A-Lines Abound: Back in action... and new PIX!
Re: A-Line's Abound: Another A-Line build...
Postby MattyCiii » Sat Apr 14, 2012 12:29 pm
One more angle on that replacement dropout assembly:
After looking at all the pix I notice I don't have any shots of the back side and how closely that mates to the original. Where did I leave that camera...
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
MattyCiii
Postby adam333 » Sun Apr 15, 2012 5:34 pm
The piece look great!
I am curious about the price from this supplier. I didn't know they exist. Pretty cool to get a quote online.
adam333
1 W
1 W
Postby fractal » Sun Apr 15, 2012 7:20 pm
hey matt!!! great work!!! im very happy for you!!! they look great. mine will be ready next week. its been a challenge but seeing the results sure feels good.
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby MattyCiii » Sun Apr 15, 2012 7:37 pm
adam333 wrote:I am curious about the price from this supplier. I didn't know they exist. Pretty cool to get a quote online.
Adam, the price was in the same ball park as the prices you researched for David and I. I would have paid $236 for one copy of each side, but decided I'd "buy in volume and save". I got 3 of each side for $295 each side, total cost $590. So now I have some small aluminum sculpture pieces :lol: More details here: Machining service: eMachineShop.com (A user review)
fractal wrote:hey matt!!! great work!!! im very happy for you!!! they look great. mine will be ready next week. its been a challenge but seeing the results sure feels good.
Thanks! One of the reasons I "branched off" from our previous combined effort was the hassle of re-doing all those STL files. I know my best bet was to re-draw from scratch, and so went with the eMachineShop CAD tool. I can't wait to see how yours turn out. I'm also quite pleases with the whole experience of eMachineShop.
MattyCiii
A-Line's Abound: Now it rolls down hill
Postby MattyCiii » Tue Apr 17, 2012 7:35 pm
Side 2 arrived today. About a half hour later I got it installed.
Glamor shot - both custom dropout pieces installed...
Here's the rest of the assembly - modular dropouts from Paragon Machine Works.
I added 0.1mm all around to my measurements to ensure a snug - not loose fit. Man, that was just about perfect. It had to be pressed in, but with hand strength only:
The washer:
The first bolt:
When fully tight, the bolts are totally inset:
A shot of the inside. That gap is so small you can't slide a sheet of paper in that gap.
MattyCiii
Postby MattyCiii » Tue Apr 17, 2012 7:42 pm
Here's the whole thing, also posted n the first page.
In my rush to mount the rear wheel to go for a test roll, I put it on backwards! Also note the rear brake mounted to the front. Don't ask, that'll be righted soon.
The huge space in the triangle in front of the rear wheel is where the Shumaker drive and Astro 3220 will go...
MattyCiii
A-Line's Abound: It's too short!!!
Postby MattyCiii » Wed Apr 18, 2012 8:24 am
The bike is too squat for cranks!
I can't say I wasn't warned, but the bike is too short when I put 180lbs of me on the seat. 172.5mm cranks will touch the ground. Matters will get worse when I add batteries, etc.
Strategies for "heightening"
  • I have 155mm cranks on order, but that only buys me 1/3 of an inch. Enough that I won't scrape earth when sitting still, but too close for comfort if I'm pedaling when the suspension compresses.
  • My rear shock is currently 9.5". I can make this longer:
    • I can gain an some height by getting the longest Fox DHX at 10.5" (Do bicycle shocks come in any greater length?). But an inch in the shock translates to (far) less than an inch in height, right?
    • I can maybe go for a scooter shock, like this one. It's 12" long and $100 - two great reasons to at least consider it. Down sides are uncertainty in my ability to mate it with the bicycle mount points, and the fact that every inch I add to the shock changes the suspension geometry, with possible bad side effects. What else should I consider?
  • Larger wheels. I think this is a no-brainer, upgrading to 18" moped wheels should gain me about 2" in height, right?
I'd love to hear from the community on this one!
MattyCiii
Re: A-Line's Abound: It's too short!!!
