Jonathan's 44 lbs Specialized FSR S-Works
Postby Jonathan » Thu May 29, 2008 1:15 pm
This is my 2nd bike that I put together. The first one was a learner hardtail Rockhopper. Not quite my cup of tea.
So I'm out on a quest to make a sub 50 lbs bike that can do 35+ mph.
Here's what I got.
1. Donor Specialized S-Works
2. BMC Gear Hub (evtech)
3. Crystalyte 24-72V 35A Analog Controller (ebike.ca)
4. A123 M1 20S2P 66V/4.6Ah Battery (custom)
5. Crystalyte Half Twist Throttle (ebike.ca)
6. Cycle Analyst (ebike.ca)
After talking to Maytag, I've upgraded the motor phase wires inside the motor and kept it as short as possible.
he motor, controller, throttle, and cycle analyst mounted was a fairly quick and easy process. Couple tie wrap and wires shortening things were done in a jiffy.
The stock 20A controller is a PIC, it can barely do 20 at 36V lithium. I immediately went shopping for a better controller. Considering the BMC motor got plenty of torque, I didn't need the CL's 48A controller. IMHO it would just be a waste of torque and potentially ripping out my dropout. So I got the 35A controller with the main goal of bumping my voltage and therefore top speed.
I ran into a minor hickup with the drive system. The S-Works comes with Shimano Deore XT 9-speed shifter, which didn't work with my 7-speed flywheel on the motor. I had to downgrade to a 7-speed shifter which was significantly rougher. I might get that 9-speed flyweel and rehaul this.
There's still ALOT of work to be done for my baby to be on the road such as dual torque arm installation, battery pack & enclosure fabrication , lighting etc. But the basis is there.
I'll be updating this with the progress made.
Status Update:
05/25 - A123 M1 20S2P 66V/4.6Ah Battery Pack completed.
06/01 - dual torque bar installed.
06/04 - Enclosure mold produce. Kevlar/Carbon Fiber laydown started
Jonathan
Re: Jonathan's 44 lbs Specialized S-Works
Postby Lenk42602 » Thu May 29, 2008 3:45 pm
Lookin good! Where are the batts going?
Peace,
Len
Lenk42602
Postby Microbatman » Thu May 29, 2008 7:39 pm
Let me know where you find a 9 speed freewheel or what type of 7 speed derailur you pick.
I am using a 5 speed freewheel on 9 speed derailer and works OK just need to click 2x to go from 3rd to4th sproket
I would like to make it all perfect. Works for now but looking to improve.
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Postby safe » Fri May 30, 2008 6:34 am
Going Vertical
That's the first time (that I can recall) that I've seen somone have the presence of mind to go vertical with the battery mounting rather than the usual horizontal. Seems that most people try to imitate the bike rack and when you combine it with suspension you always end up with a rack that wants to break due to stress.
By going vertical you reduce the stress and have a better mounting location. You could double the battery with this configuration because the seat tube gives added strength.
Very nice... :)
safe
Postby TylerDurden » Fri May 30, 2008 6:45 am
safe wrote:That's the first time (that I can recall) that I've seen somone have the presence of mind to go vertical with the battery mounting rather than the usual horizontal. Seems that most people try to imitate the bike rack and when you combine it with suspension you always end up with a rack that wants to break due to stress.
Very nice... :) [/color]
That would be the controller...
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby safe » Fri May 30, 2008 7:02 am
TylerDurden wrote:That would be the controller...
I don't know... he says he has:
"4. A123 M1 20S2P 66V/4.6Ah Battery (custom)"
...and that would be about the right size for it. I guess we will have to wait for a response.
safe
Postby TylerDurden » Fri May 30, 2008 7:06 am
If you are familiar with ebiking, you will recognize that box as a Clyte controller. :roll:
You might notice the cable with the Anderson connectors hanging on the top-tube for the pack.
Have a Nice Day,
TD
TylerDurden
Postby slayer » Fri May 30, 2008 7:15 am
LOL... i was trying to figure out what was safe talking about.
but i belive in a couple of years a decent battery pack will be as small as a the controller...
slayer
Postby Ypedal » Fri May 30, 2008 7:30 am
Holy crap safe.. you really should know this by now !! :cry:
Jonathan !! excellent build !! looks nice and clean ! 8)
If you ride in the wet, seal the wires with silicone as they enter the axle, and you might want to loop the wires down so that water drips to the ground instead of funelling into the motor !! :wink:
Otherwise good job man !!
