New project
New project
Postby Ossielocal » Tue Apr 03, 2012 3:13 am
Hi peoples ,
Just like to say going to do another ebike with dual suspension .Brought a brand new Giant Trance x3 for $1600 just have to wait 2 weeks though .. at the moment my ebike is a Alias Giant bike .
(93.58 KiB) Downloaded 3 times
Ossielocal
Re: New project
Postby Ossielocal » Sat Apr 21, 2012 12:47 am
Started the new bike ,hoping to get some welding done this week and next week get the box powder coasted gloss black .
Ossielocal
Re: New project
Postby Timma2500 » Sat Apr 21, 2012 1:16 am
*Subscribed*
Nice bike and plenty of triangle space to work with :)
Paul :D
Intense M3 DH, HT3525 / 5kw, 18fet, 20s 10ah nano lipo
Norco Empire 5, 80100 130kv / 5kw, HV160, 12s 12ah lipo
Under Construction
Timma2500
Re: New project
Postby Ossielocal » Sat May 05, 2012 3:35 am
Finely finish ,thinking of using some hobbyking batteries down the track .
Should of brought a dual suspension bike ages ago the ride so smooth .
Ossielocal
Re: New project
Postby Scruffoid » Sat May 05, 2012 4:11 am
Looks really neat and tidy!
So what are your side covers made of and how do you get the attached etc.
Just interested for ideas for my next battery box.
Thanks
Scruff
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewtopic.php?f=6&t=38000&p=553791#p553791
Scruffoid
Re: New project
Postby Ossielocal » Sat May 05, 2012 5:52 am
Gday Scruff ,
I used 1.6 aluminum sheet for the hole box and made the two brackets holding the box on top with 1.6 and where the drink bottle goes i just used two longer bolts to hold the bottom of the box, it's pretty strong .Battery is a nice fit it's a 10amp 48v ping ,.i'll add some close up pics if you like ..
Scruffoid wrote:Looks really neat and tidy!
Thanks
Scruff
Ossielocal
Re: New project
Postby Scruffoid » Sat May 05, 2012 5:57 am
Yeah i was more interested in the sides of the box only. Are they hinged on or bolted. are they two pieces or one big piece.
--- Ahh i just zoomed the pic way in i can see some screw or something there.
Scruffoid
Re: New project
Postby Ossielocal » Sat May 05, 2012 6:08 am
Oh yeah one side is screws and the other side is welded on .
Scruffoid wrote:Yeah i was more interested in the sides of the box only. Are they hinged on or bolted. are they two pieces or one big piece.
Ossielocal
Re: New project
Postby Whiplash » Sat May 05, 2012 8:39 am
Very clean! Nice bike i cant wait to get my TIG welder so i can do some nice solid boxin! Nice bike for sure!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Re: New project
Postby Tom L » Sun May 06, 2012 2:24 am
Your first bike looks very similar to what I've been planning for my Alias. A few of questions if you don't mind:
1) Is that a Mac motor?
2) Did you have any trouble with brake calliper clearance on either bike?
3) Did you use the 9 speed freewheels that came with both bikes? Any trouble fitting them (i.e. did you need a spacer washer and/or have to spread the dorpouts)?
4) How does the thuduster on the Alias hardtail ride? Tell me I don't need to buy a new bike as well... :)
Great build, thanks for sharing.
Tom L
Re: New project
Postby Ossielocal » Sun May 06, 2012 5:34 pm
Gday Tom ,
No it's not a Mac motor it's a 400w geared Ezee from ebikes.ca on the flat easily does 40km/h and can climb hills easy too but you wont brake any land speed records ..lol
On my first bike i just used 2 small washes on the back brake caliper to line it up with the disk but the new bike i didn't have to do anything just went straight on with no hassles .
My first bike had a 9 speed cassette and derailleur and had no problems there with the new bike it had a 10 speed cassette and derailleur so i had to buy a 9speed derailleur and just used the cassette that was on the Ezee wheel .The Ezee wheel comes with a small spacer washer so it doesn't rub against the cassette {freewheel} .
The thuduster great but you can't beat dual suspension bike i recommend if you can afford it buy a dual suspension bike the ride is very smooth .You need a very soft seat too for a comfortable ride .
What bike do you own ?
Tom L wrote:Your first bike looks very similar to what I've been planning for my Alias. A few of questions if you don't mind:
Ossielocal
Re: New project
Postby rui_fujino » Sun May 06, 2012 8:17 pm
that great looking build! I wish I had that much space for lipo!
one thing tho..I think you should change how your phase wires are going out from the hub...your setup may cause water to drip down into the hub...
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Re: New project
Postby zelectric » Sun May 06, 2012 11:09 pm
Ossielocal wrote:Finely finish ,thinking of using some hobbyking batteries down the track .