Postby sn0wchyld » Wed Apr 18, 2012 8:56 am
hehe... 'i told you so' :mrgreen: sorry couldnt resist!
yea i'm not really happy with mine, and thats with a 26 front and 17mx rim rear (22 inch effective). I cant pedal on corners or through any bumps, and the loss of rollover height is a bit of a pain too.
How hard would it be to make some new 'dropout' sections to those dropouts? ie remake the black smaller part of those dropouts to add an inch or so of height?
Also, is your front shock at its max height? I've added about 2cm to mine just by moving the clamps up the shock.
You can also add an inch to your travel (so maybe .5 inches to your ride height) by choosing the lower of the two mounting holes for the rear shock.
Finally, check your sag %. since this is primarily a onroad bike you might be able to go with say 25 or 30% sag rather than the usual 40ish. should be able to gain a inch or two there too!
good luck mate.
ps
are you sure the shock is supposed to be in that way? or doesnt it matter? on my norko its got the resovware on the top. being round that way opens up some more space in the triangle...
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby Timma2500 » Wed Apr 18, 2012 8:57 am
MattyCiii,
Awsome build mate! Those dropouts are fantastic, so clean and an elegant solution! :mrgreen:
Going with a longer rear shock will more than likely need a longer fork to balance the height gain to keep your head angle where it should be.
It'd be worth looking into exactly how much extra length you would gain by going to normal DH forks, it may be less than you think as those Leftys look fairly long already.
Where as going to larger rims and tyres stands to gain you anywhere from 2" to 3" in height depending on your diameter choice.
I'd go with the bigger rims for sure. Someone on the site would surely buy your current wheels to help get back some valuable ca$h.
Just my 2c, hope it helps :wink:
Paul :D
Intense M3 DH, HT3525 / 5kw, 18fet, 20s 10ah nano lipo
Norco Empire 5, 80100 130kv / 5kw, HV160, 12s 12ah lipo
Under Construction
Timma2500
Postby etard » Wed Apr 18, 2012 9:16 am
Did I hear somebody say they were gonna sell their rims?? :lol:
That sucks man, personally I would go with bigger wheels for aesthetic reasons alone, it looks kinda funky in current guise. Those dropouts are real nice, I'm jealous! One option might be to put a bigger wheel on front and then use those two front shock mount holes to build an extension tower that would jack the rear triangle down an equivalent amount so that your head angle stays the same. Another option is pegs instead of pedals.
etard
Postby MattyCiii » Wed Apr 18, 2012 10:33 am
sn0wchyld wrote:hehe... 'i told you so' :mrgreen: sorry couldnt resist!
me: :oops:
sn0wchyld wrote:are you sure the shock is supposed to be in that way? or doesnt it matter? on my norko its got the resovware on the top. being round that way opens up some more space in the triangle...
In its final form I'd like to ride with the reservoir on the bottom, giving me more space in the triangle for LiPo. But until I mount batteries, I can play:
  • I can't presently use that "lower mount hole" because the reservoir will bump the cable mount points down inside the seat stay. Of course I can always just grind them off with the dremel tool...
  • What I can and should do is ride the bike with the reservoir up, and with it down, and see if there's any difference. That and comb the Internet for opinions. I'd hate to be using the shock wrong and ruin it just to gain a little space.
Timma2500 wrote:MattyCiii,
I wish! The problem is what I've built is so extremely specialized. Lefty hub up front is not standard - heck, the spoke length is different on the left than the right. In the back is a NuVinci, pigeon-holing that wheel into the RC build niche. So starts the "spare parts pile" so many e-bike veterans cultivate...
Timma2500 wrote:Just my 2c, hope it helps :wink:
Definitely!
etard wrote:...personally I would go with bigger wheels for aesthetic reasons alone, it looks kinda funky in current guise.
I second that! I thought I'd need all that extra room out back to fit my planned RC drive, but with it all built up it's clear I can spare at least 2" out back. Plenty of room up front too.
etard wrote:One option might be to put a bigger wheel on front and then use those two front shock mount holes to build an extension tower that would jack the rear triangle down an equivalent amount so that your head angle stays the same.
