Samd
I wasn't happy with the to-ing and fro-ing on my tank for the dual drive plans in another thread, and whilst I was enjoying the whole duct tape ghetto thing, I decided it was time to join the chopped ranks with a custom 6160 tank.
Here's the donor bike:
I liked the way the bike handled even with the LiPo up high on the top tube as 15S2P on 5Ahr bricks. So I decided to keep the batteries up there in case I ever mount a GNG kit on the downtube.
Despite the cheaper nature of the donor frame I was pleasantly surprised to find nice thick 4mm walls inside when the 4inch grinder came out to liberate the top tube.
I was surprised at the rigidity of the frame with the top tube missing. The downtube is 50mm diameter, so that section is quite strong. The top tube/tank should be in compression only.
Given the nature of the frame I've actually bought the last remaining dozen of these frames to customise but more of that in a forsale thread of it's own later....
With a bit of CAD and cardboard design I managed to make up a design I was happy with that held 555 watt hours of Zippys. 86mm internal for the most width tapering back slightly at the seat join.
There is a door underneath that bolts into place, with about 25mm of clearance. I plan to hide a 12FET under there after removing it from it's casing and bolting the heatsink to the underdoor. I like the idea of the top being solid as we often get light rain where I live.
I found a local fabricator that TIGs dirtbike frame upgrades who is really easy to deal with. He also does a lot of 6061 Aluminium buggies and does not bother T6 treating them any more due to using slightly thicker walls. I've gone with his suggestions on internal gusseting and will ride the prototype to destruction, with some help of a few other local ES members. Nice to have spare frames in the shed if i can kill this one.
