GCinDC's Giant DH Comp
Re: GCinDC's Giant DH Comp
Postby Sacman » Mon May 14, 2012 10:24 pm
GCinDC wrote:while at bestbuy for her mother's day gift, i saw the gopro roll bar mount. it's big enough to attach to fork near disc:
Yeah but mounting the GoPro that close to the disc means you really hear the BIG SCRAPE sound whenever you hit the brakes. :shock:
Sacman
Postby GCinDC » Tue May 15, 2012 9:02 am
interestingly enough, the disc brake is quieter after the rainy commute, but i'm bummed that wavy edge of the rotor seems means less than full contact with the pads - in fact it seems the top third of the pads don't contact the rotor. :roll: i should have gotten the round edged ones i guess...
but yeah, the gopro mic always magnifies phsyical vibration. i was gonna toss it on the other side but it was getting late and i had to get to work... as always.
bit of drama last night on the homefront so i ran out of time to complete the LM35 transplant:
i'm psyched i can piggyback off the halls again and won't have to run new wires.. tho i think on the way home yesterday when the HK monitor buzzer went off at 125C, the sound of the first beep started to die and then i think the power dropped to the motor. i yanked the connection to the monitor (since i haven't yet wired the switch) and it popped right back. so there's enough halls current to run the LED display but not the buzzer and flashing - but bear in mind also that i'm running 28g teflon all the way from the motor, and what's that 7 strands or so? so that could be a factor...
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby Skippic » Tue May 15, 2012 9:53 am
You should only power the sensor from the halls, not the display. Just make sure, you have common ground.
Skippic
Postby GCinDC » Tue May 15, 2012 10:34 am
Skippic wrote:You should only power the sensor from the halls, not the display. Just make sure, you have common ground.
i'm all ears. last time i went hunting for another 5V source, i blew the chip of a brand new sensorless controller... for the circuit to work, it's gotta come from the controller, right? the display has separate power wires, but for the temp sensor to work, all three wires from LM35 or whatever need to be connected... so why not just power it from them...
i'm happy to open it up and solder to a spare 5v pad...
this is what i have now, which works perfectly fine, until the buzzer imitates a dying chicken:
and don't bother responding with words. only a diagram will be acceptable. :mrgreen:
GCinDC
1 GW
1 GW
Postby Skippic » Tue May 15, 2012 11:19 am
(133.62 KiB) Downloaded 3 times
Skippic
Postby GCinDC » Tue May 15, 2012 11:40 am
interesting. excellent use of no words! :lol:
i forgot to ask about the proper leads. ever since you suggested piggybacking on halls, i never understood what to do w/ them, since it runs w/o them connected...
so, if only for my educational purposes (or any lost ebike souls), would you change your diagram to include them?
in other news, it's been raining lately and my waterproof gear ain't waterproof. yesterday, i got a facefull of front tire juice. this morning i decided to ride standing up to keep my face above that stream. and since the seat then gets soaked from the rear tire, it's best not to sit down. some clips:
GCinDC
1 GW
1 GW
Postby Skippic » Tue May 15, 2012 12:03 pm
Windows Paint FTW!
(11.35 KiB) Downloaded 3 times
Skippic
Postby Skippic » Tue May 15, 2012 12:11 pm
Just in case someone tries to "simplify" things:
(13.89 KiB) Downloaded 3 times
Skippic
Postby GCinDC » Tue May 15, 2012 6:04 pm
thanks! that's helpful.
in other news, moonshine brought his dh comp and fatty 5404 over and while reaching in my backpack for a tool, my thumb stuck my mechanical pencil and it somehow deposited a 7mm piece of graphite under my thumbnail. several days later and it's still a bit darker in there. :lol:
and that bit on the timelapse:
the low lighting resulted in a million flashes which i don't have the energy to weed out.
how you liking that sensorless controller, moonshine? get it running?
GCinDC
1 GW
1 GW
Postby Skippic » Tue May 15, 2012 6:15 pm
I used your favorite color for the temp. sensor wire ;)
Skippic
Postby GCinDC » Tue May 15, 2012 7:10 pm
Skippic wrote:I used your favorite color for the temp. sensor wire ;)
not purple, pink! silly
ground the gear puller (thanks, snowchild, btw for the tip on those) down to get at the bearing, taped the legs shut and gently liberated the bearings:
still so clean.. :D
M/C wheel going on tonight! then brakes. :P
GCinDC
1 GW
1 GW
Postby Hyena » Tue May 15, 2012 7:21 pm
GCinDC wrote:and don't bother responding with words. only a diagram will be acceptable. :mrgreen:
Skippic beat me to it. You're lucky I was asleep, I was going to draw my diagram in such a way that the wiring appeared as a cock and balls :lol:
I'd be tempted to drop another 5v source straight across the halls and keep your existing wiring set up - (you could probably throw in a few diodes if you're worried about juice going back into the controller.) Easiest solution, get a cheap phone charger (old one or ebay) - they're usually ~5v - run that off your main pack voltage as a dc-dc converter and drop the output in parallel with your hall wires at the controller.
