100km/60m NE of San Francisco, California USA
Postby Sacman » Wed May 09, 2012 2:38 pm
NICE!!!
Charlie's a natural monkey... :lol: I like it.
Sacman
Postby GCinDC » Wed May 09, 2012 11:00 pm
full-throttle wrote:I still find it hard to believe that DH-comps have some kind of a offset in their swing arms.
i took a closer look with the wheel off. damn...
but check out the ding.
i marvel the original owner didn't limp.
the gold level is square to the frame
and yeah, reversing the rotors would only make it worse:
so i unlaced the wheel, removing the 135mm spokes:
and i relaced it with the old 130mm spokes, with all the spokes going in from the drive side, therefore drawing it closer to the disk side, trued it up pretty nice i'd say and whipped that mofo tire on.
tomorrow i've gotta find a radio shack that's got mini xlrs..
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1.21 GW
1.21 GW
Postby GCinDC » Thu May 10, 2012 6:31 am
couple clips from the lacing
GCinDC
1.21 GW
1.21 GW
Postby GCinDC » Thu May 10, 2012 10:02 pm
motor wires are so short! will have to move the controller again. before i do, someone help: how is the temp sensor (white) wired?
last time i played around w/ multimeter i fried a controller chip. i ran my temp sensor off halls current. surely it needs some current to operate, right?
i bagged the mini xlr and attached my standard connectors. want to run stock for tests before upgrading.
so sleepy. i attached wrong (female) halls connector... :roll:
GCinDC
1.21 GW
1.21 GW
Postby Hyena » Thu May 10, 2012 10:28 pm
GCinDC wrote:someone help: how is the temp sensor (white) wired?
No necessarily - it depends on what type it is. If it's a 3 leg chip type it's probably running off the 5v hall supply, if it's a thermistor it's essentially a resistor that changes resistance with temperture, in which case it's probably piggy backing on the -ve hall wire. Put a multimeter across the white and black wires and see if you get resistance. Failing that you could always ask the supplier :P
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby full-throttle » Thu May 10, 2012 11:18 pm
Do the new HS motors come with the temperature output?
Would be interested to see whether it's LM35 or thermistor based
full-throttle
Postby Hyena » Thu May 10, 2012 11:32 pm
full-throttle wrote:Do the new HS motors come with the temperature output?
Not standard, I guess it was a custom order. Something I wish I knew about when we were ordering the 5400s (and my other others) as I would have definately had it included! Trying to get Kenny to do even routine additions seemed hard enough though.
Hyena
Postby GCinDC » Fri May 11, 2012 7:55 am
ah, here we go, from here:
ebikessf.com wrote:New 2012 Crystalyte H3540 cruiser rear hub motor. NSK bearings. Honeywell S411 hall sensors. Built-in 2K thermal sensor ....
i see someone else had a question..
more research to be done. the wire exit looks much better than the last hs3540. looks almost filled with epoxy. and i almost hate to remove the side covers. i'll be pissed if one of the bearings sticks on the axle. better to remove the rubber caps before lifting the sidecover? they've never survived one of my battlefield surgeries... :lol:
GCinDC
1.21 GW
1.21 GW
Postby GCinDC » Sat May 12, 2012 3:17 pm
thanks to len for the link to the alligator universal hose kit. the hose is stainless mesh w/ kevlar and plastic coating and the kit came w/ a bag of fittings. cool hipster at the bike rack on Q st cut the cable for me for free. the rest was cake.
ready to bleed:
GCinDC
1.21 GW
1.21 GW
Postby moonshine » Sat May 12, 2012 11:08 pm
hey man,
bottom line...something is effed. I don't know if its the controller (lower on my differential), the phases, or the halls (highest). Lyen's tester says ALL of em are dead. In your experience, when the halls were messed up, when you connect the battery, do you hear a rapid "click click click click" inside the motor? It only lasts for a second or two. Either way, i'm tapping out. So ticked that after a mile worth of riding something is "blown." Ridiculous.
03 Giant DH comp w/ 05 swingarm, cromotor in 26" large marge, Kelly KBL96251, 24s4p
Build Thread: viewtopic.php?f=6&t=40031
moonshine
Postby GCinDC » Mon May 14, 2012 7:49 am
ah monday morning. :D
too busy this weekend to get much done, but now that the MC wheel is built, i'm going to:
- probably replace the factory installed 2k thermistor of new HS3540 with an LM35 (or somesuch) to wire up to my hk temp monitor:
(edit: psyched that i can tap existing wires and not have to run new ones... but come to think of it, i'll probably want to upgrade them prior to oil filling... :roll: )
also have to grind the gear puller claws to remove bearing and replace in side cover.
then i'll install the M/C wheel and ride up the Amp sucking Mass ave - probably at night to avoid glare - and record temperature rise
then i'll fill the motor with oil and repeat :D
GCinDC
1.21 GW
1.21 GW
Postby GCinDC » Mon May 14, 2012 10:21 am
GCinDC
1.21 GW
1.21 GW
Postby JohnC » Mon May 14, 2012 5:48 pm
Looking good GC!
