Specialized Big Hit FSR with midmount
Re: Specialized Big Hit FSR with midmount
Postby Tench » Wed Mar 21, 2012 4:44 am
velias wrote:I'm interested in the physical throttle. What type is it?
It looks like a standard half-twist hall throttle. but you have the grip going over it? did you do any physical mods to the bike or throttle?
Or is that a magura throttle with your own grip?
The throttle was the one on the ebikes .ca website, i did find the tube was a little short so i cut the grip off extended it to full length and fitted a set of medium compound Renthal grips, it is a hall sensor throttle.
I also got to grips with the small issue i was having with the CA not limiting properly, it now all works properly and runs even better with more power and speed, had a quick spin upto 40mph the other day :D it is now everything i hoped it would be when i started this project.
Project one viewtopic.php?f=28&t=20304&hilit=tench
Project Two viewtopic.php?f=6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
Tench
Postby Whiplash » Wed Mar 21, 2012 8:21 am
waynebergman wrote:Thanks for sharing all the info on your project with the foum. I have been following this thread with interest and also Whiplash's mid drive with the mac. I have just recently got my first electric on the road.........an HS3540 used as a direct drive hub. Happy with it for a trouble free project which was good for a starter bike but the two disappointments with my bike are not having gears to get the motor into its happy zone for climbing and also the DD does not seem to coast that freely when used as the rear wheels hub, lots of drag. Way more draq then I was led to believe.
My next bike will be a mac mid drive and I am glad to hear you are thinking of something like this as well, I will be watching with interest should you go this route. I have been inspired for sure seeing your bike, looks awesome, quiet, smooth, light weight...............its got it all. It would be real cool to have a mac mid drive with a 20 mile range that was super light and some kind of an internal geared rear hub maybe like the Rohloff or something, this is my dream anyways.
Thanks again for showing us what can be done with a project like yours. Awesome!
Yes, the MAC is an excellent choice!!
Beautiful build Tench!
viewtopic.php?f=28&t=34158
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
1 GW
1 GW
Postby iovaykind » Wed Mar 21, 2012 9:16 am
Do share what you did on the CA!
iovaykind
Postby Tench » Wed Mar 21, 2012 9:37 am
I have not modded it to work better in any way than any other CA, this one just had a continuity problem with one of the wires between it and the controller which was causing me a problem with the programing of the throttle overide functions, now it is all working correctly i have been able to fine tune the throttle output voltage with a potentiometer and get the voltage settings right in the CA to work best with it, which has unleashed the true potential of the build.
Whip, been watching your build too, same idea slightly different execution, great minds think alike!! :D I too think it is the best way to build an off road bike if you want all the benefits, quietness and efficiency of a hub motor with the verstility of a mid mount, gears, weight distribution etc. I am thinking of doing another with a MAC, lighter, slightly smaller dia i think aswell?
I keep getting thoughts about doing one with a Cro, but to a different design, i am either going to have to do it or get therapy! :evil: but one of Matt's 4" motors would be an exciting prospect too!!
Tench
Postby Idontwanttopedal » Wed Mar 21, 2012 3:21 pm
Like see cromotor setup like this
Idontwanttopedal
Postby Whiplash » Wed Mar 21, 2012 10:04 pm
Yikes a Cromotor? That would be INSANE as a midmount! More like a dirtbike!
Whiplash
1 GW
1 GW
Postby Accountant » Thu Mar 22, 2012 5:02 am
Whiplash wrote:Yikes a Cromotor? That would be INSANE as a midmount! More like a dirtbike!
correction : IT WILL BE INSANE.
Accountant
Postby Tench » Thu Mar 22, 2012 5:17 am
:shock: :shock: :twisted: :twisted: :mrgreen: :mrgreen: 8) 8)
Tench
Postby toolman2 » Thu Mar 22, 2012 6:22 am
yep, it would be a bit insane, cos there are lighter, higher efficiency, more powerful and compact motors to chose from once you are no longer putting it in the wheel, where the cromotor is designed to go..
toolman2
Postby Whiplash » Thu Mar 22, 2012 8:05 am
They are also noisy and hard to control unless there is something I have not seen yet? The trails I ride would be deadly with a violent RC motor, you would almost certainly end up dead...One slip of the throttle and.... oops!
