All the best
Tony
http://www.youtube.com/watch?v=SI8mWpng ... KUSNbYOFE=
kudos wrote:In your sig you have xlyte 72V 45A Controller, in the vid you say 72V 40A so which is it?
The reason I ask is that I also have the 72V 40A controller for my next build but I haven't tried it yet. I also see that there is a xlyte 72V 45A controller which seems to be quite a bit more expensive, so wondering which you are actually using?
Also what does 8 - 5s1p mean? Do you mean your pack is configured as 10S4P to give you 84V hot off charger ?
Cheers,
Kudos
kudos wrote:Just seen your bike pics in the before/after thread - nice!
Reminds me of Jimbo's setup with the battery mounted under the frame with the diagonal top edge.
What size rotors are you using 200 or 203mm ?
Kudos
pchen92 wrote:And so what's your range ?
smudger1956 wrote:......I am hoping for the neck end of 40..current setup APM and a sat nav reading showed 34mph.
I did get the idea from Jimbo's build.
smudger1956 wrote:My controller is a 45amper, why I thought is was 40amp..must be having a 'senior moment'...
kudos wrote:smudger1956 wrote:My controller is a 45amper, why I thought is was 40amp..must be having a 'senior moment'...
Ya need to change your sig too then, still says 40A!
valsislav wrote:Love the videos!
Users browsing this forum: adam333 and 11 guests