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby safe » Fri May 30, 2008 9:52 am
I don't use a hub motor so I'm not familiar with their controller boxes.
The Unite (appropriate matching) controllers are brushed aluminum... so I just figured he had built his own box for the batteries.
It doesn't look like a controller because there are no fins and it's not aluminum. (what you would normally expect)
Unless are they aluminum with black paint?
safe
Postby Mark_A_W » Fri May 30, 2008 5:23 pm
Safe, you are way overestimating the energy density of lithium batteries...
Most heatsinks are anodised black....you've never seen a heatsink? A controller box is a heatsink, and about half are black (I have one black and one straight ally).
I like your bike Jonathan. The one change I would make is upgrading the front end to disc brakes.
And let me know if you find a 9 speed freewheel. I did find an 8 speed on the internet, but AFAIF there's no such thing as a nine speed. On a normal bike you bend your axle with more than 7. http://www.sheldonbrown.com/speeds.html
It really sucks as all decent shifters are 9 speed...one reason I ended up with a front hub. The best 7 speed shifter are Shimano Rapid Fire 7's I think. Depending on brand the spacings between sprockets changes from 7 to 8 to 9 speed, but I think you can get away with a 7 speed cluster and an 8 speed changer...at least I hope so as that's what my brother's half built e-bike will have!
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Mark_A_W
Postby CGameProgrammer » Fri May 30, 2008 5:50 pm
Yes that's a Crystalyte controller behind the seat and he says he hasn't made the battery pack yet. 20s2p is four DeWalt 36V packs, and that's not tiny.
CGameProgrammer
Postby Jonathan » Fri May 30, 2008 6:12 pm
Solidworks modeling ... 20S2P Battery pack assemble and insulated with tap to prevent shorting.
My mold for the carbon fiber battery enclosure.
I had some progress with the battery pack. Couple minutes of 3D modeling and several hours of shoe-goo & soldering.
The A123 M1 are not quite 26mm it's more like 27mm. NP it still fit within my frame.
During the assembly process I accidentally dropped the my screwdriver across the battery and ZAPP! a 2mm weld occur. Luckily the batteries are still fine.
Microbatman, I had the link for the 9-speed freewheel somewhere but I can't seems to find it now. I believe they are for the Bionx. Not quite sure if they fit the BMC or not but well worth a try.
Ypedal, thanks for the wiring recommendation. Will do.
Mark, Front disc brake is part of the plan but first I need to get this thing on the road.
Jonathan
Postby knoxie » Sat May 31, 2008 7:13 am
Hi
Nice bike! and a nice build as well, this is going to be a copy of maytags bike in many ways! you will love the Puma at 66V its a nice safe voltage to run one at as well, any higher and the stock controllers have problems, this is an analogue controller you have there? you will need your torque arms bolted down well as it will throw a huge amount of torque at you, great place for batteries in there wont affect the handling too much, hope there is enough capacity in there for you? you can always back off on the throttle and peddle more for greater range.
Make sure you fit a kill switch to this rig, it will accelerate hard you dont want the throttle jamming, just get one of those little pit bike bar switches and wire it in to the brake line, I dont think you need a disc brake on the front IMHO, the bike is nice and light and it will have a good spec v-brake on it, get some decent pads and you should be fine, none of my e-bikes other than my KMX have them and I run quality pads and good cables, keep the well adjusted they stop me just fine, disc brake pads wear out just as quickly as well and they are normally more expensive to buy.
Good luck with the pack building, where did you get the batteries from? I may do something similar in the future, however I would need more AH for longer rides, maybe put a booster pack on a rack on the back, you could do that with your rig, keep it nice and light and simple for local stuff then pop a seatpost rack on the back with another pack in should you wish to go touring at range.
Once its on the bike its a good idea to use some self amalgamating tape around the exposed axle hole to keep the water out and also like the other poster said loop the cable up, check with maytag to get the correct phase connections as this is important.
Keep the pics coming I love seeing new bikes being born
Knoxie
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby Jonathan » Tue Jun 03, 2008 3:09 am
Ah! I found the 9-speed freewheel. I believe this is for the Bionx. Not sure if it will work with the regular 9-speed shifter.
http://nycewheels.com/9-speed-freewheel-13-32.html
Jonathan
Postby Mark_A_W » Tue Jun 03, 2008 4:19 am
Umm, when I clicked that I found a freewheel adapter, not a 9 speed freewheel.
