The Mid Drive Hub Motor Media Group
Re: The Mid Drive Hub Motor Media Group
Postby John in CR » Fri Apr 13, 2012 7:14 pm
I'm looking to shorten the axle to save some weight, and more importantly cut down on the maximum width. Both sides are hollow, one for the wires and the other for a shifting rod. The wiring harness is so tight that I'd rather not replace it, so I can't get it too hot in the shortening process. How would you guys cut it? I'm leaning toward short periods with the angle grinder and cool it off.
Also, what about attaching the sprocket? One side is cast iron/steel that extends to the opposite side of the magnet ring. The wire side is a more typical AL cover, though I think I'd want to reinforce it or turn a new thicker one if I drive off of that side. I'm expecting to run 6-10kw peaks depending on voltage.
Lastly, being quiet is important. I'm looking at a 3:2 possible as high as 2:1 reduction, so what chain and sprockets for a budget oriented guy like me?...the 218 stuff LFP swears by? I was even thinking bike chain at least until I'm sure about gearing, but use chainring size sprockets to greatly reduce the torque load.
John
John in CR
Postby Whiplash » Fri Apr 13, 2012 7:26 pm
If you have access to a lathe that's how I do mine. Just tie up the wires and carefully cut till thin enough to break off..
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
1 GW
1 GW
Postby John in CR » Fri Apr 13, 2012 8:11 pm
Whiplash wrote:If you have access to a lathe that's how I do mine. Just tie up the wires and carefully cut till thin enough to break off..
If I cut the wires a few inches from the axle, that could work. Thanks for making me revisit the idea of using a lathe. With the phase wires shorted, I might be able to do it just chucking the whole motor in the lathe.
John in CR
Postby jull31 » Sat Apr 14, 2012 3:26 am
Motor bafang BPM 500w
Battery 4 zippy 6s for 44.4 V, 10 Ah
Max speed 50 km/h and 5 Wh/km
http://www.youtube.com/watch?v=ESPSq6J0 ... r_embedded
jull31
10 µW
10 µW
Postby bzhwindtalker » Sun Apr 15, 2012 2:18 pm
I miss my velomobile... I really can see how nice a mid driven velo would be!
last mid drive vid for a while, you will understand why at the end of the vid :(
bzhwindtalker
Postby knoxie » Sun Apr 15, 2012 2:51 pm
:( ahh damn what a shame...any chance the frame still has any warranty on it? great bike super agile, hope you get it sorted and get posting more videos soon :D
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby Haste » Sun Apr 15, 2012 8:38 pm
any benefit of using a smaller geared hub motor? Q series or bpm? It would even have more oomph on 48v than a DD...
1997 Marin Hill Hawk. Bafang BPM 2 10T. KU123 30 amp controller. 12s LiPo.=32mph
Haste
Postby Alan B » Sun Apr 15, 2012 9:26 pm
Video blocked for copyright content. :(
Alan B
Postby Harold in CR » Sun Apr 15, 2012 9:52 pm
American censorship. Video works for me. 8) 8) :lol: :lol:
[b]Thanks to Justin, the forum is open source and NON-commercialized.[/b
Harold in CR
Postby Whiplash » Sun Apr 15, 2012 11:23 pm
Ha typical USofA
Whiplash
1 GW
1 GW
Postby bzhwindtalker » Mon Apr 16, 2012 3:12 am
bzhwindtalker
Postby jateureka » Mon Apr 16, 2012 6:29 am
subscribed
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Ibosa; Aprilia; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4; Pending upgrades = Throttle Tamer & battery capacity meter.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, w'screen; Pending upgrades = Kilovac EV-200 contactor and 14 x Leaf modules for 132Ah pack
E-mower: EGO 56V mower & line trimmer
E-Power: 3.3kW solar array and Xantrax grid tie inverter
jateureka
Postby bzhwindtalker » Sat Apr 21, 2012 6:41 am
I made a new swing arm for my bike, new vids comming!
Also, this picture shows how the motor mount double up as a chain guard, not expected but really nice feature :
bzhwindtalker
Postby Timma2500 » Sat Apr 21, 2012 6:49 am
Also subscribed*
I like this build!
I hope the new swingarm works out well :)
Paul :D
Norco Aline / carbon fibre frame mod / 12t Mac / 12fet / 23kg
Timma2500
Postby gwhy! » Sat Apr 21, 2012 12:42 pm
bzhwindtalker wrote:I made a new swing arm for my bike, new vids comming!