I really like that idea. It should not be too hard to fabricate said extension tower.
etard wrote:Another option is pegs instead of pedals.
When built this thing will be a beast to pedal, but (as all novice e-bikers say...) I do plan to pedal it a lot.
MattyCiii
Postby adam333 » Sat Apr 21, 2012 2:55 pm
The price is pretty good.
I would also consider bigger wheels personally. I'm using 26 inches front and back on mine and I like the fact I can pedal in curves. ( I "fake pedal" mine just to avoid drawing too much attention on the cycling trail :) ) Next step is to find a schlumpf rep that is still open in the Montreal region....
About your rack fixation on the bike, I used this system on my previous one, and had a lot of issue having it swing left and right with about 15 pound on it. I would go with something more stable personally. If only the controller is going there, it could be fine though.
adam333
1 W
1 W
Postby MattyCiii » Sat Apr 21, 2012 8:28 pm
Thanks Adam. I have 18" moped rims, tires and tubes on the way. Once they arrive, I can measure the ERD and get spokes. Then I'll be building me some new, larger wheels!
Anticipation...
MattyCiii
Postby MattyCiii » Wed Apr 25, 2012 9:34 pm
Measure twice, cut once.
Remember when I said this?
MattyCiii wrote:Larger wheels. I think this is a no-brainer, upgrading to 18" moped wheels should gain me about 2" in height, right?
About 5 days after placing my order for all the wheel parts, it hit me: moving from 16" rims to 18" rims won't gain me two inches in height, it'll gain me only one!
Epic Facepalm!
But good luck was with me. My source for rims hadn't shipped yet (order successfully cancelled), and the supplier of my tires had them on backorder (also cancelled).
So now I have 21" wheels on order. Let me do the math out loud this time: 21"/2 = 10.5" new radius. 16"/2 = 8" old radius. Subtracting gives me a difference of 2.5". Damn that was easy - wish I could have gotten it right the first time!
MattyCiii
Postby doc007 » Thu Apr 26, 2012 12:20 am
MattyCiii wrote:Measure twice, cut once.
Epic Facepalm!
I think you should also consider the tire thickness. Some tires are low profile (ex. road racing) and others are high profile (ex. downhilling, freeriding). With thicker tires you could easily gain an inch on the radius.
ps nice dropout design im sure someone will buy those "paperweights" off you to help offset your initial investment. cant hurt to post an ad in the for sale section. good luck! looking forward to see how the build progresses.
doc007
Postby neptronix » Thu Apr 26, 2012 12:54 am
145mm sinz cranks.
That's how i get clearance on my hardtail, which came with a rather low BB to start with.
Also, longer rear shock can get you some rear lift up. That's a downhill bike, so some rear lift could help it. Just an idea.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby MattyCiii » Thu Apr 26, 2012 5:33 am
doc007 wrote:I think you should also consider the tire thickness. Some tires are low profile (ex. road racing) and others are high profile (ex. downhilling, freeriding). With thicker tires you could easily gain an inch on the radius.
Thanks Doc. My new 21" rim is only 1.6" wide. A narrower rim should force a tire to be somewhat taller compared to mounting on a wider rim. All within reason of course. I have a 3" by 21" moped road tire on the way, hopefully the combination will work! It's hard to find 21" motorcycle/scooter/moped tires much narrower, and I can't go much wider than 3" wide without bicycle frame clearance issues...
doc007 wrote:ps nice dropout design im sure someone will buy those "paperweights" off you to help offset your initial investment. cant hurt to post an ad in the for sale section. good luck! looking forward to see how the build progresses.
Will do! Of course I have a very small audience to market to - 2009 A-Line owners - but never say die, right? Hopefully this build will come together nicely - and soon - giving me something to show potential customers, mainly a nice component of A-Line owners wanting to go RC.
neptronix wrote:145mm sinz cranks.