I did find an 8 speed when I poked around.
Thanks for looking though.
Mark_A_W
Postby Mark_A_W » Tue Jun 03, 2008 4:35 pm
Thanks.
Yep, it's 9 speed (well, the description is). But it would be nicer is the smallest sprocket was 11 tooth instead of 13.
To find out if it is compatible with shifters you need to know the sprocket spacing.
Mark_A_W
Postby Jonathan » Mon Jun 09, 2008 3:48 pm
I've had a little more progress on the bike since the last posting. I finally finished my ride. Woo Hoo!
The batteries pack fit within the triangle frame with about a 1/4 slop. I then machined couple little spacers to hug the circumference of the downtube for a little better traction. The fit now is pretty darn tight with only one way of coming apart.
1. slide the top spacer up & out.
2. tilt, pivot battery pack 25* then slide upward.
I don't think this one is going anywhere soon.
The batteries are wired as two separate 2P10S configuration, which allow me individually balance each cells. I can also go from 33V / 8.6A configuration to 66V / 4.5A configuration in an instance.
I also got a chance to installed the two stainless steel torque arm from EVTech (they're $12.50/each, what a deal!). I preferred two over one torque arm to keep the torque force parallel to the frame. From what I've seen or dropout with torque arm fatique/failure is that the arm horizontally tilt and cause the dropout to expand and break. Again all I have to do is machine couple spacer blocks out of AA6061-T6 to the frame. I didn't need any for the brake torque since I have freewheel.
Here's the final results.
Sorry for the messy garage pic.
I'm very satisfied with the current results. It weight a total of 47 lbs, 3 lbs more than original spec, due to CA, wirings, spacers and duct tape.
The handling is almost stock with most of the weight at the lower 2'. Slalom was quite a bit of fun on this full suspension.
Top speed for me was 35 mph on flat no wind. fitek reported something like 37 mph but I think it's down the small gradient.
What's next?
Well I need to get disc brakes. At least for the front, because stopping from 30+ mph is pretty darn scary with v-brakes.
The other thing is to connect the cruise control. Now I know why joystix, maytag, & jondoh luv theirs so much.
But this will be another day and another project.
Jonathan
Postby pwbset » Mon Jun 09, 2008 4:08 pm
Epic build! Congrats! I do think you need to add a little paint job to the batt pack though before it's complete. :P :wink: :mrgreen:
pwbset
Postby TylerDurden » Mon Jun 09, 2008 4:39 pm
If that's a messy garage, I qualify for FEMA funding. :oops:
SLick bike man. You got stealth.
:mrgreen:
Have a Nice Day,
TD
TylerDurden
Postby vanilla ice » Mon Jun 09, 2008 5:31 pm
"Please excuse the crudity of this model. I didn't have time to build it to scale or to paint it."
Its always those guys who say "I apologize in advance for the messy xxx" that have the neatest xxx.
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby fitek » Tue Jun 10, 2008 12:07 pm
Jonathan let me ride this bike the past weekend and it is amazingly fast. 32mph uphill! And it out accelerated cars quite easily.
Additionally, when I got home I felt shameful and spent the rest of the day cleaning my garage.
Hyperion RC powered El Cheapo scooter
72 volt Bafang+Makita powered Downtube folder
Full suspension serial hybrid tandem SWB recumbent, 36v 12ah Makita, Kollmorgen
FWD LWB recumbent featuring 24v 300W Kollmorgen and office chair seat
Bottom bracket driven Motiv mountain bike, MY1018
E-Ton Eco folding electric bike, 18" wheels, 24V 10ah SLA
fitek
Postby AussieJester » Mon Jun 16, 2008 8:00 pm
Jonathan wrote:
What's next?
Impressive looking ride there Jonathon :-) Are we still going to see the carbon/kevlar enclosure sometime down the track or has this been scrapped completely (apologies if i missed anything regarding it)... Very interested in seeing how it comes out as i plan on something similar myself ...
AussieJester
Postby deecanio » Tue Jun 17, 2008 4:56 am
Hi Jonathan,
yes very very nice build - clean and stealth just how we like it!!!
looks like Maytags GT - nice and light too :) excellent work!!
Cheers
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Next
Who is online
Users browsing this forum: No registered users and 11 guests