I know you have a frame fail as well as the swingarm and I cant help thinking it maybe to do with the weight and position of the hub motor within the frame, Just a thought :| .
gwhy!
Postby bzhwindtalker » Sat Apr 21, 2012 1:21 pm
I can't see how a mid mounted motor could be worst than a wheel mounted motor...
The swingarm I built failed too, badly engineered and d
oing huge jumps...
bzhwindtalker
Postby amberwolf » Sat Apr 21, 2012 1:29 pm
I like that setup...but I would ask that next time you take pics, you take them of the sunny side of the bike. ;)
amberwolf
Postby bzhwindtalker » Mon May 07, 2012 1:54 am
This is my new signiature video :
bzhwindtalker
Postby spinningmagnets » Sat May 26, 2012 7:56 am
From Rassy, please note that Rassy has the mid-drive motor use the BOTTOM of the freewheel to add power to the chain...
http://endless-sphere.com/forums/viewtopic.php?f=28&t=18606
Same guy, different trike:
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=47043
Last edited by spinningmagnets on Sat Feb 23, 2013 9:46 pm, edited 1 time in total. View post history.
spinningmagnets
Postby spinningmagnets » Sat May 26, 2012 9:20 am
The M55, I know this is a low-production / high-Euro bike (Ferrari?) but I'd like to add it here simply because it shows that a well-researched project that can afford to do whatever it wants has studied E-bike drive systems,...and came to the conclusion that a hub driving the Bottom-Bracket (BB) is the best they could come up with.
In the interests of full-disclosure, I am working as a copy-editor (spell-checker?) for the electricbike.com web-magazine, and I have nothing to sell.
http://www.electricbike.com/m55/
Last edited by spinningmagnets on Sat Oct 11, 2014 7:47 pm, edited 1 time in total. View post history.
spinningmagnets
Postby spinningmagnets » Sat May 26, 2012 11:44 am
From LI-ghtcycle, I know this hub-as-a-non-hub is mounted to the cargo rack, but...it seemed appropriate, since I'm thinking this thread will become a magnet for non-hub research. Its a 9C driving a right-side chain to a twin-sprocket NuVinci hub. Claiming high efficiency, very believable.
http://endless-sphere.com/forums/viewtopic.php?f=3&t=25082
spinningmagnets
Postby spinningmagnets » Sat May 26, 2012 11:53 am
spinningmagnets
Postby spinningmagnets » Sat May 26, 2012 12:00 pm
John in CRs bike had the rear suspension arm welded with an extension to make room for an easier install of the mid-drive. For those who don't have access to a welder, I was able to make a longtail full suspension by attaching the BB-axle of an MTB rear-sus arm to the drop-outs of a hardtail. It was easier than I thought it would be. I can fit a 10-inch diameter skillet in the extra space, so an 8-inch geared hub would easily fit.
spinningmagnets
Postby bandaro » Sat May 26, 2012 9:51 pm
So I am seriously considering a hub mid drive to replace an outrunner for my next build, as I am currently having problems with snapping chains and tearing sprockets with my current build, the noise is tolerable, but I want something that is perfectly reliable.
So the reason I am avoiding a hub is the weight, currently the reduction for my 63-74 is well shy of 2kg all told, inc. motor (except crank/freewheel weight) and would take up a similar/smaller space to a hub motor. So as a result of the weight loss, I have a few kw in a bike well under 20kg, with 500wh of lifepo4. I am wanting a dual suspension, with lipo, and pretty sure I will be able to get the setup for under 6kg extra, but I hear that hub motors are very heavy, and the motor itself will be 6kg....
Never owned a hub, so don't know the weight for sure, but what would be the lightest hub that will push out 3-4kw? I am happy to overvolt it if it will handle it, just literally looking for the lightest way to get a hub running, so I can use all the hub motor components for reliability, and an off the shelf freewheel and bike chain going to the cranks. End result MUST be compact and clean.
Thanks for the input guys, I'm sure if there is a suitable motor out there, someone here knows it.
bandaro
Postby spinningmagnets » Sat May 26, 2012 11:32 pm
Geared hubs are common, and they are noticeably smaller in diameter than the direct-drive 9C-style of hubs. If you want the silence of a DD and you also want the small diameter of the geared hubs, Crystalyte no longer carries the 40X-series, but they do now carry the "G-series".
http://endless-sphere.com/forums/viewtopic.php?f=3&t=34203
spinningmagnets
Next
Who is online
Users browsing this forum: micah78, Yahoo [Bot] and 13 guests
