E-Trike Project
E-Trike Project
Postby AussieJester » Sun May 25, 2008 2:36 am
G'day All :-)
I have been lurking about the forum for a month or two now gathering information for my own e-bike build, a BIG thanks to several members that have been extremely helpful:-) I thought now i have most of the info together I would start this thread so others may possibly have suggestions that might benefit the build ;-)
I plane to construct a custom frame, a trike frame, I am disabled (in-complete paraplegic) thus your standard two wheel bike isn't a possibility, pedals on this build will also be absent (i had originally planned on pedals but on further thought well.... ) So interest might be lost by alot due to this never the less we shall push on :-) I guess you could call this my own custom version of a mobility scooter as we often see the elderly getting about in...although im not that old (39) :-)
Thus far I have penciled a design (not to scale) on paper, apologies i don't have the skillz for autocad, anywayz...the proposed frame/drivetrain design-->
I was after a 'pro/stock' look, a lower seat height is required so as transferring from my wheelchair to the trike isn't a major issue. The frame will be constructed from thin walled mild steel pipe ranging from ~50mm to 25mm diameter (wall thickness ~1.5) I have yet to purchase all the piping required that will happen this week.
Front forks will also be custom made-->
Using the following plans
Electrics.
I have ordered the following from TNC Scooters
1000W Motor - 48 Volts (Model: MY1020)
11 Tooth Dual-D-bore Sprocket For #25 Chain
80 Tooth Sprocket for #25 Chain
48V Controller (Model LB37) Yi-Yun Brand Controller
Brake Leaver with Brake Switch
#25 Chain (70 Links)
2 Wire Ignition Assembly
Twist Throttle Cable (Hall Effect)
(and few additional components as spares)
From Cycle US The following will be oredered-->
2 x 20 inch x 4inch wide rims (had planned on steel 20's but they seem to have been removed from the list on the site ;-S (will email and see if they are still available.) along with 2 x tyres and trike hubs
Front wheel/tyre combo will be of the 20x 3inch variety sourced locally.
Powering the 1000watt motor will be four 12 volt 17aH SLA batteries. down the track i will go with the newer technology but due to cost (im on a disability pension) to get up and running SLA will be used ;-) The trike will be used predominantly for local runs on the bike path/footpath to the shops (approx 1km away) and longer runs to larger shopping center (and local pub hehe) some 3 kms away so the need for huge distance isn't of a big concern at this point. What is is hill climbing ability i live in a VERY hilly area. FYI it will be my only form of transportation, currently i wheel everywhere or catch taxi.
I have already purchased a 130amp mig welder ( i was a welder before my accident) and a pipe bender (awaiting delivery) to construct the trike frame. I have a pretty well equipped workshop at my home. This build will be a somewhat lengthy affai, that said i am hoping to have the trike complete (ridable maybe not prepped and painted) within 3 months.
OK..think that is about it for now shall post updates as the construction progresses :-)
I would appreciate/encourage any constructive criticisms by members and thank those who took the time to read this thread :-)
Kim
AussieJester
Re: E-Tike Project
Postby 1000w » Sun May 25, 2008 3:10 am
Good work Aussie, the frame looks awesome and I love your choice of rear rims and tyres, those low profiles look very cool.
I think maybe we should catch up and have a chat. PM me if you're keen.
Cheers,
Matt.
1000w
Re: E-Tike Project
Postby Miles » Sun May 25, 2008 3:20 am
Interesting project, Kim. I'm looking forward to seeing this progress.
Is the Driveline view from below or above?
Miles
Re: E-Tike Project
Postby AussieJester » Sun May 25, 2008 5:15 am
1000w wrote:I think maybe we should catch up and have a chat. PM me if you're keen.
Cheers,
Matt.
Thanks Matt and yeah always keen for a chat, shall drop you a pm
Yes mate it is (obviously rough) but i think you guyz get the idea ... 1000 watt motor with ~11 tooth cog #25 chain to a 80 tooth cog (will fabricate a mount on the 3 speed hub so as the 80 tooth sprocket bolts directly to the hub...im hoping the Shimano 3 speed hub i bought last week will arrive in a few days) the original 3 speed cog will have a chain to the rear axel which will drive one of the rear wheels only.