Nice Trance!! Clean build. The perfect bike to convert. :D
36 Volt 10ah Ping LiFePo-GT I-Drive - viewtopic.php?f=6&t=16835
36v SLA -Surf Bike - viewtopic.php?f=6&t=31147
48 Volt Trance X3 - viewtopic.php?f=6&t=34249#p497494
zelectric
Re: New project
Postby neptronix » Sun May 06, 2012 11:16 pm
What are you doing for torque arms/plates?
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Re: New project
Postby mvly » Mon May 07, 2012 12:38 am
Yeah once you go full suspension, you will never go back. Now my hard tail is collecting dust. I might off load it to someone here on the forum.
mvly
Re: New project
Postby Ossielocal » Mon May 07, 2012 3:42 am
Gday neptronix, didn't think it needed torque plates it's not overly torqueie Hub motor it's only 400w geared motor and it came with small torque washes and the axle fits pretty tight in the bike frame .
neptronix wrote:What are you doing for torque arms/plates?
Ossielocal
Re: New project
Postby Tom L » Mon May 07, 2012 4:44 am
Ossielocal wrote:Gday Tom ,
I've got a 2008 Giant Alias in storage. Was thinking of kitting it out with a BMC or MAC torque wound motor and 12s2p of lipo (16Ah) when I return to Oz latter this year.
My budget may streach far enough for a new bike.
Cheers for the answers.
Tom L
Re: New project
Postby voicecoils » Mon May 07, 2012 5:35 am
Ossielocal wrote:Gday neptronix, didn't think it needed torque plates it's not overly torqueie Hub motor it's only 400w geared motor and it came with small torque washes and the axle fits pretty tight in the bike frame .
It's much better to have them than not. Anytime the motor turns forwards, the axle pushes backwards against the dropouts.
Without torque arms, the only thing keeping the axle from turning is friction from the nuts being done up tight. If your axle nuts come loose, your dropouts will spread or snap easily.
The shop I work at sells the eZee kit torque arm which is an easy option, but it looks like you could easily fabricate something nicely integrated yourself.
The battery box you made is super slick, very clean conversion!
voicecoils
Re: New project
Postby Duc998 » Tue May 08, 2012 9:32 pm
edit: oops thought I was posting in my own thread :oops:
Was going to post in this anyway and say low the frame and the layout of the box. Cant believe how much room that triangle has cant believe I did'nt spot this model earlier :) Well done looks great.
Also yes I would get the dropouts or make your own. Why risk it its not worth it.
Giant DH Comp 03 build in progress 72v 18s3p 9C 9x7 12fet Infineon controller set 45amps
Duc998
Re: New project
Postby Ossielocal » Wed May 09, 2012 2:14 am
Hi guys taken your advice and brought a torque arm and thanks for the positive comments ..Added a pic with some mudguards on if i go for a dirt ride .
Ossielocal
Re: New project
Postby Ossielocal » Sun May 13, 2012 2:23 am
Had a problem today was going to go for a nice ride along the beach and the bike was playing up had to pull the motor apart and found a wire that was lose .Hopefully my soldering will hold and it's a know problem with these motors .viewtopic.php?f=3&t=36819
Ossielocal
Re: New project
Postby voicecoils » Sun May 13, 2012 4:40 am
Ossielocal wrote:Had a problem today was going to go for a nice ride along the beach and the bike was playing up had to pull the motor apart and found a wire that was lose. Hopefully my soldering will hold and it's a know problem with these motors .viewtopic.php?f=3&t=36819
Best to re-solder all 5 wires to the PCB while you have it open. If there's enough wire length, place through the holes and solder, instead of laying the wire simply on top of the hole. Afterword, check under the PCB with a flashlight and check that the solder has not bridged between hall wire connections underneath the PCB's thru-holes.
voicecoils
Re: New project
Postby Duc998 » Thu May 24, 2012 1:36 am
Hi Ossielocal
How do you find pedeling power of your bike? I like pedelling around 20 kph without assistance on a flats but finding it hard on my new dh comp build, My first ebike was a cheap ebay full suspension setup and I'm sure I could pedal on flats easier then the DH Comp. Could be the extra weight or sprocket setup. So I'm already starting to think about a light Trance build with x3 8ah 6s lipos :shock:
Duc998
Re: New project
Postby Ossielocal » Thu May 24, 2012 6:44 pm
Gday Duc998,i don't find it to hard too pedal with my setup .What motor have you have ? Battery i use is a ping 48v 10amp and i manage to get 45k with some pedaling average speed 30km/h.
Duc998 wrote:Hi Ossielocal
Ossielocal
Re: New project
Postby Trackman417 » Sun Aug 05, 2012 4:58 pm
Nice bike! Wish you showed some more pics of how you built the triangle box for those who wish to use aluminum :wink:
Great work really professional looking
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
Trackman417
Who is online
Users browsing this forum: Bing [Bot], Peter Sternersson, triggeraa and 12 guests