It’s coming along just like your GT i-drive 2.0 build. I like how you tweak it or make an improvement every week.
26” Mongoose, GM (r), 50V 10AH LiPo
JohnC
Postby GCinDC » Mon May 14, 2012 9:50 pm
JohnC wrote:I like how you tweak it or make an improvement every week.
haha, thanks. my wife is less amused. :lol:
while at bestbuy for her mother's day gift, i saw the gopro roll bar mount. it's big enough to attach to fork near disc:
GCinDC
1.21 GW
1.21 GW
Postby Sacman » Mon May 14, 2012 10:24 pm
GCinDC wrote:while at bestbuy for her mother's day gift, i saw the gopro roll bar mount. it's big enough to attach to fork near disc:
Yeah but mounting the GoPro that close to the disc means you really hear the BIG SCRAPE sound whenever you hit the brakes. :shock:
Sacman
Postby GCinDC » Tue May 15, 2012 9:02 am
interestingly enough, the disc brake is quieter after the rainy commute, but i'm bummed that wavy edge of the rotor seems means less than full contact with the pads - in fact it seems the top third of the pads don't contact the rotor. :roll: i should have gotten the round edged ones i guess...
but yeah, the gopro mic always magnifies phsyical vibration. i was gonna toss it on the other side but it was getting late and i had to get to work... as always.
bit of drama last night on the homefront so i ran out of time to complete the LM35 transplant:
i'm psyched i can piggyback off the halls again and won't have to run new wires.. tho i think on the way home yesterday when the HK monitor buzzer went off at 125C, the sound of the first beep started to die and then i think the power dropped to the motor. i yanked the connection to the monitor (since i haven't yet wired the switch) and it popped right back. so there's enough halls current to run the LED display but not the buzzer and flashing - but bear in mind also that i'm running 28g teflon all the way from the motor, and what's that 7 strands or so? so that could be a factor...
GCinDC
1.21 GW
1.21 GW
Postby Skippic » Tue May 15, 2012 9:53 am
You should only power the sensor from the halls, not the display. Just make sure, you have common ground.
Skippic
Postby GCinDC » Tue May 15, 2012 10:34 am
Skippic wrote:You should only power the sensor from the halls, not the display. Just make sure, you have common ground.
i'm all ears. last time i went hunting for another 5V source, i blew the chip of a brand new sensorless controller... for the circuit to work, it's gotta come from the controller, right? the display has separate power wires, but for the temp sensor to work, all three wires from LM35 or whatever need to be connected... so why not just power it from them...
i'm happy to open it up and solder to a spare 5v pad...
this is what i have now, which works perfectly fine, until the buzzer imitates a dying chicken:
and don't bother responding with words. only a diagram will be acceptable. :mrgreen:
GCinDC
1.21 GW
1.21 GW
Postby Skippic » Tue May 15, 2012 11:19 am
(133.62 KiB) Downloaded 3 times
Skippic
Postby GCinDC » Tue May 15, 2012 11:40 am
interesting. excellent use of no words! :lol:
i forgot to ask about the proper leads. ever since you suggested piggybacking on halls, i never understood what to do w/ them, since it runs w/o them connected...
so, if only for my educational purposes (or any lost ebike souls), would you change your diagram to include them?
in other news, it's been raining lately and my waterproof gear ain't waterproof. yesterday, i got a facefull of front tire juice. this morning i decided to ride standing up to keep my face above that stream. and since the seat then gets soaked from the rear tire, it's best not to sit down. some clips:
GCinDC
1.21 GW
1.21 GW
Postby Skippic » Tue May 15, 2012 12:03 pm
Windows Paint FTW!
(11.35 KiB) Downloaded 3 times
Skippic
Postby Skippic » Tue May 15, 2012 12:11 pm
Just in case someone tries to "simplify" things:
(13.89 KiB) Downloaded 3 times
Skippic
Postby GCinDC » Tue May 15, 2012 6:04 pm
thanks! that's helpful.
in other news, moonshine brought his dh comp and fatty 5404 over and while reaching in my backpack for a tool, my thumb stuck my mechanical pencil and it somehow deposited a 7mm piece of graphite under my thumbnail. several days later and it's still a bit darker in there. :lol:
and that bit on the timelapse:
the low lighting resulted in a million flashes which i don't have the energy to weed out.
how you liking that sensorless controller, moonshine? get it running?
GCinDC
1.21 GW
1.21 GW
Postby Skippic » Tue May 15, 2012 6:15 pm
I used your favorite color for the temp. sensor wire ;)
Skippic
PreviousNext
Who is online
Users browsing this forum: ilovehotshot and 6 guests