AussieJester
Re: E-Trike Project
Postby Miles » Sun May 25, 2008 5:22 am
Kim,
As we talked before, I think you may need to take the motor drive to the existing input point on the 3 speed and take the drive to the wheel from a sprocket mounted on the hub gear shell. I may be wrong, but I think it might be problematic to back-drive these hub gears. Certainly worth testing first, anyway...
Miles
Re: E-Trike Project
Postby AussieJester » Sun May 25, 2008 5:35 am
Miles wrote:Kim,
ahhh i got your initial info arse about mate LoL Originally i was going to place the large sprocket next to the original (similar to how 1000watt has done his) :-S No biggy and no need to change the design alot :-)
EDIT:
I did a quick Paint diagram to show how i wished to do it to make 100% sure i am on the same page ;-) -->
The s3 speed trike hubs at Cycle US have the two sprockets like i have drawn (albeit to sprockets of the same tooth count) one goes to the fron sprocket on the crank and the the drives rear wheels)
AussieJester
Re: E-Trike Project
Postby Miles » Sun May 25, 2008 5:44 am
It may work that way and it makes more sense from a fabrication point of view. The load will work in either direction, I'm just worried about the gear changing mechanism, particularly on the Shimano.
Anyway, give it a test: Shove the axle in a vice and run it both ways, by hand, to check that it changes gear without problems, under load.
Miles
Re: E-Trike Project
Postby Miles » Sun May 25, 2008 5:48 am
I wasn't clear, from your diagram, what was connected to what, on the hub.
As long as one of the sprockets is fixed direct to the shell, it will work, doesn't matter which side it's mounted, from that point of view.
Looking at the small photo here - http://www.choppersus.com/store/product ... Train-Kit/ - you can just about make out that the larger sprocket is attached to the hub shell. For a pedal drive, you are gearing up rather than down (as you are for electric drive), so that means that they are indeed using the sprocket fixed to the shell to drive the rear wheel.
Sorry if I confused you.
Miles
Re: E-Trike Project
Postby faranglaw » Sun May 25, 2008 6:22 am
Sounds like a neat project Aussie...just curious I know for bicycles there is a 200W limit in Oz but for a disabled trike is there any limit...? 1000W should pull that along nicely as long as you keep it lightish and are you goning to have it so you wheel your chair straight in (on ramp) or can you fold it up and place it on a rack..what about headlight incase you leave the local establishment a little late...blinkers etc..??.anyway sounds interesting keep the posts coming so we can see the project unfold.. all the best from Sydney.. Farang :wink:
faranglaw
Re: E-Trike Project
Postby AussieJester » Sun May 25, 2008 6:52 am
I'm with ya now miles Ill have to see how i can attach the original sprocket that comes on the hub to the hub housing when it arrives in a few days. Modifying the large sprocket to fit the hub will be an easier job, 1000watt has done this neatly on his cruiser i think i will probably take a similar approach :-) cheers for the input mate much appreciated ;-)
faranglaw wrote:Sounds like a neat project Aussie...just curious I know for bicycles there is a 200W limit in Oz but for a disabled trike is there any limit...? 1000W should pull that along nicely as long as you keep it lightish and are you goning to have it so you wheel your chair straight in (on ramp) or can you fold it up and place it on a rack..what about headlight incase you leave the local establishment a little late...blinkers etc..??.anyway sounds interesting keep the posts coming so we can see the project unfold.. all the best from Sydney.. Farang :wink:
haha yes i would like to know about the watt limit to buddy hehe I seem to recall i saw a mobility scooter motor used on something it was in the 500 watt range for memory. I'm basically hoping not to attract any attention from the local police up here, If ii do the motor will have miraculously been pulled from a mobility scooter! hehe it wont be visible when the trike is complete either so its size wont be such a 'give away' i guess...I plan to fabricate a housing from 1.5mm aluminium that will contain the batteries controller and motor, additionally i will be on the road only when crossing it and unless on the 'back road (footpaths)" will keep the speed down for saftely/police reasons, i simply feel i must have the larger size motor, 200watt wouldnt move my left arm let alone the rest of me plus my sport chair LoL... As for the wheelchair, im in two minds atm and will wait and see , initially i planned to make a solid towing bar that would simply and quickly attach to the rear swing arm of the trike suspending the front castor wheels off the ground, i have also pondered draging the chair up onto the rear of the trike, i think when the frame is made it will become a little more 'clear' if this will be possible or not. The chair itself isn't the 'folding' variety though, it has quick release wheels (push the inner button of the hub they pull off) and the back rest folds down only) Thankfully the wheelchair i have is reasonably lightweight. HAHA and yes the trike will definitely have front and rear tail light on it i wont go so far as having blinkers however :-)
Shall definitely keep the posts coming when fabrication starts in coming days, thanks for the well wishes mate :-)
Kim
AussieJester
Re: E-Trike Project
Postby J Barrie Wilkinson » Sun May 25, 2008 4:14 pm
Hi Kim,
I have done a DF hybrid bike and a tadpole trike using #25 chain drive at the bottom bracket. There is a 90t Curry scooter sprocket
http://www.electricscooterparts.com/sprockets.html (scroll down)
if you need to gear down more, which is what I used but had a smaller motor than you. Make sure you get heavy duty #25 chain, it is much stronger and is usually designated as #25H.