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby moonshine » Tue May 15, 2012 9:15 pm
Nice timelapse man. That was pretty deep under your nail man. Pretty impressive when you think about it...probability wise... Anyway, yea dude. The 12 fet works. It has no nut like you mentioned, but i can go probably 25-30 mph on it so its currently satisfying my ev needs. It gets warm though....im running 18s2p. Not quite sure how to go faster on it...cause i feel like it'll get even hotter. Remind me to stop by sometime this week to pay you. I was thinkin about reprogramming it, but i too scurrred. So i'll probably just have it as a back up. Oh and...i don't know if this means anything..but my CA showed my Amax reading...that was with my 18fet (before i connected the 12fet and clicked reset). It showed a Amax of 124. Is that a lot? enough to mess up my controller? anyways...i keep a pretty good eye on the CA now...Oh and i love my bike. Its frickin awesome. Thanks GC.
03 Giant DH comp w/ 05 swingarm, cromotor in 26" large marge, Kelly KBL96251, 24s4p
Build Thread: viewtopic.php?f=6&t=40031
moonshine
Postby GCinDC » Tue May 15, 2012 9:38 pm
hey moonshine, glad to hear you're running. i've got the default asv file for that controller so no worries programming it. no regen w/o ebrakes btw, or do you have them?
and i've been thinking about regen... you engaged regen and blew your 18fet controller. how fast were you going? your hk lipos are 20c but only 2c charge, and since i've noticed how much hotter my motor gets with regen, i'm wondering if that's just excess current that can't get back into the battery. just a hunch. when testing the thermistor in my hs3540, i saw huge spikes at regen... i'd have thought your motor would soak it up in heat, but perhaps the controller took it for some reason.
not gonna ride the mc wheel tomorrow. more work than i though carving (carefully not to scrape windings) a gap for the LM35.
and soldering it in:
home sweet home, belly laying flat on windings:
but before i jb weld it in place, i might want to test it. :idea:
dang it i don't have my tester! moonshine, can you drop it off tomorrow?? it's pouring out and i don't want to take apart the bike wiring only to have to put it back tomorrow am...
GCinDC
1 GW
1 GW
Postby moonshine » Tue May 15, 2012 10:13 pm
Yea man. No prob. What time? text me whenever. Maybe i'll ride there. haha just kidding. Last time i tried goin a half a mile and i got screwed. Actually...know of any bike trails that'll get me there? google says 5mi one way....Will i make it? I don't have a freewheel....so its all motor.
moonshine
Postby Skippic » Tue May 15, 2012 10:54 pm
Hyena wrote:I was going to draw my diagram in such a way that the wiring appeared as a cock and balls
I'll remember this, from now on all my technical drawings will resemble a cock!
Skippic
Postby GCinDC » Wed May 16, 2012 7:42 pm
Skippic wrote:...my technical drawings will resemble...
congratulations, but you show off your masterpiece in another thread? :lol:
in other news, the return commute got a bit noisy. no shenanigans either. and just in time to install a new wheel!
i'm really torn about upgrading the phase wires while i'm at it. i'd rather not remove that side cover, but it'd be dumb to leave it as is and worry that the oil will damage it...
ah well, let's see what another night in the garage brings...
GCinDC
1 GW
1 GW
Postby GCinDC » Wed May 16, 2012 8:12 pm
tested LM35 hooked up to HK VT (voltage/temp) monitor. used ebike tester since it puts out 5v.
some variance but motor was still cooling down..
