Another Genesis Build...
Re: Another Genesis Build...
Postby ZOMGVTEK » Mon Apr 30, 2012 10:06 pm
The dropouts clamp now.
I also determined why the bike felt way faster than expected... The controller was feeding it 130A+... Whoops. Guess a 12 FET can take 12kW, at least temporarily. Now I need to get a 24 FET so I can run it at stupid power levels.
ZOMGVTEK
Postby nicobie » Tue May 01, 2012 2:49 pm
130 battery amps? What did you have your phase amps set to?
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby ZOMGVTEK » Tue May 01, 2012 2:52 pm
I'm not absolutely sure. I think I set the battery current to 50A, and the phase amps to 100. I wanted to have about 100/200A out of the controller, but I grossly underestimated my shunt modification, and the battery current was really high... Regen current is over 30A, which might be a bit too much.
It's running around 85/200 now, but I barely used it since.
ZOMGVTEK
Postby ZOMGVTEK » Mon May 07, 2012 10:23 pm
Only two MOSFET replacements later, and the controller is down to a pathetic 8-9kW with two small snubbers added.
24 FET is on the way. About 15kW is where I want it to be.
I started recording some random footage until some sketchy guy interrupted and starting pounding me with questions about the bike... So I jammed this trailer together. The bike isn't that fast right now anyways, so anything real is going to have to wait. I didn't intend on doing this, and never used this video thingamajiggie on my phone before, so the footage and edit isn't ideal.
ZOMGVTEK
Postby neptronix » Mon May 07, 2012 10:43 pm
That's such a sweet rear swingarm setup...
You need a 24FET, minimum, pronto, man!!
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby boppinbob » Wed May 09, 2012 7:37 pm
Does someone here have a link to a vendor so I can buy a single gear freewheel like zomgvtek has in this pictrure.
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Postby ZOMGVTEK » Wed May 09, 2012 8:54 pm
ZOMGVTEK
Postby ZOMGVTEK » Wed May 16, 2012 8:30 am
I have a fair bit of use on the bike now, probably over 100 miles. A beefy controller is on its way, hopefully it's fast enough at 15kW.
Me and my brother took them into work today. Probably saved a few trees or something like that.
ZOMGVTEK
Postby ZOMGVTEK » Sun May 20, 2012 7:21 pm
It looks like every time someone moves my bike, they rest the phase wires against an object to hold it up. So, I put some pegs on the axle...
And I managed to get the chain on.
ZOMGVTEK
Postby ZOMGVTEK » Mon Jun 18, 2012 5:09 pm
ZOMGVTEK
Postby Farfle » Mon Jun 18, 2012 5:18 pm
Daaaaaaaaamn....
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby ZOMGVTEK » Mon Jun 18, 2012 9:39 pm
It's really difficult to keep tires on this thing.
ZOMGVTEK
Postby boppinbob » Wed Jun 20, 2012 10:11 am
I noticed you didn't have the calipers on the rear disc brake hooked up. Was there a reason for that?
boppinbob
Postby ZOMGVTEK » Wed Jun 20, 2012 10:14 am
I don't really need or use a rear brake. I put the disc on there since I had it, just never bothered to try and get a caliper to fit. It might not, the clearance is quite minimal.
The rear of the bike is heavy enough that I can easily use the front brake down extreme inclines, and my regen works great at high speed.
ZOMGVTEK
Postby DolphLundgren » Fri Jun 22, 2012 2:49 pm
ZOMGVTEK wrote:
Nice rides :wink:
cool build
DolphLundgren
Postby migueralliart » Sun Jun 24, 2012 9:00 pm
In all seriousness please include pictures of the GTR as well ! :D
migueralliart
Postby ZOMGVTEK » Sun Jun 24, 2012 9:07 pm
This was surprisingly loud.
The GTR looks like a stock black GTR, it's not all that exciting.
At some point, my 24 FET is going to go back in and I might have to do some real smoky heaters. Then I'll have the 12 FET left over to get going on the TO-247 project.
ZOMGVTEK
Postby ZOMGVTEK » Sat Jun 30, 2012 7:18 pm
A cheap tire with about 20 hard miles on it, no heaters. It's really showing wear already.
It's looking like something a bit better than cheap bicycle tires are required.
ZOMGVTEK
Postby ZOMGVTEK » Wed Aug 29, 2012 8:54 pm
Me and a friend took our bikes to the track today. The guy at the tree must have thought it was a pedal bike, he started talking up a storm and I fell asleep at the light, so excuse the poor RT.
12.2260 @ 49.56
Not bad for a 12 FET controller and only 8kW with massive phase limiting. I think I can shave about 1 second off that 60 ft time with double the power and a 24 FET. The bike is a bit slow until it gets rolling 10 MPH or so with the massive phase limiting on the 12 FET.
Not the best quality video, but hey, I didn't record it.
http://www.youtube.com/watch?v=btKOu2ZBp50
ZOMGVTEK
Next
Who is online
Users browsing this forum: Google [Bot], Kepler, sflorlando and 11 guests