No offence, but for now RC drives are for high speed street and maybe some easy singletrack otherwise you could easily get hurt. My little 63/74 was still pretty violent and it had halls! They just tend to be too touchy for my kind of riding at least...
Whiplash
1 GW
1 GW
Postby Tench » Thu Mar 22, 2012 8:55 am
I agree, i have lightened the HS in my build a little, i may even add some flywheel weight in future to calm down the pickup and smooth the delivery even more, a little well placed weight might be worth a small increase in the gross weight. The RC motors are much noisier and snappy, more suited to high speed setups, thats not what a capable trail bike needs, i want torque from low revs with accurate control. I wonder if anyone has ever done an RC drive that included a flywheel for this purpose?
Tench
Postby gwhy! » Thu Mar 22, 2012 9:44 am
Tench wrote:I agree, i have lightened the HS in my build a little, i may even add some flywheel weight in future to calm down the pickup and smooth the delivery even more, a little well placed weight might be worth a small increase in the gross weight. The RC motors are much noisier and snappy, more suited to high speed setups, thats not what a capable trail bike needs, i want torque from low revs with accurate control. I wonder if anyone has ever done an RC drive that included a flywheel for this purpose?
Its not nessersary to have a flywheel on the rc setups as long as the throttle and gearing is setup well , running the rc motors on 48v do tend to make them noisy but if running through the bike gears the voltage can come down to 24v ( this make the ride comparable to the noise that a hub motor makes ) I am currently thinking remaking my hub road bike to run with a rc motor running on 24v with a current limit of around 120A should be more than enough to play with the other traffic :lol:
gwhy!
Postby toolman2 » Thu Mar 22, 2012 10:02 am
i think i know what you both mean here ( ive added flywheel weight to a moto for tight single track) but for any electric machines that have a heap of torque like these ive found the problem to be our speed based throttle, i did end up getting fetchers torque based throttle working ok after a fair bit of grief (and kellys have the option also) and it really is heaps better more controlled and easier to ride, might even save your life whiplash. :lol:
im thinking once that is sorted, then you just want the quickest response, and lowest motor inertia possible? -and yes good torque from low revs with accurate control is doable for all these motors.
toolman2
Postby Tench » Thu Mar 22, 2012 12:00 pm
I suppose it depends on your needs and preferences, a quick pick up is not near the top of my list, doing a full lock turn feet up to negotiate a tree and then followed by a bit of a climb, smoothness and control along with strong torque is what matters, i like riding the rocky technical trails where the bike needs the ability of a trials bike but with a decent turn of speed too, so a slow action throttle, low gearing with a controlled pickup suits me better. You want to try riding a hub motor when it is geared down 3-1, believe me it picks up plenty quick enough without looking for a lighter snappier motor! But then we are back at personal preferences, we each build a bike to suit our own likes and needs, there are so many variables there wont be one bike thats suits all uses for all people, so each one of us will have our own idea of what the perfect bike will be. This one i have built here is pretty good for the purpose i intended, but being only my second ebike build i am sure i can learn from this one to make the next one even more capable of meeting my perception of a usefull ebike and hopefully even more versatile too.
Tench
Postby lostrack » Thu Mar 22, 2012 12:44 pm
I tell you what guys...
DON'T STAND UP!
the reason you can't use a fast pickup motor for mountainbiking at the moment, is the power is so instant, you can't stand up while riding it.
I tried it on my 3220 RC setup (dialled down to 160 amps) and it threw all my weight to the back, which then made me turn the throttle more (think : the angle of your hand on the grip!). It's a real struggle NOT to flip over. Brakes VS motor are pretty well matched, so you need real control to keep it on track.
The only way I found to do this, was to sit down on the saddle - and who does this when riding a MTB on a downhill course?
I have a speed throttle which is rediculously twitchy. The RC CA setup may help
lostrack
Postby knoxie » Thu Mar 22, 2012 3:43 pm
Yes Tench the RC setups are notoriously twitchy as my buddy Deec found out on the now infamous video we shot around my house, see below :) also RC controllers dont like low RPMS either, this is why I think what you have made is pretty much ideal, I think a geared down BMC might even be a bit too strong, I like the RC rigs a lot though and for fast trail riding and street riding they are great :mrgreen:, what you need is a throttle response switch where you can quickly dial in say on 3 positions the response, but then I guess the newer Lyen controllers already do this to a fashion.