GCinDC
1 GW
1 GW
Postby Scruffoid » Wed May 16, 2012 11:19 pm
Wow Im dizzy. Nice camera angle.... lets see you do that one at 35mph
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewtopic.php?f=6&t=38000&p=553791#p553791
Scruffoid
Postby GCinDC » Thu May 17, 2012 12:58 am
jbwelded the halls in place so they don't move when oil is sloshing in there.Image
drilled a vent hole close to axle, and at angle to discourage leakage. Image
took a closer look where the wire exits and decided not to mess with it. Image
turned the bike over and water came dripping down out of who knows where... and when i flipped it back, the CA was full of water!
turns out there are quite a few open holes under there.
i tossed a couple washers in the drive side and the wheel lined up pretty well:
long overdue brake bleed. yes, i removed the pads. and yes, that's a seasoning injector.
all cleaned up and ready to go tomorrow. tested it up and down the street. got to 34mph in the middle of the block so that's good. i shouldn't slow down traffic. temp rose to 44c after i parked. brakes work great.
GCinDC
1 GW
1 GW
Postby Hyena » Thu May 17, 2012 3:49 am
Nice one, I'm keen to see how you get on with the oil. Have you put it in yet ? If so what sort ?
Looks like a fairly large hole. You adding a breather hose to it or just leaving the hole ?
Hyena
Postby shorza » Thu May 17, 2012 4:28 am
Looking really good Greg.
GCinDC wrote:took a closer look where the wire exits and decided not to mess with it.
On my Crystalyte, the black plastice spacer between the motor and cables tries to spin with the motor, jamming the cables against the axle.
How did you get around this?
shorza
Postby GCinDC » Thu May 17, 2012 12:37 pm
no bets on if i'll make it thru the day w/o a breakdown??
Hyena wrote:Nice one, I'm keen to see how you get on with the oil. Have you put it in yet ? If so what sort ?
Not yet. I'm trying to be scientific. :lol: I want to see how the motor runs w/o the oil. and the answer is not surprisingly: HOT. :lol: i took it easy today as it's too hard to read the monitor in the sunlight, let alone video it. i'll do my night ride/video tonight, if i can keep my eyes open.
but it's amazing to see the difference of a vented hs3540 in a skinny bike wheel compared to a many pound MC wheel. reminder to self to test no load amps on both.
ambient was 20C this morning, but the motor was up to 80C after .5mi! i got up to 40mph after a bit, so was happy about that and for the long downhill run it rose only gradually, and hit 125C at mile 4. the hs3540 bike wheel woulda been at 85C max at the same time.
i'm counting on oil cooling. otherwise, i'd have to baby the motor.
and after i get a good comparison at 20s, i'm planning to get up to 24s, just to maintain my hs3540 bike wheel speed. (and i'll sacrifice regen at this point if it generates too much heat..)
but you should be proud of me for not doing stupid jumps on it yet. or even curbs. i don't have enough range in the spoke threads to get crazy just yet.
shorza wrote:On my Crystalyte, the black plastice spacer between the motor and cables tries to spin with the motor, jamming the cables against the axle. How did you get around this?
this question almost induced morning sickness when i read it. surely that issues been resolved by now?? i never really understood it, but your description is pretty clear. i almost chopped the plastic off with a chisel this morning, but i've got the wire tied fast to the dropout to prevent rubbing against disc bolts.
i think i will have to remove the wire side cover before the oil. i'll need to caulk the holes over there, if not use more jbweld. it's the right thing to do.. :roll:
oh, and hyena, as for the drill hole, i tried not to overthink it. i just had KISS in my head and was too busy second guessing myself about the proper angle to go at to counter leakage via centrifugal forces.. i like the idea of a short clear plastic tube in there.
and something tells me i should fill the motor on it's side, in order to measure how much goes in.
but that seasoning injector is pretty fun, and made quick work of the mineral oil. (can you believe me the lbs that sold me the wrong hose also said i could use any old mineral oil... so not true.)
time to stop writing. i feel like i'm jet lagged right now... :lol:
GCinDC
1 GW
1 GW
Postby shorza » Thu May 17, 2012 5:11 pm
GCinDC wrote:this question almost induced morning sickness when i read it. surely that issues been resolved by now?? i never really understood it, but your description is pretty clear. i almost chopped the plastic off with a chisel this morning, but i've got the wire tied fast to the dropout to prevent rubbing against disc bolts.
Haha, I'm not riding it like this yet. If it causes dramas, I'll get rid of it and just cable tie the cables in the axle.
Sorry, i still can't understand how yours doesn't try to spin with the motor.
shorza
Postby GCinDC » Thu May 17, 2012 7:02 pm
ilia just told me the washer's been improved. it's not perfect, but it's better.
GCinDC
1 GW
1 GW
PreviousNext
Who is online
Users browsing this forum: agniusm and 7 guests
