AussieJester wrote:Seems there's alot of faffing about, asking and re-asking same questions, just fit the motor you have use the torque arm a and ride the bike, it will work fine....if you want a rear hub, talk to Es member cell_man he sells Mac motors for a better price than you're finding on Ebay, he's a trusted seller ..has quality motors and batteries...
KiM
Scruffoid wrote:Dont limit the power to 500W when they can give it 1000W.
You limit the power yourself by how far you turn the throttle, the extra power will surely come in handy.
Why have a Ferrari and then speed limit it to only 100Km/Hr.
Just my opinion.
Wayne
Elite track sprinters are able to attain an instantaneous maximum output of around 2,000 watts, or in excess of 25 W/kg; elite road cyclists may produce 1,600 to 1,700 watts as an instantaneous maximum in their burst to the finish line at the end of a five-hour long road race.
Scruffoid wrote:I have no idea how you battery is wired up etc but i would suggest that in a 16AH configuration that it is running multiple cells in Parallel and based upon that alone the amperage to supply 1000 W at 48 Volts is 1000/48 = 20 Amps. I think youll find that 20Amps wouldnt even make the batteries stress at all.
You worry way to much about stuff. Just build it get it running and start enjoying it.
1000W of power is nothing, you can pedal it with that much power with your feet. A human can produce some serious power its just for small bursts. Isnt it something like So it will all be good on your bike.Elite track sprinters are able to attain an instantaneous maximum output of around 2,000 watts, or in excess of 25 W/kg; elite road cyclists may produce 1,600 to 1,700 watts as an instantaneous maximum in their burst to the finish line at the end of a five-hour long road race.
So get off you bum plug it all together on the bike adn show us a picture of the thing put together and your grin of riding it.
Scruffoid wrote:You worry way to much about stuff. Just build it get it running and start enjoying it.
chopper_elec wrote:Yeah my only issue has been finding a hub motor that will fit in the very wide 175mm dropouts.
chopper_elec wrote:My only issue is having the tempation to go faster on a cheap bike lol. I was thinking that the 750w or 1000w might be too much amp draw for my lifepo4 48v 16ah battery
Scruffoid wrote:I dunno I cant see a trailer all i see is a workbench
[/quote]amberwolf wrote: Question: In the Relay symbol, it has three connections on top and two on bottom. Usually a relay uses the two for it's control, the coil, and three for it's load--one Common center, one Normally Open, and one Normally Closed. So I'm curious if that program does or doesn't do it that way, or if it is simply not using the likely more intuitive layout of grouping the control and load connections separately?
Users browsing this forum: No registered users and 5 guests