Good luck with your project, an exercise in frustration in the construction but oh the Ebike grin when it all comes together.
Giant Revive 408/412 72V 20A 12AH sla's
EVT 750W Brushless 36V 15AH NiMH
Sun CX Tadpole Trike not yet powered
J Barrie Wilkinson
Re: E-Trike Project
Postby AussieJester » Sun May 25, 2008 8:53 pm
J Barrie Wilkinson wrote:Hi Kim,
Cheers for the info there mate, I do actually have electric scooter parts bookmarked and originally was going to get the elctrics from them, i then was given the TNC link (thankyou safe saved me a packet of money :-) ) and their prices were much more attractive, I did however want one of the shockies from electric scooter parts until i was quoted $US127 for delivery, suffice to say i didnt get the shocky LoL... TNC charged me 44 for all the parts I ordered from them :-) Will keep them in mind though if a bigger cog is required ;-) I have ordered a #25 chain from TNC scooters (a couple of 72 link lengths of it actually and a chain breaker to adjust to size, i am not aware if it is of the heavy duty variety however? This is the chain info-->
Motor Parts - 106001
Shipping Weight: 0.5 lbs.
Chain is 17-1/2'' long.
#25 chain has a 1/4'' spacing between each link and is approximately 1/4'' wide.
might be an idea to add a few links and the chain break too the onboard tool kit along with puncture repair kit i guess, last thing i need is breaking down in my area theres zero chance of me moving this creation up a hill back to my garage :-S
As for the frustration in construction i know what your getting at there LoL Also am familiar with the feeling when a job is completed, nothing like it imo :-)
Thankyou for your input mate much appreciated :-)
AussieJester
3 Speed Shimano Hub
Postby AussieJester » Mon May 26, 2008 3:48 am
The postie dropped of the Shimano 3 speed hub i won off ebay last week so i promptly stripped it down for a looksee.
Once cleaned off and the few decades of grease and grim were cleaned off it came up well, looks to be in very good condition too :-)
Miles I soon found that the original sprocket (once the 3 'lugs') were ground off fits snuggly over the external end of the hub (opposite end to where it is originally) I shall by another to fasten the larger sprocket to ala how 100watt did his. Anywayz...i do have a dilemma, I have the hub stripped as far as can been seen in above pics but i need to get the end off, i circled the recess where i presume a tool fits to unscrew the end BUT i want to know which way the thread goes, i assume it would be a anti clockwise to undo? I did put it in the vise and give it a few taps, it didn't budge and without knowing if i'm tightening or loosening it i didnt want to apply more force I don't want to attempt welding the sprocket onto the end of the hub before stripping the rest of the internals as its going to heat up ALOT with the mig...
If anyone could offfer some insight i would be appreciative...the blown up plans i managed to find on the net dont give details on thread direction etc
Thanks in advance
Kim
AussieJester
Re: E-Trike Project
Postby TylerDurden » Mon May 26, 2008 4:21 am
Nice pix AJ,
FWIW, my ancient Sturmey opens anti-clockwise.
Rather than use a punch, I made two "keys" that fit in the slots by flattening nails with a hammer... I could then use a pipe-wrench to remove the top race. (The wrench could bite onto the keys, holding them in place and not slip on the hardened cover.) "Ghetto-Spanner", if you will.
HTH
:D
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Please post your Watts-at-speed in the survey.
TylerDurden
Re: E-Trike Project
Postby Miles » Mon May 26, 2008 4:31 am
Lots of useful info on hub gears here: http://hubstripping.wordpress.com/
Miles
Next
Who is online
Users browsing this forum: No registered users and 6 guests