Spoke with Dave last night, what a top chap, we were all going to meet at the weekend but its been called off last minute sadly, ahh well give me some time to get a better off road solution sorted out.
Oh and this amazing video from Luke just showing what electric power can do to gas bikes, this will make you laugh!!
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby binlagin » Thu Mar 22, 2012 4:14 pm
Those two videos... I've never been so entertained! Thx for sharing lol
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby deecanio » Thu Mar 22, 2012 5:30 pm
all points agreed in relation to RC.
Hub mid is a great solution, im not sure about putting in a cro though, i was under the impression that using a standard mtb deraileur and sprockets would have a limit as to how much power you could use, for arguments sake lets say its 4kw, i would think that the best hub to drop in to such a solution would be one that hits 4kw with the lightest weight penalty no? - still i'm of the opinion that hubs are most known about so so using them as a mid gives a wealth of known setups and would improve things no end having the hub mid frame, allowing you to bounce it around a bit ;) - certainly going for a hub mid next.
Knoxie, what happened to the meet mate :( ???
Also, yes wiring almost finished, going to test ride v soon ;)
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby knoxie » Thu Mar 22, 2012 5:46 pm
Hi Deec yes that was in 2010!! cant believe it was that long ago :? its had a few hits that video :-) That Zero really rocks doesnt it, I think a Mid drive is a very good option if implemented correctly, there are a lot of big DH bikes with loads of space under the frame due to the design where you can mount a mid drive, you of course have to watch the drive if you ride really hard off road.
Yes shame the meet is off however It is going to be rescheduled soon so maybe you can make it then? there are a few more UK riders that have expressed an interest in meeting up as well.
Looking forward to seeing your ride on the tracks, get that Gopro charged up!
knoxie
Postby Tench » Thu Mar 22, 2012 6:13 pm
Well if the new meet is not arranged for the last weekend in any month i should be able to make it. I am shooting in the first round of the UK championship series this weekend, then next month i am doing the world championships then the last weekend of every month untill October is the remaining rounds of the UK series, i cant knacker myself out on the bike and shoot in the same weekend!! i,m not 21 anymore! Just won the Midlands winter series aswell :D http://midlandshftleague.weebly.com/index.html
click hall of fame, first pic :D bodes well for the rest of the year to be on good form at the begining, scored 391.47% out of a possible 400 8) Chap who won the .22 class (3rd pic down was also using one of my guns)
Back to bikes, if i did go for a mid mounted cro i would not be putting it through cycle gears and a derailier, i have an unconventional alternative in mind :idea: 8) i wouldnt want to build something that was unreliable or even unrideable, whats the point it that! it would have to be more capable than this or why bother :D Just waiting on motor specs and dimensions to come through so i cant see if it is, was going to say possible but thats the wrong word, i believe anything is possible, to see,, no to work it all out 8)
So lets get a ride organised, where is it going to be, i could plan a route in derbyshire if i knew what sort of mileage we should be planning and type of terain you want to ride?
Tench
Postby knoxie » Thu Mar 22, 2012 6:31 pm
Sharp shooting Simon!! I have a really nice BSA airsporter S in the cupboard, guess its all about compressed air and not springs these days though :)
There is some good riding in Derby for sure! I need to get an off roader sorted out as my BMX isnt man enough for that :lol: I have a nice frame already just need to get the motor in it, Cro mo mid mount with a custom frame would be mental!! ha ha I know you dont like the weight in the wheel so its the only option for you maybe? although if you are going to go that way then maybe just a big motor like a Lemco or Etek might be better? controllers are cheaper too! and the controllers that are available have better throttle settings.
I would be up for a meet, lets do a north and south meet! keep everyone happy :D if we start it...they will come :wink: #fieldofdreams
knoxie
Postby toolman2 » Thu Mar 22, 2012 7:46 pm
lostrack wrote:I tell you what guys...