Thanks Nep! Unfortunately I backed myself into a corner on this build... I want to use a Schlumpf Speed Drive on this beast so I'm limited to the smallest Schlumpf (155mm) cranks. But the rear shock is still definitely an option. I can go up an inch and still use a bicycle shock, or if I need longer punt and go with a [url]dirt bike shock[/url], which allows me flexibility in mounting the reservoir to boot.
Driving around yesterday I hit a pothole that literally made my F150 jump laterally. I can't wait to try this bike on the same pothole at speed and see how it handles... It will be jarring certainly, but on the bike at least it won't shake my fillings loose...
MattyCiii
Postby recumpence » Fri Apr 27, 2012 4:12 pm
Guess what I have sitting here for you? :wink:
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby MattyCiii » Fri Apr 27, 2012 6:12 pm
recumpence wrote:Guess what I have sitting here for you? :wink:
Matt
THANKS Matt!!!
As soon as it's mounted I'll be posting pix for sure!
MattyCiii
Postby MattyCiii » Sat Apr 28, 2012 12:15 pm
One step closer to getting this project on the road:
I've completed my first Schlumpf/ATS drive installation. I'll hopefully get some good robust testing in on my "daily driver" Dahon folding bike, enough to decide whether to install a Speed Drive (1:1.6 overdrive) on the A-Line, or should I install a High Speed Drive (1:2.5 overdrive).
Considering how much weight and rotational inertia this bike will have, I plan to gear it way down. Actually I'd be smart to price some smaller chainrings and see what's available in case my 42t front/21t rear is not low enough. A High Speed Drive will allow me to pedal much more with the electric drive in parallel I think, but the Speed Drive has the advantage of - well, I already own one.
MattyCiii
Postby MattyCiii » Wed May 02, 2012 5:09 pm
OK,
Parts for the new wheels are starting to arrive. Here's the best "test fit" I can do without - you know, rims or spokes. This will be a tight fit both front and back! I have exactly 100mm clearance up front - and 100mm of travel.
In the rear, the A-Line chain stays narrow near the pivot (to clear feet/pedaling), and the tires have about 5mm each side clearance.
I'm going to remove that rear rack - I have a better option in the works. And the seat will have to come waaaaay down.
MattyCiii
Postby MattyCiii » Wed May 02, 2012 5:38 pm
Looks like, according to the Lefty manual, I need to have 10mm of space between a fully compressed strut and the steerer tube. The '29er version of the Lefty has 10mm spacers that prevent bottoming. Looks like I might need one of those spacers...
MattyCiii
Postby adam333 » Fri May 04, 2012 9:20 am
MattyCiii wrote:Thanks Nep! Unfortunately I backed myself into a corner on this build... I want to use a Schlumpf Speed Drive on this beast so I'm limited to the smallest Schlumpf (155mm) cranks. But the rear shock is still definitely an option. I can go up an inch and still use a bicycle shock, or if I need longer punt and go with a [url]dirt bike shock[/url], which allows me flexibility in mounting the reservoir to boot.
From the Schlumpf price list, an additional 40 euro will get you the following crank lengths: ( from price list pdf )
Extra charge for special crankarm
lengths: 102, 114, 127,
140, 155 straight shape, 160, 165, 170,
172.5, 175mm
(all except 155 offset)
http://www.haberstock-mobility.com/en/products/schlumpf-drive.html
adam333
1 W
1 W
Re: A-Line's Abound: Size does matter...
Postby MattyCiii » Fri May 04, 2012 9:25 am
Thanks Adam!
I have the 155mm crank arms in hand so I'll stick with that for now. Good find though, I probably should have cast a wider net when looking for options.
As it stands, those big wheels should get me the ground clearance I need to <cough> get this project rolling agin.
It looks like you're thinking about a High Speed Drive for your A-Line? I'll definitley get info posted here when mine comes in, and once I have the unit in hand I can answer any questions you have.
~Matt
MattyCiii
Postby adam333 » Fri May 04, 2012 3:17 pm
yep, I contacted Ilia, I think I am ready to go that way.
adam333
1 W
1 W
PreviousNext
Who is online
Users browsing this forum: Groundthinking, motornews and 4 guests