DON'T STAND UP!
yep, its called whiskey throttle, happens on powerful dirt bikes, highly amusing, its when you get thrown back from a small throttle input, and as you fall back your hand grabs more throttle from the extra twist, and your off the back before you can say "gee that throttle is touchy".
that kona vid could not be a better example of it, very enjoyable to watch :twisted: also see the poor dude who ends up shoeless on the ground with lukes agni bike, a hv160 rc controller seems to be a key ingredient in for quality gravel rash. -we do want halls and good modulation from the controller and ill admit we dont allways get this, but rc stuff meant for planes without current control do seem a little "touchy".
but honestly guys, if you only believe one thing i say: torque throttle is what we need.
you know how it goes, the first millimeter of throttle (with all our "normal" speed based throttle controllers) gives you absolute full power, untill you get to say 10kph, then that sudden take up is the second mm of throttle, at near full road speed the first 90% of your throttle does nothing and the sudden take up happens in the last mm of throttle and at no point do you get good smooth control, its a drama on any of these high torque machines, and we are just not used to it cos all (petrol) engines are not like this.
you need to chose the torque you want with your hand, its what is natural for us so we are in precise control of how much we get thrown back, if you watch that kona stinky vid you will see this clearly, torque throttle is how we can have 5, 10 or 20 times this power level under some level of control with ic engines, and why these machines can be so bitey regardless of what type of brushless motor we are using. was it you tench haveing a go at the torque throttle a while back?
toolman2
Postby Kepler » Thu Mar 22, 2012 10:27 pm
So How does a torque throttle actually control torque? Our do you mean Current throttle?
Current Rides
BBS02 powered Specialized Camber: LATEST ROAD and SINGLE TRACK WEAPON http://www.endless-sphere.com/forums/viewtopic.php?f=6&t=60375
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
83 Volt 3 kW Stealth Fighter: OFF ROAD http://www.stealthelectricbikes.com/
Kepler
Postby toolman2 » Thu Mar 22, 2012 11:33 pm
Kepler wrote:So How does a torque throttle actually control torque? Our do you mean Current throttle?
yep, current based throttle, rather than speed, when we all use speed based (cos our controlers happen to be that way) with grunty setups then you touch the throttle a tiny bit (requesting say only 10kph)
and you get flipped straight off the back as the motor gives its all to blast you from a standstill to that speed without remorse, watch the kona vid for a refresher and be sure to pause on the graised arm for the end result.
that kona could well become a very nicely behaved gentle AND powerful machine (our controllers are meant to be in "control" of our motors, as they have precise position feedback many samples for every single rotation) and i dont think more weight or a throttle delay is what your after? not when we should have better control of the motor than any other machine around (stepper motors and servo motors like for a cnc lathes are not much different to all our brushless motors)
do try and give this just a little thought people, it will help move us all forward -dont make luke have to roll up here and explain how sweet and gentle his 80?kw bike is at low speed yet 10 times the power to flip you if desired, with an excellent controller setup. :lol:
theres a circuit somewhere here that was "fetchers current based throttle" or similar that i cant seem to find it yet.
the minuet the machine easily has the power to blow you off the back on take off, this problem wants looking at, and i figure we are all heading that way, and as a rider
it seems better to have a say in the matter of torque, cos some days you just dont feel like laying down behind your bike, other times (like trials stuff) you need good control of that massive launch to climb stuff.
toolman2
Postby Tench » Fri Mar 23, 2012 3:34 am
I totally agree that there is massive room for improvement on the throttle's control over the motors output, it must be remembered though that the motor cycle with 150+bhp that is very easy to control has a lot of differences, at low rpm the gas engine makes very little power so is easier to control than it would be trying to pull away with it at the red line, full throttle at 2000rpm does not result in 150bhp trying to kill you, an electric motor has all its torque available all the time, maybe an rpm based amps limit in addition to the throttle could create a power curve more like we are used to with ice?
I have tried the CA current throttle setup, it was a little abrupt and only fitted to a modest cyclone so from that it would be hard to tell if there was a worth while improvement over a throttle connected directly to the controller, i should try that again with a higher power setup to feel the difference, allthough while typeing this i have had an idea :idea: :D
Tench
PreviousNext
Who is online
Users browsing this forum: OldTimer and 6 guests
